This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
@ActiveProfiles
@ActiveProfiles
is a class-level annotation that is used to declare which bean
definition profiles should be active when loading an ApplicationContext
for an
integration test.
The following example indicates that the dev
profile should be active:
Java
Kotlin
@ContextConfiguration
@ActiveProfiles("dev") (1)
class DeveloperTests {
// class body...
1 | Indicate that the dev profile should be active. |
// class body...
The following example indicates that both the dev
and the integration
profiles should
be active:
Java
Kotlin
@ActiveProfiles({"dev", "integration"}) (1)
class DeveloperIntegrationTests {
// class body...
1 | Indicate that the dev and integration profiles should be active. |
@ActiveProfiles(["dev", "integration"]) (1)
// class body...
@ActiveProfiles provides support for inheriting active bean definition profiles
declared by superclasses and enclosing classes by default. You can also resolve active
bean definition profiles programmatically by implementing a custom
ActiveProfilesResolver
and registering it by using the resolver attribute of @ActiveProfiles .
See Context Configuration with Environment Profiles,
@Nested
test class configuration, and the
@ActiveProfiles
javadoc for
examples and further details.
