For the latest stable version, please use Spring Framework 6.2.6!spring-doc.cn
Spring Testing Annotations
The Spring Framework provides the following set of Spring-specific annotations that you can use in your unit and integration tests in conjunction with the TestContext framework. See the corresponding javadoc for further information, including default attribute values, attribute aliases, and other details.spring-doc.cn
Spring’s testing annotations include the following:spring-doc.cn
