For the latest stable version, please use Spring Framework 6.2.4! |
Reactive Libraries
spring-webflux
depends on reactor-core
and uses it internally to compose asynchronous
logic and to provide Reactive Streams support. Generally, WebFlux APIs return Flux
or
Mono
(since those are used internally) and leniently accept any Reactive Streams
Publisher
implementation as input. The use of Flux
versus Mono
is important, because
it helps to express cardinality — for example, whether a single or multiple asynchronous
values are expected, and that can be essential for making decisions (for example, when
encoding or decoding HTTP messages).
For annotated controllers, WebFlux transparently adapts to the reactive library chosen by
the application. This is done with the help of the
ReactiveAdapterRegistry
, which
provides pluggable support for reactive library and other asynchronous types. The registry
has built-in support for RxJava 3, Kotlin coroutines and SmallRye Mutiny, but you can
register others, too.
For functional APIs (such as [webflux-fn], the WebClient
, and others), the general rules
for WebFlux APIs apply — Flux
and Mono
as return values and a Reactive Streams
Publisher
as input. When a Publisher
, whether custom or from another reactive library,
is provided, it can be treated only as a stream with unknown semantics (0..N). If, however,
the semantics are known, you can wrap it with Flux
or Mono.from(Publisher)
instead
of passing the raw Publisher
For example, given a Publisher
that is not a Mono
, the Jackson JSON message writer
expects multiple values. If the media type implies an infinite stream (for example,
application/json+stream
), values are written and flushed individually. Otherwise,
values are buffered into a list and rendered as a JSON array.
