For the latest stable version, please use Spring Framework 6.2.4! |
Package Hierarchy
The Spring Framework’s JDBC abstraction framework consists of four different packages:
core
: Theorg.springframework.jdbc.core
package contains theJdbcTemplate
class and its various callback interfaces, plus a variety of related classes. A subpackage namedorg.springframework.jdbc.core.simple
contains theSimpleJdbcInsert
andSimpleJdbcCall
classes. Another subpackage namedorg.springframework.jdbc.core.namedparam
contains theNamedParameterJdbcTemplate
class and the related support classes. See Using the JDBC Core Classes to Control Basic JDBC Processing and Error Handling, JDBC Batch Operations, and Simplifying JDBC Operations with theSimpleJdbc
Classes. -
datasource
: Theorg.springframework.jdbc.datasource
package contains a utility class for easyDataSource
access and various simpleDataSource
implementations that you can use for testing and running unmodified JDBC code outside of a Jakarta EE container. A subpackage namedorg.springframework.jdbc.datasource.embedded
provides support for creating embedded databases by using Java database engines, such as HSQL, H2, and Derby. See Controlling Database Connections and Embedded Database Support. -
object
: Theorg.springframework.jdbc.object
package contains classes that represent RDBMS queries, updates, and stored procedures as thread-safe, reusable objects. See Modeling JDBC Operations as Java Objects. This approach is modeled by JDO, although objects returned by queries are naturally disconnected from the database. This higher-level of JDBC abstraction depends on the lower-level abstraction in theorg.springframework.jdbc.core
package. -
support
: Theorg.springframework.jdbc.support
package providesSQLException
translation functionality and some utility classes. Exceptions thrown during JDBC processing are translated to exceptions defined in theorg.springframework.dao
package. This means that code using the Spring JDBC abstraction layer does not need to implement JDBC or RDBMS-specific error handling. All translated exceptions are unchecked, which gives you the option of catching the exceptions from which you can recover while letting other exceptions be propagated to the caller. See UsingSQLExceptionTranslator
