For the latest stable version, please use Spring Framework 6.2.0! |
Using @Autowired
JSR 330’s |
You can apply the @Autowired
annotation to constructors, as the following example shows:
Java
Kotlin
public class MovieRecommender {
private final CustomerPreferenceDao customerPreferenceDao;
@Autowired
public MovieRecommender(CustomerPreferenceDao customerPreferenceDao) {
this.customerPreferenceDao = customerPreferenceDao;
class MovieRecommender @Autowired constructor(
private val customerPreferenceDao: CustomerPreferenceDao)
As of Spring Framework 4.3, an |
You can also apply the @Autowired
annotation to traditional setter methods,
Java
Kotlin
public class SimpleMovieLister {
private MovieFinder movieFinder;
@Autowired
public void setMovieFinder(MovieFinder movieFinder) {
this.movieFinder = movieFinder;
@set:Autowired
lateinit var movieFinder: MovieFinder
You can also apply the annotation to methods with arbitrary names and multiple arguments, as the following example shows:
Java
Kotlin
private MovieCatalog movieCatalog;
private CustomerPreferenceDao customerPreferenceDao;
@Autowired
public void prepare(MovieCatalog movieCatalog,
this.movieCatalog = movieCatalog;
private lateinit var movieCatalog: MovieCatalog
private lateinit var customerPreferenceDao: CustomerPreferenceDao
@Autowired
fun prepare(movieCatalog: MovieCatalog,
customerPreferenceDao: CustomerPreferenceDao) {
You can apply @Autowired
to fields as well and even mix it with constructors, as the
Java
Kotlin
@Autowired
@Autowired
private val customerPreferenceDao: CustomerPreferenceDao) {
@Autowired
Make sure that your target components (for example, For XML-defined beans or component classes found via classpath scanning, the container
usually knows the concrete type up front. However, for |
You can also instruct Spring to provide all beans of a particular type from the
ApplicationContext
by adding the @Autowired
annotation to a field or method that
expects an array of that type, as the following example shows:
Java
Kotlin
@Autowired
private MovieCatalog[] movieCatalogs;
@Autowired
private lateinit var movieCatalogs: Array<MovieCatalog>
The same applies for typed collections, as the following example shows:
Java
Kotlin
private Set<MovieCatalog> movieCatalogs;
@Autowired
public void setMovieCatalogs(Set<MovieCatalog> movieCatalogs) {
this.movieCatalogs = movieCatalogs;
@Autowired
lateinit var movieCatalogs: Set<MovieCatalog>
Your target beans can implement the You can declare the Note that the standard |
Even typed Map
instances can be autowired as long as the expected key type is String
The map values contain all beans of the expected type, and the keys contain the
corresponding bean names, as the following example shows:
Java
Kotlin
private Map<String, MovieCatalog> movieCatalogs;
@Autowired
public void setMovieCatalogs(Map<String, MovieCatalog> movieCatalogs) {
@Autowired
lateinit var movieCatalogs: Map<String, MovieCatalog>
By default, autowiring fails when no matching candidate beans are available for a given injection point. In the case of a declared array, collection, or map, at least one matching element is expected.
The default behavior is to treat annotated methods and fields as indicating required
dependencies. You can change this behavior as demonstrated in the following example,
enabling the framework to skip a non-satisfiable injection point through marking it as
non-required (i.e., by setting the required
attribute in @Autowired
to false
Java
Kotlin
@Autowired(required = false)
var movieFinder: MovieFinder? = null
A non-required method will not be called at all if its dependency (or one of its dependencies, in case of multiple arguments) is not available. A non-required field will not get populated at all in such cases, leaving its default value in place. In other words, setting the |
Injected constructor and factory method arguments are a special case since the required
has a somewhat different meaning due to Spring’s constructor
resolution algorithm that may potentially deal with multiple constructors. Constructor
and factory method arguments are effectively required by default but with a few special
rules in a single-constructor scenario, such as multi-element injection points (arrays,
collections, maps) resolving to empty instances if no matching beans are available. This
allows for a common implementation pattern where all dependencies can be declared in a
unique multi-argument constructor — for example, declared as a single public constructor
without an @Autowired
annotation.
Only one constructor of any given bean class may declare |
Alternatively, you can express the non-required nature of a particular dependency
through Java 8’s java.util.Optional
@Autowired
public void setMovieFinder(Optional<MovieFinder> movieFinder) {
As of Spring Framework 5.0, you can also use a @Nullable
annotation (of any kind
in any package — for example, javax.annotation.Nullable
from JSR-305) or just leverage
Kotlin built-in null-safety support:
Java
Kotlin
@Autowired
public void setMovieFinder(@Nullable MovieFinder movieFinder) {
@Autowired
You can also use @Autowired
for interfaces that are well-known resolvable
dependencies: BeanFactory
, ApplicationContext
, Environment
, ResourceLoader
ApplicationEventPublisher
, and MessageSource
. These interfaces and their extended
interfaces, such as ConfigurableApplicationContext
or ResourcePatternResolver
, are
automatically resolved, with no special setup necessary. The following example autowires
an ApplicationContext
object:
Java
Kotlin
@Autowired
private ApplicationContext context;
public MovieRecommender() {
@Autowired
lateinit var context: ApplicationContext
The |
