For the latest stable version, please use Spring Framework 6.2.6!spring-doc.cn
Filters
Form Data
Browsers can submit form data only through HTTP GET or HTTP POST but non-browser clients can also use HTTP PUT, PATCH, and DELETE. The Servlet API requires ServletRequest.getParameter*() methods to support form field access only for HTTP POST.spring-doc.cn
The spring-web module provides FormContentFilter to intercept HTTP PUT, PATCH, and DELETE requests with a content type of application/x-www-form-urlencoded, read the form data from the body of the request, and wrap the ServletRequest to make the form data available through the ServletRequest.getParameter*() family of methods.spring-doc.cn
Forwarded Headers
As a request goes through proxies (such as load balancers) the host, port, and scheme may change, and that makes it a challenge to create links that point to the correct host, port, and scheme from a client perspective.spring-doc.cn
RFC 7239 defines the Forwarded HTTP header that proxies can use to provide information about the original request. There are other non-standard headers, too, including X-Forwarded-Host, X-Forwarded-Port, X-Forwarded-Proto, X-Forwarded-Ssl, and X-Forwarded-Prefix.spring-doc.cn
ForwardedHeaderFilter is a Servlet filter that modifies the request in order to a) change the host, port, and scheme based on Forwarded headers, and b) to remove those headers to eliminate further impact. The filter relies on wrapping the request, and therefore it must be ordered ahead of other filters, such as RequestContextFilter, that should work with the modified and not the original request.spring-doc.cn
There are security considerations for forwarded headers since an application cannot know if the headers were added by a proxy, as intended, or by a malicious client. This is why a proxy at the boundary of trust should be configured to remove untrusted Forwarded headers that come from the outside. You can also configure the ForwardedHeaderFilter with removeOnly=true, in which case it removes but does not use the headers.spring-doc.cn
In order to support asynchronous requests and error dispatches this filter should be mapped with DispatcherType.ASYNC and also DispatcherType.ERROR. If using Spring Framework’s AbstractAnnotationConfigDispatcherServletInitializer (see Servlet Config) all filters are automatically registered for all dispatch types. However if registering the filter via web.xml or in Spring Boot via a FilterRegistrationBean be sure to include DispatcherType.ASYNC and DispatcherType.ERROR in addition to DispatcherType.REQUEST.spring-doc.cn
Shallow ETag
The ShallowEtagHeaderFilter filter creates a “shallow” ETag by caching the content written to the response and computing an MD5 hash from it. The next time a client sends, it does the same, but it also compares the computed value against the If-None-Match request header and, if the two are equal, returns a 304 (NOT_MODIFIED).spring-doc.cn
This strategy saves network bandwidth but not CPU, as the full response must be computed for each request. State-changing HTTP methods and other HTTP conditional request headers such as If-Match and If-Unmodified-Since are outside the scope of this filter. Other strategies at the controller level can avoid the computation and have a broader support for HTTP conditional requests. See HTTP Caching.spring-doc.cn
This filter has a writeWeakETag parameter that configures the filter to write weak ETags similar to the following: W/"02a2d595e6ed9a0b24f027f2b63b134d6" (as defined in RFC 7232 Section 2.3).spring-doc.cn
In order to support asynchronous requests this filter must be mapped with DispatcherType.ASYNC so that the filter can delay and successfully generate an ETag to the end of the last async dispatch. If using Spring Framework’s AbstractAnnotationConfigDispatcherServletInitializer (see Servlet Config) all filters are automatically registered for all dispatch types. However if registering the filter via web.xml or in Spring Boot via a FilterRegistrationBean be sure to include DispatcherType.ASYNC.spring-doc.cn
CORS
Spring MVC provides fine-grained support for CORS configuration through annotations on controllers. However, when used with Spring Security, we advise relying on the built-in CorsFilter that must be ordered ahead of Spring Security’s chain of filters.spring-doc.cn
See the sections on CORS and the CORS Filter for more details.spring-doc.cn
