For the latest stable version, please use Spring Framework 6.2.6!spring-doc.cn
Type Conversion
By default, formatters for various number and date types are installed, along with support for customization via @NumberFormat and @DateTimeFormat on fields.spring-doc.cn
To register custom formatters and converters in Java config, use the following:spring-doc.cn
@EnableWebMvc
	public void addFormatters(FormatterRegistry registry) {
@EnableWebMvc
	override fun addFormatters(registry: FormatterRegistry) {
To do the same in XML config, use the following:spring-doc.cn
	xmlns:mvc="http://www.springframework.org/schema/mvc"
	xsi:schemaLocation="
		https://www.springframework.org/schema/mvc/spring-mvc.xsd">
	<mvc:annotation-driven conversion-service="conversionService"/>
	<bean id="conversionService"
			class="org.springframework.format.support.FormattingConversionServiceFactoryBean">
		<property name="converters">
			<set>
				<bean class="org.example.MyConverter"/>
			</set>
		</property>
		<property name="formatters">
			<set>
				<bean class="org.example.MyFormatter"/>
				<bean class="org.example.MyAnnotationFormatterFactory"/>
			</set>
		</property>
		<property name="formatterRegistrars">
			<set>
				<bean class="org.example.MyFormatterRegistrar"/>
			</set>
		</property>
	</bean>
</beans>
By default Spring MVC considers the request Locale when parsing and formatting date values. This works for forms where dates are represented as Strings with "input" form fields. For "date" and "time" form fields, however, browsers use a fixed format defined in the HTML spec. For such cases date and time formatting can be customized as follows:spring-doc.cn
@EnableWebMvc
		DateTimeFormatterRegistrar registrar = new DateTimeFormatterRegistrar();
		registrar.setUseIsoFormat(true);
		registrar.registerFormatters(registry);
@EnableWebMvc
		val registrar = DateTimeFormatterRegistrar()
See the FormatterRegistrar SPI and the FormattingConversionServiceFactoryBean for more information on when to use FormatterRegistrar implementations.
