For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Properties, Arrays, Lists, Maps, and Indexers
Navigating with property references is easy. To do so, use a period to indicate a nested property value. The instances of the Inventor class, pupin and tesla, were populated with data listed in the Classes used in the examples section. To navigate "down" the object graph and get Tesla’s year of birth and Pupin’s city of birth, we use the following expressions:spring-doc.cn
// evaluates to 1856
int year = (Integer) parser.parseExpression("birthdate.year + 1900").getValue(context);
String city = (String) parser.parseExpression("placeOfBirth.city").getValue(context);
val year = parser.parseExpression("birthdate.year + 1900").getValue(context) as Int
val city = parser.parseExpression("placeOfBirth.city").getValue(context) as String
Case insensitivity is allowed for the first letter of property names. Thus, the expressions in the above example may be written as Birthdate.Year + 1900 and PlaceOfBirth.City, respectively. In addition, properties may optionally be accessed via method invocations — for example, getPlaceOfBirth().getCity() instead of placeOfBirth.city.spring-doc.cn
The contents of arrays and lists are obtained by using square bracket notation, as the following example shows:spring-doc.cn
ExpressionParser parser = new SpelExpressionParser();
EvaluationContext context = SimpleEvaluationContext.forReadOnlyDataBinding().build();
// Inventions Array
// evaluates to "Induction motor"
String invention = parser.parseExpression("inventions[3]").getValue(
		context, tesla, String.class);
// Members List
// evaluates to "Nikola Tesla"
String name = parser.parseExpression("members[0].name").getValue(
		context, ieee, String.class);
// List and Array navigation
// evaluates to "Wireless communication"
String invention = parser.parseExpression("members[0].inventions[6]").getValue(
val parser = SpelExpressionParser()
val context = SimpleEvaluationContext.forReadOnlyDataBinding().build()
// Inventions Array
val invention = parser.parseExpression("inventions[3]").getValue(
		context, tesla, String::class.java)
// Members List
val name = parser.parseExpression("members[0].name").getValue(
		context, ieee, String::class.java)
val invention = parser.parseExpression("members[0].inventions[6]").getValue(
The contents of maps are obtained by specifying the literal key value within the brackets. In the following example, because keys for the officers map are strings, we can specify string literals:spring-doc.cn
// Officer's Dictionary
Inventor pupin = parser.parseExpression("officers['president']").getValue(
		societyContext, Inventor.class);
// evaluates to "Idvor"
String city = parser.parseExpression("officers['president'].placeOfBirth.city").getValue(
		societyContext, String.class);
// setting values
parser.parseExpression("officers['advisors'][0].placeOfBirth.country").setValue(
		societyContext, "Croatia");
val pupin = parser.parseExpression("officers['president']").getValue(
		societyContext, Inventor::class.java)
val city = parser.parseExpression("officers['president'].placeOfBirth.city").getValue(
		societyContext, String::class.java)
// setting values
