For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
WebFlux Config
The WebFlux Java configuration declares the components that are required to process requests with annotated controllers or functional endpoints, and it offers an API to customize the configuration. That means you do not need to understand the underlying beans created by the Java configuration. However, if you want to understand them, you can see them in WebFluxConfigurationSupport or read more about what they are in Special Bean Types.spring-doc.cn
For more advanced customizations, not available in the configuration API, you can gain full control over the configuration through the Advanced Configuration Mode.spring-doc.cn
Enabling WebFlux Config
You can use the @EnableWebFlux annotation in your Java config, as the following example shows:spring-doc.cn
@EnableWebFlux
public class WebConfig {
@EnableWebFlux
class WebConfig
The preceding example registers a number of Spring WebFlux infrastructure beans and adapts to dependencies available on the classpath — for JSON, XML, and others.spring-doc.cn
WebFlux config API
In your Java configuration, you can implement the WebFluxConfigurer interface, as the following example shows:spring-doc.cn
@EnableWebFlux
public class WebConfig implements WebFluxConfigurer {
	// Implement configuration methods...
@EnableWebFlux
class WebConfig : WebFluxConfigurer {
Conversion, formatting
By default, formatters for various number and date types are installed, along with support for customization via @NumberFormat and @DateTimeFormat on fields.spring-doc.cn
To register custom formatters and converters in Java config, use the following:spring-doc.cn
@EnableWebFlux
	public void addFormatters(FormatterRegistry registry) {
@EnableWebFlux
	override fun addFormatters(registry: FormatterRegistry) {
By default Spring WebFlux considers the request Locale when parsing and formatting date values. This works for forms where dates are represented as Strings with "input" form fields. For "date" and "time" form fields, however, browsers use a fixed format defined in the HTML spec. For such cases date and time formatting can be customized as follows:spring-doc.cn
@EnableWebFlux
		DateTimeFormatterRegistrar registrar = new DateTimeFormatterRegistrar();
		registrar.setUseIsoFormat(true);
		registrar.registerFormatters(registry);
@EnableWebFlux
		val registrar = DateTimeFormatterRegistrar()
See FormatterRegistrar SPI and the FormattingConversionServiceFactoryBean for more information on when to use FormatterRegistrar implementations.
Validation
By default, if Bean Validation is present on the classpath (for example, the Hibernate Validator), the LocalValidatorFactoryBean is registered as a global validator for use with @Valid and @Validated on @Controller method arguments.spring-doc.cn
In your Java configuration, you can customize the global Validator instance, as the following example shows:spring-doc.cn
@EnableWebFlux
	public Validator getValidator() {
@EnableWebFlux
	override fun getValidator(): Validator {
Note that you can also register Validator implementations locally, as the following example shows:spring-doc.cn
@Controller
public class MyController {
	@InitBinder
	protected void initBinder(WebDataBinder binder) {
		binder.addValidators(new FooValidator());
@Controller
	@InitBinder
	protected fun initBinder(binder: WebDataBinder) {
		binder.addValidators(FooValidator())
If you need to have a LocalValidatorFactoryBean injected somewhere, create a bean and mark it with @Primary in order to avoid conflict with the one declared in the MVC config.
Content Type Resolvers
You can configure how Spring WebFlux determines the requested media types for @Controller instances from the request. By default, only the Accept header is checked, but you can also enable a query parameter-based strategy.spring-doc.cn
The following example shows how to customize the requested content type resolution:spring-doc.cn
@EnableWebFlux
	public void configureContentTypeResolver(RequestedContentTypeResolverBuilder builder) {
@EnableWebFlux
	override fun configureContentTypeResolver(builder: RequestedContentTypeResolverBuilder) {
HTTP message codecs
The following example shows how to customize how the request and response body are read and written:spring-doc.cn
@EnableWebFlux
	public void configureHttpMessageCodecs(ServerCodecConfigurer configurer) {
		configurer.defaultCodecs().maxInMemorySize(512 * 1024);
@EnableWebFlux
	override fun configureHttpMessageCodecs(configurer: ServerCodecConfigurer) {
ServerCodecConfigurer provides a set of default readers and writers. You can use it to add more readers and writers, customize the default ones, or replace the default ones completely.spring-doc.cn
For Jackson JSON and XML, consider using Jackson2ObjectMapperBuilder, which customizes Jackson’s default properties with the following ones:spring-doc.cn
It also automatically registers the following well-known modules if they are detected on the classpath:spring-doc.cn
View Resolvers
The following example shows how to configure view resolution:spring-doc.cn
@EnableWebFlux
	public void configureViewResolvers(ViewResolverRegistry registry) {
@EnableWebFlux
	override fun configureViewResolvers(registry: ViewResolverRegistry) {
The ViewResolverRegistry has shortcuts for view technologies with which the Spring Framework integrates. The following example uses FreeMarker (which also requires configuring the underlying FreeMarker view technology):spring-doc.cn
@EnableWebFlux
		registry.freeMarker();
	// Configure Freemarker...
	public FreeMarkerConfigurer freeMarkerConfigurer() {
		FreeMarkerConfigurer configurer = new FreeMarkerConfigurer();
		configurer.setTemplateLoaderPath("classpath:/templates");
		return configurer;
@EnableWebFlux
	fun freeMarkerConfigurer() = FreeMarkerConfigurer().apply {
You can also plug in any ViewResolver implementation, as the following example shows:spring-doc.cn
@EnableWebFlux
		ViewResolver resolver = ... ;
		registry.viewResolver(resolver);
@EnableWebFlux
		val resolver: ViewResolver = ...
To support Content Negotiation and rendering other formats through view resolution (besides HTML), you can configure one or more default views based on the HttpMessageWriterView implementation, which accepts any of the available Codecs from spring-web. The following example shows how to do so:spring-doc.cn
@EnableWebFlux
		Jackson2JsonEncoder encoder = new Jackson2JsonEncoder();
		registry.defaultViews(new HttpMessageWriterView(encoder));
@EnableWebFlux
		val encoder = Jackson2JsonEncoder()
		registry.defaultViews(HttpMessageWriterView(encoder))
See View Technologies for more on the view technologies that are integrated with Spring WebFlux.spring-doc.cn
Static Resources
This option provides a convenient way to serve static resources from a list of Resource-based locations.spring-doc.cn
In the next example, given a request that starts with /resources, the relative path is used to find and serve static resources relative to /static on the classpath. Resources are served with a one-year future expiration to ensure maximum use of the browser cache and a reduction in HTTP requests made by the browser. The Last-Modified header is also evaluated and, if present, a 304 status code is returned. The following listing shows the example:spring-doc.cn
@EnableWebFlux
	public void addResourceHandlers(ResourceHandlerRegistry registry) {
		registry.addResourceHandler("/resources/**")
				.addResourceLocations("/public", "classpath:/static/")
				.setCacheControl(CacheControl.maxAge(365, TimeUnit.DAYS));
@EnableWebFlux
	override fun addResourceHandlers(registry: ResourceHandlerRegistry) {
The resource handler also supports a chain of ResourceResolver implementations and ResourceTransformer implementations, which can be used to create a toolchain for working with optimized resources.spring-doc.cn
You can use the VersionResourceResolver for versioned resource URLs based on an MD5 hash computed from the content, a fixed application version, or other information. A ContentVersionStrategy (MD5 hash) is a good choice with some notable exceptions (such as JavaScript resources used with a module loader).spring-doc.cn
The following example shows how to use VersionResourceResolver in your Java configuration:spring-doc.cn
@EnableWebFlux
				.addResourceLocations("/public/")
				.resourceChain(true)
				.addResolver(new VersionResourceResolver().addContentVersionStrategy("/**"));
@EnableWebFlux
				.addResolver(VersionResourceResolver().addContentVersionStrategy("/**"))
You can use ResourceUrlProvider to rewrite URLs and apply the full chain of resolvers and transformers (for example, to insert versions). The WebFlux configuration provides a ResourceUrlProvider so that it can be injected into others.spring-doc.cn
Unlike Spring MVC, at present, in WebFlux, there is no way to transparently rewrite static resource URLs, since there are no view technologies that can make use of a non-blocking chain of resolvers and transformers. When serving only local resources, the workaround is to use ResourceUrlProvider directly (for example, through a custom element) and block.spring-doc.cn
Note that, when using both EncodedResourceResolver (for example, Gzip, Brotli encoded) and VersionedResourceResolver, they must be registered in that order, to ensure content-based versions are always computed reliably based on the unencoded file.spring-doc.cn
For WebJars, versioned URLs like /webjars/jquery/1.2.0/jquery.min.js are the recommended and most efficient way to use them. The related resource location is configured out of the box with Spring Boot (or can be configured manually via ResourceHandlerRegistry) and does not require to add the org.webjars:webjars-locator-core dependency.spring-doc.cn
Version-less URLs like /webjars/jquery/jquery.min.js are supported through the WebJarsResourceResolver which is automatically registered when the org.webjars:webjars-locator-core library is present on the classpath, at the cost of a classpath scanning that could slow down application startup. The resolver can re-write URLs to include the version of the jar and can also match against incoming URLs without versions — for example, from /webjars/jquery/jquery.min.js to /webjars/jquery/1.2.0/jquery.min.js.spring-doc.cn
The Java configuration based on ResourceHandlerRegistry provides further options for fine-grained control, e.g. last-modified behavior and optimized resource resolution.
Path Matching
You can customize options related to path matching. For details on the individual options, see the PathMatchConfigurer javadoc. The following example shows how to use PathMatchConfigurer:spring-doc.cn
@EnableWebFlux
	public void configurePathMatch(PathMatchConfigurer configurer) {
		configurer
			.setUseCaseSensitiveMatch(true)
			.addPathPrefix("/api", HandlerTypePredicate.forAnnotation(RestController.class));
@EnableWebFlux
	fun configurePathMatch(configurer: PathMatchConfigurer) {
		configurer
			.addPathPrefix("/api", HandlerTypePredicate.forAnnotation(RestController::class.java))
Spring WebFlux relies on a parsed representation of the request path called RequestPath for access to decoded path segment values, with semicolon content removed (that is, path or matrix variables). That means, unlike in Spring MVC, you need not indicate whether to decode the request path nor whether to remove semicolon content for path matching purposes.spring-doc.cn
Spring WebFlux also does not support suffix pattern matching, unlike in Spring MVC, where we are also recommend moving away from reliance on it.spring-doc.cn
WebSocketService
The WebFlux Java config declares of a WebSocketHandlerAdapter bean which provides support for the invocation of WebSocket handlers. That means all that remains to do in order to handle a WebSocket handshake request is to map a WebSocketHandler to a URL via SimpleUrlHandlerMapping.spring-doc.cn
In some cases it may be necessary to create the WebSocketHandlerAdapter bean with a provided WebSocketService service which allows configuring WebSocket server properties. For example:spring-doc.cn
@EnableWebFlux
	public WebSocketService getWebSocketService() {
		TomcatRequestUpgradeStrategy strategy = new TomcatRequestUpgradeStrategy();
		strategy.setMaxSessionIdleTimeout(0L);
		return new HandshakeWebSocketService(strategy);
@EnableWebFlux
	fun webSocketService(): WebSocketService {
		val strategy = TomcatRequestUpgradeStrategy().apply {
		return HandshakeWebSocketService(strategy)
@EnableWebFlux imports DelegatingWebFluxConfiguration that:spring-doc.cn
  • Provides default Spring configuration for WebFlux applicationsspring-doc.cn
  • detects and delegates to WebFluxConfigurer implementations to customize that configuration.spring-doc.cn
For advanced mode, you can remove @EnableWebFlux and extend directly from DelegatingWebFluxConfiguration instead of implementing WebFluxConfigurer, as the following example shows:spring-doc.cn
public class WebConfig extends DelegatingWebFluxConfiguration {
class WebConfig : DelegatingWebFluxConfiguration {
You can keep existing methods in WebConfig, but you can now also override bean declarations from the base class and still have any number of other WebMvcConfigurer implementations on the classpath.spring-doc.cn
