For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Order of Messages
Messages from the broker are published to the clientOutboundChannel, from where they are written to WebSocket sessions. As the channel is backed by a ThreadPoolExecutor, messages are processed in different threads, and the resulting sequence received by the client may not match the exact order of publication.spring-doc.cn
If this is an issue, enable the setPreservePublishOrder flag, as the following example shows:spring-doc.cn
@EnableWebSocketMessageBroker
public class MyConfig implements WebSocketMessageBrokerConfigurer {
	protected void configureMessageBroker(MessageBrokerRegistry registry) {
		registry.setPreservePublishOrder(true);
The following example shows the XML configuration equivalent of the preceding example:spring-doc.cn
	xmlns:websocket="http://www.springframework.org/schema/websocket"
	xsi:schemaLocation="
		https://www.springframework.org/schema/websocket/spring-websocket.xsd">
	<websocket:message-broker preserve-publish-order="true">
	</websocket:message-broker>
</beans>
When the flag is set, messages within the same client session are published to the clientOutboundChannel one at a time, so that the order of publication is guaranteed. Note that this incurs a small performance overhead, so you should enable it only if it is required.spring-doc.cn
