For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
Advanced XML Config
The MVC namespace does not have an advanced mode. If you need to customize a property on a bean that you cannot change otherwise, you can use the BeanPostProcessor lifecycle hook of the Spring ApplicationContext, as the following example shows:spring-doc.cn
@Component
public class MyPostProcessor implements BeanPostProcessor {
	public Object postProcessBeforeInitialization(Object bean, String name) throws BeansException {
@Component
class MyPostProcessor : BeanPostProcessor {
	override fun postProcessBeforeInitialization(bean: Any, name: String): Any {
Note that you need to declare MyPostProcessor as a bean, either explicitly in XML or by letting it be detected through a <component-scan/> declaration.spring-doc.cn
