For the latest stable version, please use Spring Framework 6.2.4! |
Processing
The DispatcherServlet
processes requests as follows:
The
WebApplicationContext
is searched for and bound in the request as an attribute that the controller and other elements in the process can use. It is bound by default under theDispatcherServlet.WEB_APPLICATION_CONTEXT_ATTRIBUTE
key. -
The locale resolver is bound to the request to let elements in the process resolve the locale to use when processing the request (rendering the view, preparing data, and so on). If you do not need locale resolving, you do not need the locale resolver.
The theme resolver is bound to the request to let elements such as views determine which theme to use. If you do not use themes, you can ignore it.
If you specify a multipart file resolver, the request is inspected for multiparts. If multiparts are found, the request is wrapped in a
MultipartHttpServletRequest
for further processing by other elements in the process. See Multipart Resolver for further information about multipart handling. -
An appropriate handler is searched for. If a handler is found, the execution chain associated with the handler (preprocessors, postprocessors, and controllers) is run to prepare a model for rendering. Alternatively, for annotated controllers, the response can be rendered (within the
HandlerAdapter
) instead of returning a view. -
If a model is returned, the view is rendered. If no model is returned (maybe due to a preprocessor or postprocessor intercepting the request, perhaps for security reasons), no view is rendered, because the request could already have been fulfilled.
The HandlerExceptionResolver
beans declared in the WebApplicationContext
are used to
resolve exceptions thrown during request processing. Those exception resolvers allow
customizing the logic to address exceptions. See Exceptions for more details.
For HTTP caching support, handlers can use the checkNotModified
methods of WebRequest
along with further options for annotated controllers as described in
HTTP Caching for Controllers.
You can customize individual DispatcherServlet
instances by adding Servlet
initialization parameters (init-param
elements) to the Servlet declaration in the
web.xml
file. The following table lists the supported parameters:
Parameter | Explanation |
Class that implements |
String that is passed to the context instance (specified by |
Namespace of the |
Whether to throw a By default, this is set to Note that, if default servlet handling is also configured, unresolved requests are always forwarded to the default servlet and a 404 is never raised. |
