For the latest stable version, please use Spring Framework 6.2.4! |
Literal Expressions
SpEL supports the following types of literal expressions.
strings
numeric values: integer (
int
orlong
), hexadecimal (int
orlong
), real (float
ordouble
boolean values:
true
orfalse
null
Strings can delimited by single quotation marks ('
) or double quotation marks ("
). To
include a single quotation mark within a string literal enclosed in single quotation
marks, use two adjacent single quotation mark characters. Similarly, to include a double
quotation mark within a string literal enclosed in double quotation marks, use two
adjacent double quotation mark characters.
Numbers support the use of the negative sign, exponential notation, and decimal points.
By default, real numbers are parsed by using Double.parseDouble()
The following listing shows simple usage of literals. Typically, they are not used in isolation like this but, rather, as part of a more complex expression — for example, using a literal on one side of a logical comparison operator or as an argument to a method.
Java
Kotlin
ExpressionParser parser = new SpelExpressionParser();
// evaluates to "Hello World"
String helloWorld = (String) parser.parseExpression("'Hello World'").getValue();
// evaluates to "Tony's Pizza"
String pizzaParlor = (String) parser.parseExpression("'Tony''s Pizza'").getValue();
double avogadrosNumber = (Double) parser.parseExpression("6.0221415E+23").getValue();
// evaluates to 2147483647
int maxValue = (Integer) parser.parseExpression("0x7FFFFFFF").getValue();
boolean trueValue = (Boolean) parser.parseExpression("true").getValue();
Object nullValue = parser.parseExpression("null").getValue();
val parser = SpelExpressionParser()
val helloWorld = parser.parseExpression("'Hello World'").value as String
val pizzaParlor = parser.parseExpression("'Tony''s Pizza'").value as String
val avogadrosNumber = parser.parseExpression("6.0221415E+23").value as Double
val maxValue = parser.parseExpression("0x7FFFFFFF").value as Int
val trueValue = parser.parseExpression("true").value as Boolean
val nullValue = parser.parseExpression("null").value
