For the latest stable version, please use Spring Framework 6.2.4! |
Functional Endpoints
Spring Web MVC includes WebMvc.fn, a lightweight functional programming model in which functions are used to route and handle requests and contracts are designed for immutability. It is an alternative to the annotation-based programming model but otherwise runs on the same DispatcherServlet.
Overview
In WebMvc.fn, an HTTP request is handled with a HandlerFunction
: a function that takes
ServerRequest
and returns a ServerResponse
Both the request and the response object have immutable contracts that offer JDK 8-friendly
access to the HTTP request and response.
HandlerFunction
is the equivalent of the body of a @RequestMapping
method in the
annotation-based programming model.
Incoming requests are routed to a handler function with a RouterFunction
: a function that
takes ServerRequest
and returns an optional HandlerFunction
(i.e. Optional<HandlerFunction>
When the router function matches, a handler function is returned; otherwise an empty Optional.
RouterFunction
is the equivalent of a @RequestMapping
annotation, but with the major
difference that router functions provide not just data, but also behavior.
RouterFunctions.route()
provides a router builder that facilitates the creation of routers,
as the following example shows:
Java
Kotlin
import static org.springframework.http.MediaType.APPLICATION_JSON;
import static org.springframework.web.servlet.function.RequestPredicates.*;
import static org.springframework.web.servlet.function.RouterFunctions.route;
PersonRepository repository = ...
PersonHandler handler = new PersonHandler(repository);
RouterFunction<ServerResponse> route = route() (1)
.GET("/person/{id}", accept(APPLICATION_JSON), handler::getPerson)
.GET("/person", accept(APPLICATION_JSON), handler::listPeople)
.POST("/person", handler::createPerson)
public class PersonHandler {
public ServerResponse listPeople(ServerRequest request) {
public ServerResponse createPerson(ServerRequest request) {
public ServerResponse getPerson(ServerRequest request) {
1 | Create router using route() . |
import org.springframework.web.servlet.function.router
val repository: PersonRepository = ...
val handler = PersonHandler(repository)
val route = router { (1)
accept(APPLICATION_JSON).nest {
GET("/person/{id}", handler::getPerson)
GET("/person", handler::listPeople)
class PersonHandler(private val repository: PersonRepository) {
fun listPeople(request: ServerRequest): ServerResponse {
fun createPerson(request: ServerRequest): ServerResponse {
fun getPerson(request: ServerRequest): ServerResponse {
1 | Create router using the router DSL. |
If you register the RouterFunction
as a bean, for instance by exposing it in a
class, it will be auto-detected by the servlet, as explained in Running a Server.
HandlerFunction
ServerRequest
and ServerResponse
are immutable interfaces that offer JDK 8-friendly
access to the HTTP request and response, including headers, body, method, and status code.
ServerRequest
ServerRequest
provides access to the HTTP method, URI, headers, and query parameters,
while access to the body is provided through the body
methods.
The following example extracts the request body to a String
Java
Kotlin
String string = request.body(String.class);
val string = request.body<String>()
The following example extracts the body to a List<Person>
where Person
objects are decoded from a serialized form, such as JSON or XML:
Java
Kotlin
List<Person> people = request.body(new ParameterizedTypeReference<List<Person>>() {});
val people = request.body<Person>()
The following example shows how to access parameters:
Java
Kotlin
MultiValueMap<String, String> params = request.params();
val map = request.params()
ServerResponse
ServerResponse
provides access to the HTTP response and, since it is immutable, you can use
a build
method to create it. You can use the builder to set the response status, to add response
headers, or to provide a body. The following example creates a 200 (OK) response with JSON
content:
Java
Kotlin
Person person = ...
ServerResponse.ok().contentType(MediaType.APPLICATION_JSON).body(person);
val person: Person = ...
The following example shows how to build a 201 (CREATED) response with a Location
header and no body:
Java
Kotlin
URI location = ...
ServerResponse.created(location).build();
val location: URI = ...
You can also use an asynchronous result as the body, in the form of a CompletableFuture
Publisher
, or any other type supported by the ReactiveAdapterRegistry
. For instance:
Java
Kotlin
Mono<Person> person = webClient.get().retrieve().bodyToMono(Person.class);
val person = webClient.get().retrieve().awaitBody<Person>()
If not just the body, but also the status or headers are based on an asynchronous type,
you can use the static async
method on ServerResponse
, which
accepts CompletableFuture<ServerResponse>
, Publisher<ServerResponse>
, or
any other asynchronous type supported by the ReactiveAdapterRegistry
. For instance:
Java
Mono<ServerResponse> asyncResponse = webClient.get().retrieve().bodyToMono(Person.class)
.map(p -> ServerResponse.ok().header("Name", p.name()).body(p));
ServerResponse.async(asyncResponse);
Server-Sent Events can be provided via the
static sse
. The builder provided by that method
allows you to send Strings, or other objects as JSON. For example:
Java
Kotlin
public RouterFunction<ServerResponse> sse() {
return route(GET("/sse"), request -> ServerResponse.sse(sseBuilder -> {
// Save the sseBuilder object somewhere..
// In some other thread, sending a String
sseBuilder.send("Hello world");
// Or an object, which will be transformed into JSON
Person person = ...
sseBuilder.send(person);
// Customize the event by using the other methods
sseBuilder.id("42")
.event("sse event")
.data(person);
// and done at some point
sseBuilder.complete();
fun sse(): RouterFunction<ServerResponse> = router {
GET("/sse") { request -> ServerResponse.sse { sseBuilder ->
val person = ...
sseBuilder.id("42")
.event("sse event")
.data(person)
Handler Classes
We can write a handler function as a lambda, as the following example shows:
Java
Kotlin
HandlerFunction<ServerResponse> helloWorld =
request -> ServerResponse.ok().body("Hello World");
val helloWorld: (ServerRequest) -> ServerResponse =
{ ServerResponse.ok().body("Hello World") }
That is convenient, but in an application we need multiple functions, and multiple inline
lambda’s can get messy.
Therefore, it is useful to group related handler functions together into a handler class, which
has a similar role as @Controller
in an annotation-based application.
For example, the following class exposes a reactive Person
repository:
Java
Kotlin
import static org.springframework.web.reactive.function.server.ServerResponse.ok;
private final PersonRepository repository;
public PersonHandler(PersonRepository repository) {
this.repository = repository;
public ServerResponse listPeople(ServerRequest request) { (1)
List<Person> people = repository.allPeople();
return ok().contentType(APPLICATION_JSON).body(people);
public ServerResponse createPerson(ServerRequest request) throws Exception { (2)
Person person = request.body(Person.class);
repository.savePerson(person);
return ok().build();
public ServerResponse getPerson(ServerRequest request) { (3)
int personId = Integer.parseInt(request.pathVariable("id"));
Person person = repository.getPerson(personId);
if (person != null) {
return ok().contentType(APPLICATION_JSON).body(person);
else {
return ServerResponse.notFound().build();
1 | listPeople is a handler function that returns all Person objects found in the repository as
JSON. |
2 | createPerson is a handler function that stores a new Person contained in the request body. |
3 | getPerson is a handler function that returns a single person, identified by the id path
variable. We retrieve that Person from the repository and create a JSON response, if it is
found. If it is not found, we return a 404 Not Found response. |
fun listPeople(request: ServerRequest): ServerResponse { (1)
val people: List<Person> = repository.allPeople()
fun createPerson(request: ServerRequest): ServerResponse { (2)
val person = request.body<Person>()
return ok().build()
fun getPerson(request: ServerRequest): ServerResponse { (3)
val personId = request.pathVariable("id").toInt()
return repository.getPerson(personId)?.let { ok().contentType(APPLICATION_JSON).body(it) }
?: ServerResponse.notFound().build()
JSON. |
Validation
A functional endpoint can use Spring’s validation facilities to
apply validation to the request body. For example, given a custom Spring
Validator implementation for a Person
Java
Kotlin
private final Validator validator = new PersonValidator(); (1)
validate(person); (2)
private void validate(Person person) {
Errors errors = new BeanPropertyBindingResult(person, "person");
validator.validate(person, errors);
if (errors.hasErrors()) {
throw new ServerWebInputException(errors.toString()); (3)
1 | Create Validator instance. |
2 | Apply validation. |
3 | Raise exception for a 400 response. |
private val validator = PersonValidator() (1)
validate(person) (2)
return ok().build()
private fun validate(person: Person) {
val errors: Errors = BeanPropertyBindingResult(person, "person")
throw ServerWebInputException(errors.toString()) (3)
Handlers can also use the standard bean validation API (JSR-303) by creating and injecting
a global Validator
instance based on LocalValidatorFactoryBean
See Spring Validation.
RouterFunction
Router functions are used to route the requests to the corresponding HandlerFunction
Typically, you do not write router functions yourself, but rather use a method on the
RouterFunctions
utility class to create one.
(no parameters) provides you with a fluent builder for creating a router
function, whereas RouterFunctions.route(RequestPredicate, HandlerFunction)
offers a direct way
to create a router.
Generally, it is recommended to use the route()
builder, as it provides
convenient short-cuts for typical mapping scenarios without requiring hard-to-discover
static imports.
For instance, the router function builder offers the method GET(String, HandlerFunction)
to create a mapping for GET requests; and POST(String, HandlerFunction)
for POSTs.
Besides HTTP method-based mapping, the route builder offers a way to introduce additional
predicates when mapping to requests.
For each HTTP method there is an overloaded variant that takes a RequestPredicate
as a
parameter, through which additional constraints can be expressed.
Predicates
You can write your own RequestPredicate
, but the RequestPredicates
utility class
offers commonly used implementations, based on the request path, HTTP method, content-type,
and so on.
The following example uses a request predicate to create a constraint based on the Accept
header:
Java
Kotlin
RouterFunction<ServerResponse> route = RouterFunctions.route()
.GET("/hello-world", accept(MediaType.TEXT_PLAIN),
request -> ServerResponse.ok().body("Hello World")).build();
GET("/hello-world", accept(TEXT_PLAIN)) {
You can compose multiple request predicates together by using:
RequestPredicate.and(RequestPredicate)
— both must match. -
RequestPredicate.or(RequestPredicate)
— either can match.
Many of the predicates from RequestPredicates
are composed.
For example, RequestPredicates.GET(String)
is composed from RequestPredicates.method(HttpMethod)
and RequestPredicates.path(String)
The example shown above also uses two request predicates, as the builder uses
internally, and composes that with the accept
predicate.
Routes
Router functions are evaluated in order: if the first route does not match, the second is evaluated, and so on. Therefore, it makes sense to declare more specific routes before general ones. This is also important when registering router functions as Spring beans, as will be described later. Note that this behavior is different from the annotation-based programming model, where the "most specific" controller method is picked automatically.
When using the router function builder, all defined routes are composed into one
RouterFunction
that is returned from build()
There are also other ways to compose multiple router functions together:
add(RouterFunction)
on theRouterFunctions.route()
builder -
RouterFunction.and(RouterFunction)
RouterFunction.andRoute(RequestPredicate, HandlerFunction)
— shortcut forRouterFunction.and()
with nestedRouterFunctions.route()
The following example shows the composition of four routes:
Java
Kotlin
RouterFunction<ServerResponse> otherRoute = ...
.GET("/person/{id}", accept(APPLICATION_JSON), handler::getPerson) (1)
.GET("/person", accept(APPLICATION_JSON), handler::listPeople) (2)
.POST("/person", handler::createPerson) (3)
.add(otherRoute) (4)
1 | GET /person/{id} with an Accept header that matches JSON is routed to
PersonHandler.getPerson |
2 | GET /person with an Accept header that matches JSON is routed to
PersonHandler.listPeople |
3 | POST /person with no additional predicates is mapped to
PersonHandler.createPerson , and |
4 | otherRoute is a router function that is created elsewhere, and added to the route built. |
import org.springframework.http.MediaType.APPLICATION_JSON
val handler = PersonHandler(repository);
val otherRoute = router { }
}.and(otherRoute) (4)
Nested Routes
It is common for a group of router functions to have a shared predicate, for instance a shared
path.
In the example above, the shared predicate would be a path predicate that matches /person
used by three of the routes.
When using annotations, you would remove this duplication by using a type-level @RequestMapping
annotation that maps to /person
In WebMvc.fn, path predicates can be shared through the path
method on the router function builder.
For instance, the last few lines of the example above can be improved in the following way by using nested routes:
Java
Kotlin
.path("/person", builder -> builder (1)
.GET("/{id}", accept(APPLICATION_JSON), handler::getPerson)
.GET(accept(APPLICATION_JSON), handler::listPeople)
.POST(handler::createPerson))
1 | Note that second parameter of path is a consumer that takes the router builder. |
"/person".nest { (1)
1 | Using nest DSL. |
Though path-based nesting is the most common, you can nest on any kind of predicate by using
the nest
method on the builder.
The above still contains some duplication in the form of the shared Accept
-header predicate.
We can further improve by using the nest
method together with accept
Java
Kotlin
.path("/person", b1 -> b1
.nest(accept(APPLICATION_JSON), b2 -> b2
.GET("/{id}", handler::getPerson)
.GET(handler::listPeople))
"/person".nest {
GET("", handler::listPeople)
Running a Server
You typically run router functions in a DispatcherHandler
-based setup through the
MVC Config, which uses Spring configuration to declare the
components required to process requests. The MVC Java configuration declares the following
infrastructure components to support functional endpoints:
RouterFunctionMapping
: Detects one or moreRouterFunction<?>
beans in the Spring configuration, orders them, combines them throughRouterFunction.andOther
, and routes requests to the resulting composedRouterFunction
HandlerFunctionAdapter
: Simple adapter that letsDispatcherHandler
invoke aHandlerFunction
that was mapped to a request.
The preceding components let functional endpoints fit within the DispatcherServlet
request
processing lifecycle and also (potentially) run side by side with annotated controllers, if
any are declared. It is also how functional endpoints are enabled by the Spring Boot Web
starter.
The following example shows a WebFlux Java configuration:
Java
Kotlin
@EnableMvc
public RouterFunction<?> routerFunctionA() {
public RouterFunction<?> routerFunctionB() {
public void configureMessageConverters(List<HttpMessageConverter<?>> converters) {
// configure message conversion...
public void addCorsMappings(CorsRegistry registry) {
// configure CORS...
public void configureViewResolvers(ViewResolverRegistry registry) {
// configure view resolution for HTML rendering...
@EnableMvc
fun routerFunctionA(): RouterFunction<*> {
fun routerFunctionB(): RouterFunction<*> {
override fun configureMessageConverters(converters: List<HttpMessageConverter<*>>) {
override fun addCorsMappings(registry: CorsRegistry) {
override fun configureViewResolvers(registry: ViewResolverRegistry) {
Filtering Handler Functions
You can filter handler functions by using the before
, after
, or filter
methods on the routing
function builder.
With annotations, you can achieve similar functionality by using @ControllerAdvice
, a ServletFilter
, or both.
The filter will apply to all routes that are built by the builder.
This means that filters defined in nested routes do not apply to "top-level" routes.
For instance, consider the following example:
Java
Kotlin
.before(request -> ServerRequest.from(request) (1)
.header("X-RequestHeader", "Value")
.build()))
.after((request, response) -> logResponse(response)) (2)
1 | The before filter that adds a custom request header is only applied to the two GET routes. |
2 | The after filter that logs the response is applied to all routes, including the nested ones. |
"/person".nest {
before { (1)
ServerRequest.from(it)
.header("X-RequestHeader", "Value").build()
after { _, response -> (2)
The filter
method on the router builder takes a HandlerFilterFunction
: a
function that takes a ServerRequest
and HandlerFunction
The handler function parameter represents the next element in the chain.
This is typically the handler that is routed to, but it can also be another
filter if multiple are applied.
Now we can add a simple security filter to our route, assuming that we have a SecurityManager
that
can determine whether a particular path is allowed.
The following example shows how to do so:
Java
Kotlin
SecurityManager securityManager = ...
.filter((request, next) -> {
if (securityManager.allowAccessTo(request.path())) {
return next.handle(request);
else {
return ServerResponse.status(UNAUTHORIZED).build();
val securityManager: SecurityManager = ...
("/person" and accept(APPLICATION_JSON)).nest {
filter { request, next ->
next(request)
else {
The preceding example demonstrates that invoking the next.handle(ServerRequest)
is optional.
We only let the handler function be run when access is allowed.
Besides using the filter
method on the router function builder, it is possible to apply a
filter to an existing router function via RouterFunction.filter(HandlerFilterFunction)
CORS support for functional endpoints is provided through a dedicated
CorsFilter .
