For the latest stable version, please use Spring Framework 6.2.6!spring-doc.cn
Context Configuration with Test Property Sources
The Spring Framework has first-class support for the notion of an environment with a hierarchy of property sources, and you can configure integration tests with test-specific property sources. In contrast to the @PropertySource annotation used on @Configuration classes, you can declare the @TestPropertySource annotation on a test class to declare resource locations for test properties files or inlined properties. These test property sources are added to the set of PropertySources in the Environment for the ApplicationContext loaded for the annotated integration test.spring-doc.cn
You can use @TestPropertySource with any implementation of the SmartContextLoader SPI, but @TestPropertySource is not supported with implementations of the older ContextLoader SPI.spring-doc.cn
Implementations of SmartContextLoader gain access to merged test property source values through the getPropertySourceLocations() and getPropertySourceProperties() methods in MergedContextConfiguration.spring-doc.cn
Declaring Test Property Sources
You can configure test properties files by using the locations or value attribute of @TestPropertySource.spring-doc.cn
Both traditional and XML-based properties file formats are supported — for example, "classpath:/com/example/test.properties" or "file:///path/to/file.xml".spring-doc.cn
Each path is interpreted as a Spring Resource. A plain path (for example, "test.properties") is treated as a classpath resource that is relative to the package in which the test class is defined. A path starting with a slash is treated as an absolute classpath resource (for example: "/org/example/test.xml"). A path that references a URL (for example, a path prefixed with classpath:, file:, or http:) is loaded by using the specified resource protocol. Resource location wildcards (such as **/*.properties) are not permitted: Each location must evaluate to exactly one .properties or .xml resource.spring-doc.cn
The following example uses a test properties file:spring-doc.cn
@ContextConfiguration
@TestPropertySource("/test.properties") (1)
class MyIntegrationTests {
	// class body...
1 Specifying a properties file with an absolute path.
	// class body...
You can configure inlined properties in the form of key-value pairs by using the properties attribute of @TestPropertySource, as shown in the next example. All key-value pairs are added to the enclosing Environment as a single test PropertySource with the highest precedence.spring-doc.cn
The supported syntax for key-value pairs is the same as the syntax defined for entries in a Java properties file:spring-doc.cn
The following example sets two inlined properties:spring-doc.cn
@TestPropertySource(properties = {"timezone = GMT", "port: 4242"}) (1)
	// class body...
1 Setting two properties by using two variations of the key-value syntax.
@TestPropertySource(properties = ["timezone = GMT", "port: 4242"]) (1)
	// class body...
As of Spring Framework 5.2, @TestPropertySource can be used as repeatable annotation. That means that you can have multiple declarations of @TestPropertySource on a single test class, with the locations and properties from later @TestPropertySource annotations overriding those from previous @TestPropertySource annotations.spring-doc.cn
In addition, you may declare multiple composed annotations on a test class that are each meta-annotated with @TestPropertySource, and all of those @TestPropertySource declarations will contribute to your test property sources.spring-doc.cn
Directly present @TestPropertySource annotations always take precedence over meta-present @TestPropertySource annotations. In other words, locations and properties from a directly present @TestPropertySource annotation will override the locations and properties from a @TestPropertySource annotation used as a meta-annotation.spring-doc.cn
Default Properties File Detection
If @TestPropertySource is declared as an empty annotation (that is, without explicit values for the locations or properties attributes), an attempt is made to detect a default properties file relative to the class that declared the annotation. For example, if the annotated test class is com.example.MyTest, the corresponding default properties file is classpath:com/example/MyTest.properties. If the default cannot be detected, an IllegalStateException is thrown.spring-doc.cn
Precedence
Test properties have higher precedence than those defined in the operating system’s environment, Java system properties, or property sources added by the application declaratively by using @PropertySource or programmatically. Thus, test properties can be used to selectively override properties loaded from system and application property sources. Furthermore, inlined properties have higher precedence than properties loaded from resource locations. Note, however, that properties registered via @DynamicPropertySource have higher precedence than those loaded via @TestPropertySource.spring-doc.cn
In the next example, the timezone and port properties and any properties defined in "/test.properties" override any properties of the same name that are defined in system and application property sources. Furthermore, if the "/test.properties" file defines entries for the timezone and port properties those are overridden by the inlined properties declared by using the properties attribute. The following example shows how to specify properties both in a file and inline:spring-doc.cn
	locations = "/test.properties",
	// class body...
@TestPropertySource("/test.properties",
	// class body...
Inheriting and Overriding Test Property Sources
@TestPropertySource supports boolean inheritLocations and inheritProperties attributes that denote whether resource locations for properties files and inlined properties declared by superclasses should be inherited. The default value for both flags is true. This means that a test class inherits the locations and inlined properties declared by any superclasses. Specifically, the locations and inlined properties for a test class are appended to the locations and inlined properties declared by superclasses. Thus, subclasses have the option of extending the locations and inlined properties. Note that properties that appear later shadow (that is, override) properties of the same name that appear earlier. In addition, the aforementioned precedence rules apply for inherited test property sources as well.spring-doc.cn
If the inheritLocations or inheritProperties attribute in @TestPropertySource is set to false, the locations or inlined properties, respectively, for the test class shadow and effectively replace the configuration defined by superclasses.spring-doc.cn
As of Spring Framework 5.3, test configuration may also be inherited from enclosing classes. See @Nested test class configuration for details.
In the next example, the ApplicationContext for BaseTest is loaded by using only the base.properties file as a test property source. In contrast, the ApplicationContext for ExtendedTest is loaded by using the base.properties and extended.properties files as test property source locations. The following example shows how to define properties in both a subclass and its superclass by using properties files:spring-doc.cn
@TestPropertySource("base.properties")
class BaseTest {
@TestPropertySource("extended.properties")
class ExtendedTest extends BaseTest {
open class BaseTest {
class ExtendedTest : BaseTest() {
In the next example, the ApplicationContext for BaseTest is loaded by using only the inlined key1 property. In contrast, the ApplicationContext for ExtendedTest is loaded by using the inlined key1 and key2 properties. The following example shows how to define properties in both a subclass and its superclass by using inline properties:spring-doc.cn
@TestPropertySource(properties = "key1 = value1")
class BaseTest {
@TestPropertySource(properties = "key2 = value2")
@TestPropertySource(properties = ["key1 = value1"])
@TestPropertySource(properties = ["key2 = value2"])
