For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Cache Abstraction
Since version 3.1, the Spring Framework provides support for transparently adding caching to an existing Spring application. Similar to the transaction support, the caching abstraction allows consistent use of various caching solutions with minimal impact on the code.spring-doc.cn
In Spring Framework 4.1, the cache abstraction was significantly extended with support for JSR-107 annotations and more customization options.spring-doc.cn
