For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Error Responses
A common requirement for REST services is to include details in the body of error responses. The Spring Framework supports the "Problem Details for HTTP APIs" specification, RFC 7807.spring-doc.cn
The following are the main abstractions for this support:spring-doc.cn
  • ProblemDetail — representation for an RFC 7807 problem detail; a simple container for both standard fields defined in the spec, and for non-standard ones.spring-doc.cn
  • ErrorResponse — contract to expose HTTP error response details including HTTP status, response headers, and a body in the format of RFC 7807; this allows exceptions to encapsulate and expose the details of how they map to an HTTP response. All Spring MVC exceptions implement this.spring-doc.cn
  • ErrorResponseException — basic ErrorResponse implementation that others can use as a convenient base class.spring-doc.cn
  • ResponseEntityExceptionHandler — convenient base class for an @ControllerAdvice that handles all Spring MVC exceptions, and any ErrorResponseException, and renders an error response with a body.spring-doc.cn
Render
You can return ProblemDetail or ErrorResponse from any @ExceptionHandler or from any @RequestMapping method to render an RFC 7807 response. This is processed as follows:spring-doc.cn
  • The status property of ProblemDetail determines the HTTP status.spring-doc.cn
  • The instance property of ProblemDetail is set from the current URL path, if not already set.spring-doc.cn
  • For content negotiation, the Jackson HttpMessageConverter prefers "application/problem+json" over "application/json" when rendering a ProblemDetail, and also falls back on it if no compatible media type is found.spring-doc.cn
To enable RFC 7807 responses for Spring WebFlux exceptions and for any ErrorResponseException, extend ResponseEntityExceptionHandler and declare it as an @ControllerAdvice in Spring configuration. The handler has an @ExceptionHandler method that handles any ErrorResponse exception, which includes all built-in web exceptions. You can add more exception handling methods, and use a protected method to map any exception to a ProblemDetail.spring-doc.cn
Non-Standard Fields
You can extend an RFC 7807 response with non-standard fields in one of two ways.spring-doc.cn
One, insert into the "properties" Map of ProblemDetail. When using the Jackson library, the Spring Framework registers ProblemDetailJacksonMixin that ensures this "properties" Map is unwrapped and rendered as top level JSON properties in the response, and likewise any unknown property during deserialization is inserted into this Map.spring-doc.cn
You can also extend ProblemDetail to add dedicated non-standard properties. The copy constructor in ProblemDetail allows a subclass to make it easy to be created from an existing ProblemDetail. This could be done centrally, e.g. from an @ControllerAdvice such as ResponseEntityExceptionHandler that re-creates the ProblemDetail of an exception into a subclass with the additional non-standard fields.spring-doc.cn
Internationalization
It is a common requirement to internationalize error response details, and good practice to customize the problem details for Spring MVC exceptions. This is supported as follows:spring-doc.cn
  • Each ErrorResponse exposes a message code and arguments to resolve the "detail" field through a MessageSource. The actual message code value is parameterized with placeholders, e.g. "HTTP method {0} not supported" to be expanded from the arguments.spring-doc.cn
  • Each ErrorResponse also exposes a message code to resolve the "title" field.spring-doc.cn
  • ResponseEntityExceptionHandler uses the message code and arguments to resolve the "detail" and the "title" fields.spring-doc.cn
By default, the message code for the "detail" field is "problemDetail." + the fully qualified exception class name. Some exceptions may expose additional message codes in which case a suffix is added to the default message code. The table below lists message arguments and codes for Spring MVC exceptions:spring-doc.cn
Exception Message Code Message Code Arguments
AsyncRequestTimeoutExceptionspring-doc.cn
(default)spring-doc.cn
ConversionNotSupportedExceptionspring-doc.cn
{0} property name, {1} property valuespring-doc.cn
HttpMediaTypeNotAcceptableExceptionspring-doc.cn
{0} list of supported media typesspring-doc.cn
(default) + ".parseError"spring-doc.cn
HttpMediaTypeNotSupportedExceptionspring-doc.cn
{0} the media type that is not supported, {1} list of supported media typesspring-doc.cn
HttpMessageNotReadableExceptionspring-doc.cn
HttpMessageNotWritableExceptionspring-doc.cn
HttpRequestMethodNotSupportedExceptionspring-doc.cn
{0} the current HTTP method, {1} the list of supported HTTP methodsspring-doc.cn
MethodArgumentNotValidExceptionspring-doc.cn
{0} the list of global errors, {1} the list of field errors. Message codes and arguments for each error within the BindingResult are also resolved via MessageSource.spring-doc.cn
MissingRequestHeaderExceptionspring-doc.cn
{0} the header namespring-doc.cn
MissingServletRequestParameterExceptionspring-doc.cn
{0} the request parameter namespring-doc.cn
MissingMatrixVariableExceptionspring-doc.cn
{0} the matrix variable namespring-doc.cn
MissingPathVariableExceptionspring-doc.cn
{0} the path variable namespring-doc.cn
MissingRequestCookieExceptionspring-doc.cn
{0} the cookie namespring-doc.cn
MissingServletRequestPartExceptionspring-doc.cn
{0} the part namespring-doc.cn
NoHandlerFoundExceptionspring-doc.cn
TypeMismatchExceptionspring-doc.cn
UnsatisfiedServletRequestParameterExceptionspring-doc.cn
{0} the list of parameter conditionsspring-doc.cn
By default, the message code for the "title" field is "problemDetail.title." + the fully qualified exception class name.spring-doc.cn
Client Handling
A client application can catch WebClientResponseException, when using the WebClient, or RestClientResponseException when using the RestTemplate, and use their getResponseBodyAs methods to decode the error response body to any target type such as ProblemDetail, or a subclass of ProblemDetail.spring-doc.cn
