For the latest stable version, please use Spring Framework 6.2.6!spring-doc.cn
Basic Concepts: @Bean and @Configuration
The central artifacts in Spring’s Java configuration support are @Configuration-annotated classes and @Bean-annotated methods.spring-doc.cn
The @Bean annotation is used to indicate that a method instantiates, configures, and initializes a new object to be managed by the Spring IoC container. For those familiar with Spring’s <beans/> XML configuration, the @Bean annotation plays the same role as the <bean/> element. You can use @Bean-annotated methods with any Spring @Component. However, they are most often used with @Configuration beans.spring-doc.cn
Annotating a class with @Configuration indicates that its primary purpose is as a source of bean definitions. Furthermore, @Configuration classes let inter-bean dependencies be defined by calling other @Bean methods in the same class. The simplest possible @Configuration class reads as follows:spring-doc.cn
public class AppConfig {
	public MyServiceImpl myService() {
		return new MyServiceImpl();
class AppConfig {
	fun myService(): MyServiceImpl {
		return MyServiceImpl()
The preceding AppConfig class is equivalent to the following Spring <beans/> XML:spring-doc.cn
<beans>
	<bean id="myService" class="com.acme.services.MyServiceImpl"/>
</beans>
Full @Configuration vs “lite” @Bean mode?
When @Bean methods are declared within classes that are not annotated with @Configuration, they are referred to as being processed in a “lite” mode. Bean methods declared in a @Component or even in a plain old class are considered to be “lite”, with a different primary purpose of the containing class and a @Bean method being a sort of bonus there. For example, service components may expose management views to the container through an additional @Bean method on each applicable component class. In such scenarios, @Bean methods are a general-purpose factory method mechanism.spring-doc.cn
Unlike full @Configuration, lite @Bean methods cannot declare inter-bean dependencies. Instead, they operate on their containing component’s internal state and, optionally, on arguments that they may declare. Such a @Bean method should therefore not invoke other @Bean methods. Each such method is literally only a factory method for a particular bean reference, without any special runtime semantics. The positive side-effect here is that no CGLIB subclassing has to be applied at runtime, so there are no limitations in terms of class design (that is, the containing class may be final and so forth).spring-doc.cn
In common scenarios, @Bean methods are to be declared within @Configuration classes, ensuring that “full” mode is always used and that cross-method references therefore get redirected to the container’s lifecycle management. This prevents the same @Bean method from accidentally being invoked through a regular Java call, which helps to reduce subtle bugs that can be hard to track down when operating in “lite” mode.spring-doc.cn
The @Bean and @Configuration annotations are discussed in depth in the following sections. First, however, we cover the various ways of creating a spring container by using Java-based configuration.spring-doc.cn
