For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
Functions
You can extend SpEL by registering user-defined functions that can be called within the expression string. The function is registered through the EvaluationContext. The following example shows how to register a user-defined function:spring-doc.cn
Method method = ...;
EvaluationContext context = SimpleEvaluationContext.forReadOnlyDataBinding().build();
context.setVariable("myFunction", method);
val method: Method = ...
val context = SimpleEvaluationContext.forReadOnlyDataBinding().build()
For example, consider the following utility method that reverses a string:spring-doc.cn
public abstract class StringUtils {
	public static String reverseString(String input) {
		StringBuilder backwards = new StringBuilder(input.length());
		for (int i = 0; i < input.length(); i++) {
			backwards.append(input.charAt(input.length() - 1 - i));
		return backwards.toString();
fun reverseString(input: String): String {
	val backwards = StringBuilder(input.length)
	for (i in 0 until input.length) {
		backwards.append(input[input.length - 1 - i])
You can then register and use the preceding method, as the following example shows:spring-doc.cn
ExpressionParser parser = new SpelExpressionParser();
context.setVariable("reverseString",
		StringUtils.class.getDeclaredMethod("reverseString", String.class));
String helloWorldReversed = parser.parseExpression(
		"#reverseString('hello')").getValue(context, String.class);
val parser = SpelExpressionParser()
context.setVariable("reverseString", ::reverseString::javaMethod)
val helloWorldReversed = parser.parseExpression(
		"#reverseString('hello')").getValue(context, String::class.java)
