For the latest stable version, please use Spring Framework 6.2.4! |
Understanding the Spring Framework Transaction Abstraction
The key to the Spring transaction abstraction is the notion of a transaction strategy. A
transaction strategy is defined by a TransactionManager
, specifically the
org.springframework.transaction.PlatformTransactionManager
interface for imperative
transaction management and the
org.springframework.transaction.ReactiveTransactionManager
interface for reactive
transaction management. The following listing shows the definition of the
API:
public interface PlatformTransactionManager extends TransactionManager {
TransactionStatus getTransaction(TransactionDefinition definition) throws TransactionException;
void commit(TransactionStatus status) throws TransactionException;
void rollback(TransactionStatus status) throws TransactionException;
This is primarily a service provider interface (SPI), although you can use it
programmatically from your application code. Because
is an interface, it can be easily mocked or stubbed as
necessary. It is not tied to a lookup strategy, such as JNDI.
implementations are defined like any other object (or bean)
in the Spring Framework IoC container. This benefit alone makes Spring Framework
transactions a worthwhile abstraction, even when you work with JTA. You can test
transactional code much more easily than if it used JTA directly.
Again, in keeping with Spring’s philosophy, the TransactionException
that can be thrown
by any of the PlatformTransactionManager
interface’s methods is unchecked (that
is, it extends the java.lang.RuntimeException
class). Transaction infrastructure
failures are almost invariably fatal. In rare cases where application code can actually
recover from a transaction failure, the application developer can still choose to catch
and handle TransactionException
. The salient point is that developers are not
forced to do so.
The getTransaction(..)
method returns a TransactionStatus
object, depending on a
parameter. The returned TransactionStatus
might represent a
new transaction or can represent an existing transaction, if a matching transaction
exists in the current call stack. The implication in this latter case is that, as with
Jakarta EE transaction contexts, a TransactionStatus
is associated with a thread of
execution.
As of Spring Framework 5.2, Spring also provides a transaction management abstraction for
reactive applications that make use of reactive types or Kotlin Coroutines. The following
listing shows the transaction strategy defined by
public interface ReactiveTransactionManager extends TransactionManager {
Mono<ReactiveTransaction> getReactiveTransaction(TransactionDefinition definition) throws TransactionException;
Mono<Void> commit(ReactiveTransaction status) throws TransactionException;
Mono<Void> rollback(ReactiveTransaction status) throws TransactionException;
The reactive transaction manager is primarily a service provider interface (SPI),
although you can use it programmatically from your
application code. Because ReactiveTransactionManager
mocked or stubbed as necessary.
The TransactionDefinition
interface specifies:
Propagation: Typically, all code within a transaction scope runs in that transaction. However, you can specify the behavior if a transactional method is run when a transaction context already exists. For example, code can continue running in the existing transaction (the common case), or the existing transaction can be suspended and a new transaction created. Spring offers all of the transaction propagation options familiar from EJB CMT. To read about the semantics of transaction propagation in Spring, see Transaction Propagation.
Isolation: The degree to which this transaction is isolated from the work of other transactions. For example, can this transaction see uncommitted writes from other transactions?
Timeout: How long this transaction runs before timing out and being automatically rolled back by the underlying transaction infrastructure.
Read-only status: You can use a read-only transaction when your code reads but does not modify data. Read-only transactions can be a useful optimization in some cases, such as when you use Hibernate.
These settings reflect standard transactional concepts. If necessary, refer to resources that discuss transaction isolation levels and other core transaction concepts. Understanding these concepts is essential to using the Spring Framework or any transaction management solution.
The TransactionStatus
interface provides a simple way for transactional code to
control transaction execution and query transaction status. The concepts should be
familiar, as they are common to all transaction APIs. The following listing shows the
TransactionStatus
interface:
public interface TransactionStatus extends TransactionExecution, SavepointManager, Flushable {
boolean isNewTransaction();
boolean hasSavepoint();
void setRollbackOnly();
boolean isRollbackOnly();
void flush();
boolean isCompleted();
Regardless of whether you opt for declarative or programmatic transaction management in
Spring, defining the correct TransactionManager
implementation is absolutely essential.
You typically define this implementation through dependency injection.
TransactionManager
implementations normally require knowledge of the environment in
which they work: JDBC, JTA, Hibernate, and so on. The following examples show how you can
define a local PlatformTransactionManager
implementation (in this case, with plain
JDBC.)
You can define a JDBC DataSource
by creating a bean similar to the following:
<bean id="dataSource" class="org.apache.commons.dbcp.BasicDataSource" destroy-method="close">
<property name="driverClassName" value="${jdbc.driverClassName}" />
<property name="url" value="${jdbc.url}" />
<property name="username" value="${jdbc.username}" />
<property name="password" value="${jdbc.password}" />
</bean>
The related PlatformTransactionManager
bean definition then has a reference to the
DataSource
definition. It should resemble the following example:
<bean id="txManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
<property name="dataSource" ref="dataSource"/>
</bean>
If you use JTA in a Jakarta EE container, then you use a container DataSource
, obtained
through JNDI, in conjunction with Spring’s JtaTransactionManager
shows what the JTA and JNDI lookup version would look like:
xmlns:jee="http://www.springframework.org/schema/jee"
xsi:schemaLocation="
https://www.springframework.org/schema/jee/spring-jee.xsd">
<jee:jndi-lookup id="dataSource" jndi-name="jdbc/jpetstore"/>
<bean id="txManager" class="org.springframework.transaction.jta.JtaTransactionManager" />
<!-- other <bean/> definitions here -->
</beans>
The JtaTransactionManager
does not need to know about the DataSource
(or any other
specific resources) because it uses the container’s global transaction management
infrastructure.
The preceding definition of the dataSource bean uses the <jndi-lookup/> tag
from the jee namespace. For more information see
The JEE Schema.
If you use JTA, your transaction manager definition should look the same, regardless of what data access technology you use, be it JDBC, Hibernate JPA, or any other supported technology. This is due to the fact that JTA transactions are global transactions, which can enlist any transactional resource. |
In all Spring transaction setups, application code does not need to change. You can change how transactions are managed merely by changing configuration, even if that change means moving from local to global transactions or vice versa.
Hibernate Transaction Setup
You can also easily use Hibernate local transactions, as shown in the following examples.
In this case, you need to define a Hibernate LocalSessionFactoryBean
, which your
application code can use to obtain Hibernate Session
instances.
The DataSource
bean definition is similar to the local JDBC example shown previously
and, thus, is not shown in the following example.
If the DataSource (used by any non-JTA transaction manager) is looked up through
JNDI and managed by a Jakarta EE container, it should be non-transactional, because the
Spring Framework (rather than the Jakarta EE container) manages the transactions.
The txManager
bean in this case is of the HibernateTransactionManager
type. In the
same way as the DataSourceTransactionManager
needs a reference to the DataSource
, the
needs a reference to the SessionFactory
. The following
example declares sessionFactory
and txManager
beans:
<bean id="sessionFactory" class="org.springframework.orm.hibernate5.LocalSessionFactoryBean">
<property name="mappingResources">
<list>
<value>org/springframework/samples/petclinic/hibernate/petclinic.hbm.xml</value>
</list>
</property>
<property name="hibernateProperties">
<value>
hibernate.dialect=${hibernate.dialect}
</value>
</property>
</bean>
<bean id="txManager" class="org.springframework.orm.hibernate5.HibernateTransactionManager">
<property name="sessionFactory" ref="sessionFactory"/>
</bean>
If you use Hibernate and Jakarta EE container-managed JTA transactions, you should use the
same JtaTransactionManager
as in the previous JTA example for JDBC, as the following
example shows. Also, it is recommended to make Hibernate aware of JTA through its
transaction coordinator and possibly also its connection release mode configuration:
<list>
</list>
</property>
<value>
hibernate.transaction.coordinator_class=jta
hibernate.connection.handling_mode=DELAYED_ACQUISITION_AND_RELEASE_AFTER_STATEMENT
</value>
</property>
</bean>
<bean id="txManager" class="org.springframework.transaction.jta.JtaTransactionManager"/>
Or alternatively, you may pass the JtaTransactionManager
into your LocalSessionFactoryBean
for enforcing the same defaults:
<list>
</list>
</property>
<value>
</value>
</property>
<property name="jtaTransactionManager" ref="txManager"/>
</bean>
