For the latest stable version, please use Spring Framework 6.2.4! |
Request Mapping
You can use the @RequestMapping
annotation to map requests to controllers methods. It has
various attributes to match by URL, HTTP method, request parameters, headers, and media
types. You can use it at the class level to express shared mappings or at the method level
to narrow down to a specific endpoint mapping.
There are also HTTP method specific shortcut variants of @RequestMapping
@GetMapping
@PostMapping
@PutMapping
@DeleteMapping
@PatchMapping
The shortcuts are Custom Annotations that are provided because,
arguably, most controller methods should be mapped to a specific HTTP method versus
using @RequestMapping
, which, by default, matches to all HTTP methods.
A @RequestMapping
is still needed at the class level to express shared mappings.
The following example has type and method level mappings:
Java
Kotlin
@RestController
@RequestMapping("/persons")
class PersonController {
@GetMapping("/{id}")
public Person getPerson(@PathVariable Long id) {
@PostMapping
@ResponseStatus(HttpStatus.CREATED)
public void add(@RequestBody Person person) {
@RestController
fun getPerson(@PathVariable id: Long): Person {
@PostMapping
fun add(@RequestBody person: Person) {
URI patterns
@RequestMapping
methods can be mapped using URL patterns. There are two alternatives:
PathPattern
— a pre-parsed pattern matched against the URL path also pre-parsed asPathContainer
. Designed for web use, this solution deals effectively with encoding and path parameters, and matches efficiently. -
AntPathMatcher
— match String patterns against a String path. This is the original solution also used in Spring configuration to select resources on the classpath, on the filesystem, and other locations. It is less efficient and the String path input is a challenge for dealing effectively with encoding and other issues with URLs.
PathPattern
is the recommended solution for web applications and it is the only choice in
Spring WebFlux. It was enabled for use in Spring MVC from version 5.3 and is enabled by
default from version 6.0. See MVC config for
customizations of path matching options.
PathPattern
supports the same pattern syntax as AntPathMatcher
. In addition, it also
supports the capturing pattern, e.g. {*spring}
, for matching 0 or more path segments
at the end of a path. PathPattern
also restricts the use of **
for matching multiple
path segments such that it’s only allowed at the end of a pattern. This eliminates many
cases of ambiguity when choosing the best matching pattern for a given request.
For full pattern syntax please refer to
PathPattern and
AntPathMatcher.
Some example patterns:
"/resources/ima?e.png"
- match one character in a path segment -
"/resources/*.png"
- match zero or more characters in a path segment -
"/resources/**"
- match multiple path segments -
"/projects/{project}/versions"
- match a path segment and capture it as a variable -
"/projects/{project:[a-z]}/versions"+
- match and capture a variable with a regex
Captured URI variables can be accessed with @PathVariable
. For example:
Java
Kotlin
@GetMapping("/owners/{ownerId}/pets/{petId}")
public Pet findPet(@PathVariable Long ownerId, @PathVariable Long petId) {
fun findPet(@PathVariable ownerId: Long, @PathVariable petId: Long): Pet {
You can declare URI variables at the class and method levels, as the following example shows:
Java
Kotlin
@Controller
@RequestMapping("/owners/{ownerId}")
public class OwnerController {
@GetMapping("/pets/{petId}")
@Controller
URI variables are automatically converted to the appropriate type, or TypeMismatchException
is raised. Simple types (int
, long
, Date
, and so on) are supported by default and you can
register support for any other data type.
See Type Conversion and DataBinder
You can explicitly name URI variables (for example, @PathVariable("customId")
), but you can
leave that detail out if the names are the same and your code is compiled with the -parameters
compiler flag.
The syntax {varName:regex}
declares a URI variable with a regular expression that has
syntax of {varName:regex}
. For example, given URL "/spring-web-3.0.5.jar"
, the following method
extracts the name, version, and file extension:
Java
Kotlin
@GetMapping("/{name:[a-z-]+}-{version:\\d\\.\\d\\.\\d}{ext:\\.[a-z]+}")
public void handle(@PathVariable String name, @PathVariable String version, @PathVariable String ext) {
fun handle(@PathVariable name: String, @PathVariable version: String, @PathVariable ext: String) {
URI path patterns can also have embedded ${…}
placeholders that are resolved on startup
by using PropertySourcesPlaceholderConfigurer
against local, system, environment, and
other property sources. You can use this, for example, to parameterize a base URL based on
some external configuration.
Pattern Comparison
When multiple patterns match a URL, the best match must be selected. This is done with
one of the following depending on whether use of parsed PathPattern
is enabled for use or not:
Both help to sort patterns with more specific ones on top. A pattern is more specific if it has a lower count of URI variables (counted as 1), single wildcards (counted as 1), and double wildcards (counted as 2). Given an equal score, the longer pattern is chosen. Given the same score and length, the pattern with more URI variables than wildcards is chosen.
The default mapping pattern (/**
) is excluded from scoring and always
sorted last. Also, prefix patterns (such as /public/**
) are considered less
specific than other pattern that do not have double wildcards.
For the full details, follow the above links to the pattern Comparators.
Suffix Match
Starting in 5.3, by default Spring MVC no longer performs .*
suffix pattern
matching where a controller mapped to /person
is also implicitly mapped to
/person.*
. As a consequence path extensions are no longer used to interpret
the requested content type for the response — for example, /person.pdf
, /person.xml
and so on.
Using file extensions in this way was necessary when browsers used to send Accept
headers
that were hard to interpret consistently. At present, that is no longer a necessity and
using the Accept
header should be the preferred choice.
Over time, the use of file name extensions has proven problematic in a variety of ways. It can cause ambiguity when overlain with the use of URI variables, path parameters, and URI encoding. Reasoning about URL-based authorization and security (see next section for more details) also becomes more difficult.
To completely disable the use of path extensions in versions prior to 5.3, set the following:
useSuffixPatternMatching(false)
, see PathMatchConfigurer -
favorPathExtension(false)
, see ContentNegotiationConfigurer
Having a way to request content types other than through the "Accept"
header can still
be useful, e.g. when typing a URL in a browser. A safe alternative to path extensions is
to use the query parameter strategy. If you must use file extensions, consider restricting
them to a list of explicitly registered extensions through the mediaTypes
property of
ContentNegotiationConfigurer.
Suffix Match and RFD
A reflected file download (RFD) attack is similar to XSS in that it relies on request input (for example, a query parameter and a URI variable) being reflected in the response. However, instead of inserting JavaScript into HTML, an RFD attack relies on the browser switching to perform a download and treating the response as an executable script when double-clicked later.
In Spring MVC, @ResponseBody
and ResponseEntity
methods are at risk, because
they can render different content types, which clients can request through URL path extensions.
Disabling suffix pattern matching and using path extensions for content negotiation
lower the risk but are not sufficient to prevent RFD attacks.
To prevent RFD attacks, prior to rendering the response body, Spring MVC adds a
Content-Disposition:inline;filename=f.txt
header to suggest a fixed and safe download
file. This is done only if the URL path contains a file extension that is neither
allowed as safe nor explicitly registered for content negotiation. However, it can
potentially have side effects when URLs are typed directly into a browser.
Many common path extensions are allowed as safe by default. Applications with custom
HttpMessageConverter
implementations can explicitly register file extensions for content
negotiation to avoid having a Content-Disposition
header added for those extensions.
See Content Types.
See CVE-2015-5211 for additional recommendations related to RFD.
Consumable Media Types
You can narrow the request mapping based on the Content-Type
of the request,
Java
Kotlin
@PostMapping(path = "/pets", consumes = "application/json") (1)
public void addPet(@RequestBody Pet pet) {
1 | Using a consumes attribute to narrow the mapping by the content type. |
@PostMapping("/pets", consumes = ["application/json"]) (1)
fun addPet(@RequestBody pet: Pet) {
The consumes
attribute also supports negation expressions — for example, !text/plain
means any
content type other than text/plain
You can declare a shared consumes
attribute at the class level. Unlike most other
request-mapping attributes, however, when used at the class level, a method-level consumes
attribute
overrides rather than extends the class-level declaration.
MediaType provides constants for commonly used media types, such as
APPLICATION_JSON_VALUE and APPLICATION_XML_VALUE .
Producible Media Types
You can narrow the request mapping based on the Accept
request header and the list of
content types that a controller method produces, as the following example shows:
Java
Kotlin
@GetMapping(path = "/pets/{petId}", produces = "application/json") (1)
@ResponseBody
public Pet getPet(@PathVariable String petId) {
1 | Using a produces attribute to narrow the mapping by the content type. |
@GetMapping("/pets/{petId}", produces = ["application/json"]) (1)
@ResponseBody
fun getPet(@PathVariable petId: String): Pet {
The media type can specify a character set. Negated expressions are supported — for example,
!text/plain
means any content type other than "text/plain".
You can declare a shared produces
request-mapping attributes, however, when used at the class level, a method-level produces
attribute
Parameters, headers
You can narrow request mappings based on request parameter conditions. You can test for the
presence of a request parameter (myParam
), for the absence of one (!myParam
), or for a
specific value (myParam=myValue
). The following example shows how to test for a specific value:
Java
Kotlin
@GetMapping(path = "/pets/{petId}", params = "myParam=myValue") (1)
public void findPet(@PathVariable String petId) {
1 | Testing whether myParam equals myValue . |
@GetMapping("/pets/{petId}", params = ["myParam=myValue"]) (1)
fun findPet(@PathVariable petId: String) {
You can also use the same with request header conditions, as the following example shows:
Java
Kotlin
@GetMapping(path = "/pets/{petId}", headers = "myHeader=myValue") (1)
1 | Testing whether myHeader equals myValue . |
@GetMapping("/pets/{petId}", headers = ["myHeader=myValue"]) (1)
HTTP HEAD, OPTIONS
@GetMapping
(and @RequestMapping(method=HttpMethod.GET)
) support HTTP HEAD
transparently for request mapping. Controller methods do not need to change.
A response wrapper, applied in jakarta.servlet.http.HttpServlet
, ensures a Content-Length
header is set to the number of bytes written (without actually writing to the response).
@GetMapping
) are implicitly mapped to
and support HTTP HEAD. An HTTP HEAD request is processed as if it were HTTP GET except
that, instead of writing the body, the number of bytes are counted and the Content-Length
header is set.
By default, HTTP OPTIONS is handled by setting the Allow
response header to the list of HTTP
methods listed in all @RequestMapping
methods that have matching URL patterns.
For a @RequestMapping
without HTTP method declarations, the Allow
header is set to
GET,HEAD,POST,PUT,PATCH,DELETE,OPTIONS
. Controller methods should always declare the
supported HTTP methods (for example, by using the HTTP method specific variants:
@GetMapping
, @PostMapping
, and others).
You can explicitly map the @RequestMapping
method to HTTP HEAD and HTTP OPTIONS, but that
is not necessary in the common case.
Custom Annotations
Spring MVC supports the use of composed annotations
for request mapping. Those are annotations that are themselves meta-annotated with
@RequestMapping
and composed to redeclare a subset (or all) of the @RequestMapping
attributes with a narrower, more specific purpose.
@GetMapping
, @PostMapping
, @PutMapping
, @DeleteMapping
, and @PatchMapping
are
examples of composed annotations. They are provided because, arguably, most
controller methods should be mapped to a specific HTTP method versus using @RequestMapping
which, by default, matches to all HTTP methods. If you need an example of composed
annotations, look at how those are declared.
Spring MVC also supports custom request-mapping attributes with custom request-matching
logic. This is a more advanced option that requires subclassing
RequestMappingHandlerMapping
and overriding the getCustomMethodCondition
method, where
you can check the custom attribute and return your own RequestCondition
Explicit Registrations
You can programmatically register handler methods, which you can use for dynamic registrations or for advanced cases, such as different instances of the same handler under different URLs. The following example registers a handler method:
Java
Kotlin
public class MyConfig {
@Autowired
public void setHandlerMapping(RequestMappingHandlerMapping mapping, UserHandler handler) (1)
throws NoSuchMethodException {
RequestMappingInfo info = RequestMappingInfo
.paths("/user/{id}").methods(RequestMethod.GET).build(); (2)
Method method = UserHandler.class.getMethod("getUser", Long.class); (3)
mapping.registerMapping(info, handler, method); (4)
1 | Inject the target handler and the handler mapping for controllers. |
2 | Prepare the request mapping meta data. |
3 | Get the handler method. |
4 | Add the registration. |
class MyConfig {
@Autowired
fun setHandlerMapping(mapping: RequestMappingHandlerMapping, handler: UserHandler) { (1)
val info = RequestMappingInfo.paths("/user/{id}").methods(RequestMethod.GET).build() (2)
val method = UserHandler::class.java.getMethod("getUser", Long::class.java) (3)
mapping.registerMapping(info, handler, method) (4)
