For the latest stable version, please use Spring Framework 6.2.4! |
Type Conversion
Some annotated controller method arguments that represent String
-based request input (such as
@RequestParam
, @RequestHeader
, @PathVariable
, @MatrixVariable
, and @CookieValue
can require type conversion if the argument is declared as something other than String
For such cases, type conversion is automatically applied based on the configured converters.
By default, simple types (int
, long
, Date
, and others) are supported. You can customize
type conversion through a WebDataBinder
(see DataBinder
) or by registering
Formatters
with the FormattingConversionService
See Spring Field Formatting.
A practical issue in type conversion is the treatment of an empty String source value.
Such a value is treated as missing if it becomes null
as a result of type conversion.
This can be the case for Long
, UUID
, and other target types. If you want to allow null
to be injected, either use the required
flag on the argument annotation, or declare the
argument as @Nullable
As of 5.3, non-null arguments will be enforced even after type conversion. If your handler
method intends to accept a null value as well, either declare your argument as Alternatively, you may specifically handle e.g. the resulting |
