For the latest stable version, please use Spring Framework 6.2.6!spring-doc.cn
Token Authentication
Spring Security OAuth provides support for token based security, including JSON Web Token (JWT). You can use this as the authentication mechanism in Web applications, including STOMP over WebSocket interactions, as described in the previous section (that is, to maintain identity through a cookie-based session).spring-doc.cn
At the same time, cookie-based sessions are not always the best fit (for example, in applications that do not maintain a server-side session or in mobile applications where it is common to use headers for authentication).spring-doc.cn
The WebSocket protocol, RFC 6455 "doesn’t prescribe any particular way that servers can authenticate clients during the WebSocket handshake." In practice, however, browser clients can use only standard authentication headers (that is, basic HTTP authentication) or cookies and cannot (for example) provide custom headers. Likewise, the SockJS JavaScript client does not provide a way to send HTTP headers with SockJS transport requests. See sockjs-client issue 196. Instead, it does allow sending query parameters that you can use to send a token, but that has its own drawbacks (for example, the token may be inadvertently logged with the URL in server logs).spring-doc.cn
The preceding limitations are for browser-based clients and do not apply to the Spring Java-based STOMP client, which does support sending headers with both WebSocket and SockJS requests.
Therefore, applications that wish to avoid the use of cookies may not have any good alternatives for authentication at the HTTP protocol level. Instead of using cookies, they may prefer to authenticate with headers at the STOMP messaging protocol level. Doing so requires two simple steps:spring-doc.cn
  1. Use the STOMP client to pass authentication headers at connect time.spring-doc.cn
  2. Process the authentication headers with a ChannelInterceptor.spring-doc.cn
The next example uses server-side configuration to register a custom authentication interceptor. Note that an interceptor needs only to authenticate and set the user header on the CONNECT Message. Spring notes and saves the authenticated user and associate it with subsequent STOMP messages on the same session. The following example shows how register a custom authentication interceptor:spring-doc.cn
@EnableWebSocketMessageBroker
public class MyConfig implements WebSocketMessageBrokerConfigurer {
	public void configureClientInboundChannel(ChannelRegistration registration) {
		registration.interceptors(new ChannelInterceptor() {
			public Message<?> preSend(Message<?> message, MessageChannel channel) {
				StompHeaderAccessor accessor =
						MessageHeaderAccessor.getAccessor(message, StompHeaderAccessor.class);
				if (StompCommand.CONNECT.equals(accessor.getCommand())) {
					Authentication user = ... ; // access authentication header(s)
					accessor.setUser(user);
				return message;
Also, note that, when you use Spring Security’s authorization for messages, at present, you need to ensure that the authentication ChannelInterceptor config is ordered ahead of Spring Security’s. This is best done by declaring the custom interceptor in its own implementation of WebSocketMessageBrokerConfigurer that is marked with @Order(Ordered.HIGHEST_PRECEDENCE + 99).spring-doc.cn
