For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Configuration
The simplest way to create a WebClient is through one of the static factory methods:spring-doc.cn
You can also use WebClient.builder() with further options:spring-doc.cn
For example:spring-doc.cn
WebClient client = WebClient.builder()
		.codecs(configurer -> ... )
val webClient = WebClient.builder()
		.codecs { configurer -> ... }
		.build()
Once built, a WebClient is immutable. However, you can clone it and build a modified copy as follows:spring-doc.cn
WebClient client1 = WebClient.builder()
		.filter(filterA).filter(filterB).build();
WebClient client2 = client1.mutate()
		.filter(filterC).filter(filterD).build();
// client1 has filterA, filterB
// client2 has filterA, filterB, filterC, filterD
val client1 = WebClient.builder()
val client2 = client1.mutate()
MaxInMemorySize
Codecs have limits for buffering data in memory to avoid application memory issues. By default those are set to 256KB. If that’s not enough you’ll get the following error:spring-doc.cn
org.springframework.core.io.buffer.DataBufferLimitException: Exceeded limit on max bytes to buffer
To change the limit for default codecs, use the following:spring-doc.cn
WebClient webClient = WebClient.builder()
		.codecs(configurer -> configurer.defaultCodecs().maxInMemorySize(2 * 1024 * 1024))
		.codecs { configurer -> configurer.defaultCodecs().maxInMemorySize(2 * 1024 * 1024) }
		.build()
Reactor Netty
To customize Reactor Netty settings, provide a pre-configured HttpClient:spring-doc.cn
HttpClient httpClient = HttpClient.create().secure(sslSpec -> ...);
		.clientConnector(new ReactorClientHttpConnector(httpClient))
val httpClient = HttpClient.create().secure { ... }
	.clientConnector(ReactorClientHttpConnector(httpClient))
	.build()
Resources
By default, HttpClient participates in the global Reactor Netty resources held in reactor.netty.http.HttpResources, including event loop threads and a connection pool. This is the recommended mode, since fixed, shared resources are preferred for event loop concurrency. In this mode global resources remain active until the process exits.spring-doc.cn
If the server is timed with the process, there is typically no need for an explicit shutdown. However, if the server can start or stop in-process (for example, a Spring MVC application deployed as a WAR), you can declare a Spring-managed bean of type ReactorResourceFactory with globalResources=true (the default) to ensure that the Reactor Netty global resources are shut down when the Spring ApplicationContext is closed, as the following example shows:spring-doc.cn
public ReactorResourceFactory reactorResourceFactory() {
	return new ReactorResourceFactory();
fun reactorResourceFactory() = ReactorResourceFactory()
You can also choose not to participate in the global Reactor Netty resources. However, in this mode, the burden is on you to ensure that all Reactor Netty client and server instances use shared resources, as the following example shows:spring-doc.cn
public ReactorResourceFactory resourceFactory() {
	ReactorResourceFactory factory = new ReactorResourceFactory();
	factory.setUseGlobalResources(false); (1)
	return factory;
public WebClient webClient() {
	Function<HttpClient, HttpClient> mapper = client -> {
		// Further customizations...
	ClientHttpConnector connector =
			new ReactorClientHttpConnector(resourceFactory(), mapper); (2)
	return WebClient.builder().clientConnector(connector).build(); (3)
1 Create resources independent of global ones.
2 Use the ReactorClientHttpConnector constructor with resource factory.
3 Plug the connector into the WebClient.Builder.
fun resourceFactory() = ReactorResourceFactory().apply {
	isUseGlobalResources = false (1)
fun webClient(): WebClient {
	val mapper: (HttpClient) -> HttpClient = {
	val connector = ReactorClientHttpConnector(resourceFactory(), mapper) (2)
	return WebClient.builder().clientConnector(connector).build() (3)
Timeouts
To configure a connection timeout:spring-doc.cn
import io.netty.channel.ChannelOption;
		.option(ChannelOption.CONNECT_TIMEOUT_MILLIS, 10000);
To configure a read or write timeout:spring-doc.cn
import io.netty.handler.timeout.ReadTimeoutHandler;
import io.netty.handler.timeout.WriteTimeoutHandler;
		.doOnConnected(conn -> conn
				.addHandlerLast(new ReadTimeoutHandler(10))
				.addHandlerLast(new WriteTimeoutHandler(10)));
// Create WebClient...
		.doOnConnected { conn -> conn
				.addHandlerLast(ReadTimeoutHandler(10))
				.addHandlerLast(WriteTimeoutHandler(10))
To configure a response timeout for all requests:spring-doc.cn
		.responseTimeout(Duration.ofSeconds(2));
To configure a response timeout for a specific request:spring-doc.cn
WebClient.create().get()
		.uri("https://example.org/path")
		.httpRequest(httpRequest -> {
			HttpClientRequest reactorRequest = httpRequest.getNativeRequest();
			reactorRequest.responseTimeout(Duration.ofSeconds(2));
		.retrieve()
		.bodyToMono(String.class);
		.httpRequest { httpRequest: ClientHttpRequest ->
			val reactorRequest = httpRequest.getNativeRequest<HttpClientRequest>()
		.retrieve()
		.bodyToMono(String::class.java)
JDK HttpClient
The following example shows how to customize the JDK HttpClient:spring-doc.cn
HttpClient httpClient = HttpClient.newBuilder()
    .followRedirects(Redirect.NORMAL)
    .connectTimeout(Duration.ofSeconds(20))
        new JdkClientHttpConnector(httpClient, new DefaultDataBufferFactory());
WebClient webClient = WebClient.builder().clientConnector(connector).build();
val httpClient = HttpClient.newBuilder()
    .build()
val connector = JdkClientHttpConnector(httpClient, DefaultDataBufferFactory())
val webClient = WebClient.builder().clientConnector(connector).build()
Jetty
The following example shows how to customize Jetty HttpClient settings:spring-doc.cn
HttpClient httpClient = new HttpClient();
httpClient.setCookieStore(...);
		.clientConnector(new JettyClientHttpConnector(httpClient))
val httpClient = HttpClient()
httpClient.cookieStore = ...
		.clientConnector(JettyClientHttpConnector(httpClient))
By default, HttpClient creates its own resources (Executor, ByteBufferPool, Scheduler), which remain active until the process exits or stop() is called.spring-doc.cn
You can share resources between multiple instances of the Jetty client (and server) and ensure that the resources are shut down when the Spring ApplicationContext is closed by declaring a Spring-managed bean of type JettyResourceFactory, as the following example shows:spring-doc.cn
public JettyResourceFactory resourceFactory() {
	return new JettyResourceFactory();
			new JettyClientHttpConnector(httpClient, resourceFactory()); (1)
	return WebClient.builder().clientConnector(connector).build(); (2)
1 Use the JettyClientHttpConnector constructor with resource factory.
2 Plug the connector into the WebClient.Builder.
fun resourceFactory() = JettyResourceFactory()
	val connector = JettyClientHttpConnector(httpClient, resourceFactory()) (1)
	return WebClient.builder().clientConnector(connector).build() (2)
HttpComponents
The following example shows how to customize Apache HttpComponents HttpClient settings:spring-doc.cn
HttpAsyncClientBuilder clientBuilder = HttpAsyncClients.custom();
clientBuilder.setDefaultRequestConfig(...);
CloseableHttpAsyncClient client = clientBuilder.build();
ClientHttpConnector connector = new HttpComponentsClientHttpConnector(client);
val client = HttpAsyncClients.custom().apply {
}.build()
val connector = HttpComponentsClientHttpConnector(client)
