For the latest stable version, please use Spring Framework 6.2.4! |
The BeanFactory
API
The BeanFactory
API provides the underlying basis for Spring’s IoC functionality.
Its specific contracts are mostly used in integration with other parts of Spring and
related third-party frameworks, and its DefaultListableBeanFactory
implementation
is a key delegate within the higher-level GenericApplicationContext
container.
BeanFactory
and related interfaces (such as BeanFactoryAware
, InitializingBean
DisposableBean
) are important integration points for other framework components.
By not requiring any annotations or even reflection, they allow for very efficient
interaction between the container and its components. Application-level beans may
use the same callback interfaces but typically prefer declarative dependency
injection instead, either through annotations or through programmatic configuration.
Note that the core BeanFactory
API level and its DefaultListableBeanFactory
implementation do not make assumptions about the configuration format or any
component annotations to be used. All of these flavors come in through extensions
(such as XmlBeanDefinitionReader
and AutowiredAnnotationBeanPostProcessor
) and
operate on shared BeanDefinition
objects as a core metadata representation.
This is the essence of what makes Spring’s container so flexible and extensible.
BeanFactory
or ApplicationContext
This section explains the differences between the BeanFactory
and
ApplicationContext
container levels and the implications on bootstrapping.
You should use an ApplicationContext
unless you have a good reason for not doing so, with
and its subclass AnnotationConfigApplicationContext
as the common implementations for custom bootstrapping. These are the primary entry
points to Spring’s core container for all common purposes: loading of configuration
files, triggering a classpath scan, programmatically registering bean definitions
and annotated classes, and (as of 5.0) registering functional bean definitions.
Because an ApplicationContext
includes all the functionality of a BeanFactory
, it is
generally recommended over a plain BeanFactory
, except for scenarios where full
control over bean processing is needed. Within an ApplicationContext
(such as the
implementation), several kinds of beans are detected
by convention (that is, by bean name or by bean type — in particular, post-processors),
while a plain DefaultListableBeanFactory
is agnostic about any special beans.
For many extended container features, such as annotation processing and AOP proxying,
the BeanPostProcessor
extension point is essential.
If you use only a plain DefaultListableBeanFactory
, such post-processors do not
get detected and activated by default. This situation could be confusing, because
nothing is actually wrong with your bean configuration. Rather, in such a scenario,
the container needs to be fully bootstrapped through additional setup.
The following table lists features provided by the BeanFactory
and
ApplicationContext
interfaces and implementations.
Feature | BeanFactory |
ApplicationContext |
Bean instantiation/wiring |
Yes |
Yes |
Integrated lifecycle management |
No |
Yes |
Automatic |
No |
Yes |
Automatic |
No |
Yes |
Convenient |
No |
Yes |
Built-in |
No |
Yes |
To explicitly register a bean post-processor with a DefaultListableBeanFactory
you need to programmatically call addBeanPostProcessor
, as the following example shows:
Java
Kotlin
DefaultListableBeanFactory factory = new DefaultListableBeanFactory();
// populate the factory with bean definitions
// now register any needed BeanPostProcessor instances
factory.addBeanPostProcessor(new AutowiredAnnotationBeanPostProcessor());
factory.addBeanPostProcessor(new MyBeanPostProcessor());
// now start using the factory
val factory = DefaultListableBeanFactory()
factory.addBeanPostProcessor(AutowiredAnnotationBeanPostProcessor())
factory.addBeanPostProcessor(MyBeanPostProcessor())
To apply a BeanFactoryPostProcessor
to a plain DefaultListableBeanFactory
you need to call its postProcessBeanFactory
method, as the following example shows:
Java
Kotlin
XmlBeanDefinitionReader reader = new XmlBeanDefinitionReader(factory);
reader.loadBeanDefinitions(new FileSystemResource("beans.xml"));
// bring in some property values from a Properties file
PropertySourcesPlaceholderConfigurer cfg = new PropertySourcesPlaceholderConfigurer();
cfg.setLocation(new FileSystemResource("jdbc.properties"));
// now actually do the replacement
cfg.postProcessBeanFactory(factory);
val reader = XmlBeanDefinitionReader(factory)
reader.loadBeanDefinitions(FileSystemResource("beans.xml"))
val cfg = PropertySourcesPlaceholderConfigurer()
cfg.setLocation(FileSystemResource("jdbc.properties"))
In both cases, the explicit registration steps are inconvenient, which is
why the various ApplicationContext
variants are preferred over a plain
in Spring-backed applications, especially when
relying on BeanFactoryPostProcessor
and BeanPostProcessor
instances for extended
container functionality in a typical enterprise setup.
An |
