For the latest stable version, please use Spring Framework 6.2.6!spring-doc.cn
Observability Support
Micrometer defines an Observation concept that enables both Metrics and Traces in applications. Metrics support offers a way to create timers, gauges, or counters for collecting statistics about the runtime behavior of your application. Metrics can help you to track error rates, usage patterns, performance, and more. Traces provide a holistic view of an entire system, crossing application boundaries; you can zoom in on particular user requests and follow their entire completion across applications.spring-doc.cn
Spring Framework instruments various parts of its own codebase to publish observations if an ObservationRegistry is configured. You can learn more about configuring the observability infrastructure in Spring Boot.spring-doc.cn
List of produced Observations
Spring Framework instruments various features for observability. As outlined at the beginning of this section, observations can generate timer Metrics and/or Traces depending on the configuration.spring-doc.cn
Table 1. Observations produced by Spring Framework
Observation name Description
"http.client.requests"spring-doc.cn
Time spent for HTTP client exchangesspring-doc.cn
"http.server.requests"spring-doc.cn
Processing time for HTTP server exchanges at the Framework levelspring-doc.cn
Observations are using Micrometer’s official naming convention, but Metrics names will be automatically converted to the format preferred by the monitoring system backend (Prometheus, Atlas, Graphite, InfluxDB…​).
Micrometer Observation concepts
If you are not familiar with Micrometer Observation, here’s a quick summary of the concepts you should know about.spring-doc.cn
  • Observation is the actual recording of something happening in your application. This is processed by ObservationHandler implementations to produce metrics or traces.spring-doc.cn
  • Each observation has a corresponding ObservationContext implementation; this type holds all the relevant information for extracting metadata for it. In the case of an HTTP server observation, the context implementation could hold the HTTP request, the HTTP response, any exception thrown during processing, and so forth.spring-doc.cn
  • Each Observation holds KeyValues metadata. In the case of an HTTP server observation, this could be the HTTP request method, the HTTP response status, and so forth. This metadata is contributed by ObservationConvention implementations which should declare the type of ObservationContext they support.spring-doc.cn
  • KeyValues are said to be "low cardinality" if there is a low, bounded number of possible values for the KeyValue tuple (HTTP method is a good example). Low cardinality values are contributed to metrics only. Conversely, "high cardinality" values are unbounded (for example, HTTP request URIs) and are only contributed to traces.spring-doc.cn
  • An ObservationDocumentation documents all observations in a particular domain, listing the expected key names and their meaning.spring-doc.cn
Configuring Observations
Global configuration options are available at the ObservationRegistry#observationConfig() level. Each instrumented component will provide two extension points:spring-doc.cn
  • setting the ObservationRegistry; if not set, observations will not be recorded and will be no-opsspring-doc.cn
  • providing a custom ObservationConvention to change the default observation name and extracted KeyValuesspring-doc.cn
Using custom Observation conventions
Let’s take the example of the Spring MVC "http.server.requests" metrics instrumentation with the ServerHttpObservationFilter. This observation uses a ServerRequestObservationConvention with a ServerRequestObservationContext; custom conventions can be configured on the Servlet filter. If you would like to customize the metadata produced with the observation, you can extend the DefaultServerRequestObservationConvention for your requirements:spring-doc.cn
import io.micrometer.common.KeyValue;
import io.micrometer.common.KeyValues;
import org.springframework.http.server.observation.DefaultServerRequestObservationConvention;
import org.springframework.http.server.observation.ServerRequestObservationContext;
public class ExtendedServerRequestObservationConvention extends DefaultServerRequestObservationConvention {
	public KeyValues getLowCardinalityKeyValues(ServerRequestObservationContext context) {
		// here, we just want to have an additional KeyValue to the observation, keeping the default values
		return super.getLowCardinalityKeyValues(context).and(custom(context));
	private KeyValue custom(ServerRequestObservationContext context) {
		return KeyValue.of("custom.method", context.getCarrier().getMethod());
If you want full control, you can implement the entire convention contract for the observation you’re interested in:spring-doc.cn
import org.springframework.http.server.observation.ServerHttpObservationDocumentation;
import org.springframework.http.server.observation.ServerRequestObservationConvention;
public class CustomServerRequestObservationConvention implements ServerRequestObservationConvention {
	public String getName() {
		// will be used as the metric name
		return "http.server.requests";
	public String getContextualName(ServerRequestObservationContext context) {
		// will be used for the trace name
		return "http " + context.getCarrier().getMethod().toLowerCase();
		return KeyValues.of(method(context), status(context), exception(context));
	public KeyValues getHighCardinalityKeyValues(ServerRequestObservationContext context) {
		return KeyValues.of(httpUrl(context));
	private KeyValue method(ServerRequestObservationContext context) {
		// You should reuse as much as possible the corresponding ObservationDocumentation for key names
		return KeyValue.of(ServerHttpObservationDocumentation.LowCardinalityKeyNames.METHOD, context.getCarrier().getMethod());
	// status(), exception(), httpUrl()...
	private KeyValue status(ServerRequestObservationContext context) {
		return KeyValue.of(ServerHttpObservationDocumentation.LowCardinalityKeyNames.STATUS, String.valueOf(context.getResponse().getStatus()));
	private KeyValue exception(ServerRequestObservationContext context) {
		String exception = (context.getError() != null) ? context.getError().getClass().getSimpleName() : KeyValue.NONE_VALUE;
		return KeyValue.of(ServerHttpObservationDocumentation.LowCardinalityKeyNames.EXCEPTION, exception);
	private KeyValue httpUrl(ServerRequestObservationContext context) {
		return KeyValue.of(ServerHttpObservationDocumentation.HighCardinalityKeyNames.HTTP_URL, context.getCarrier().getRequestURI());
You can also achieve similar goals using a custom ObservationFilter – adding or removing key values for an observation. Filters do not replace the default convention and are used as a post-processing component.spring-doc.cn
import io.micrometer.observation.Observation;
import io.micrometer.observation.ObservationFilter;
public class ServerRequestObservationFilter implements ObservationFilter {
	public Observation.Context map(Observation.Context context) {
		if (context instanceof ServerRequestObservationContext serverContext) {
			context.setName("custom.observation.name");
			context.addLowCardinalityKeyValue(KeyValue.of("project", "spring"));
			String customAttribute = (String) serverContext.getCarrier().getAttribute("customAttribute");
			context.addLowCardinalityKeyValue(KeyValue.of("custom.attribute", customAttribute));
		return context;
You can configure ObservationFilter instances on the ObservationRegistry.spring-doc.cn
HTTP Server instrumentation
HTTP server exchange observations are created with the name "http.server.requests" for Servlet and Reactive applications.spring-doc.cn
Servlet applications
Applications need to configure the org.springframework.web.filter.ServerHttpObservationFilter Servlet filter in their application. It uses the org.springframework.http.server.observation.DefaultServerRequestObservationConvention by default, backed by the ServerRequestObservationContext.spring-doc.cn
This will only record an observation as an error if the Exception has not been handled by the web framework and has bubbled up to the Servlet filter. Typically, all exceptions handled by Spring MVC’s @ExceptionHandler and ProblemDetail support will not be recorded with the observation. You can, at any point during request processing, set the error field on the ObservationContext yourself:spring-doc.cn
import jakarta.servlet.http.HttpServletRequest;
import org.springframework.http.ResponseEntity;
import org.springframework.stereotype.Controller;
import org.springframework.web.bind.annotation.ExceptionHandler;
import org.springframework.web.filter.ServerHttpObservationFilter;
@Controller
public class UserController {
	@ExceptionHandler(MissingUserException.class)
	ResponseEntity<Void> handleMissingUser(HttpServletRequest request, MissingUserException exception) {
		// We want to record this exception with the observation
		ServerHttpObservationFilter.findObservationContext(request)
				.ifPresent(context -> context.setError(exception));
		return ResponseEntity.notFound().build();
	static class MissingUserException extends RuntimeException {
Because the instrumentation is done at the Servlet Filter level, the observation scope only covers the filters ordered after this one as well as the handling of the request. Typically, Servlet container error handling is performed at a lower level and won’t have any active observation or span. For this use case, a container-specific implementation is required, such as a org.apache.catalina.Valve for Tomcat; this is outside of the scope of this project.
By default, the following KeyValues are created:spring-doc.cn
Table 2. Low cardinality Keys
Descriptionspring-doc.cn
exception (required)spring-doc.cn
Name of the exception thrown during the exchange, or KeyValue#NONE_VALUE} if no exception happened.spring-doc.cn
method (required)spring-doc.cn
Name of HTTP request method or "none" if not a well-known method.spring-doc.cn
outcome (required)spring-doc.cn
Outcome of the HTTP server exchange.spring-doc.cn
status (required)spring-doc.cn
HTTP response raw status code, or "UNKNOWN" if no response was created.spring-doc.cn
uri (required)spring-doc.cn
URI pattern for the matching handler if available, falling back to REDIRECTION for 3xx responses, NOT_FOUND for 404 responses, root for requests with no path info, and UNKNOWN for all other requests.spring-doc.cn
Table 3. High cardinality Keys
http.url (required)spring-doc.cn
HTTP request URI.spring-doc.cn
Applications need to configure the org.springframework.web.filter.reactive.ServerHttpObservationFilter reactive WebFilter in their application. It uses the org.springframework.http.server.reactive.observation.DefaultServerRequestObservationConvention by default, backed by the ServerRequestObservationContext.spring-doc.cn
This will only record an observation as an error if the Exception has not been handled by the web framework and has bubbled up to the WebFilter. Typically, all exceptions handled by Spring WebFlux’s @ExceptionHandler and ProblemDetail support will not be recorded with the observation. You can, at any point during request processing, set the error field on the ObservationContext yourself:spring-doc.cn
import org.springframework.web.filter.reactive.ServerHttpObservationFilter;
import org.springframework.web.server.ServerWebExchange;
@Controller
	ResponseEntity<Void> handleMissingUser(ServerWebExchange exchange, MissingUserException exception) {
		ServerHttpObservationFilter.findObservationContext(exchange)
Table 4. Low cardinality Keys
Name of the exception thrown during the exchange, or "none" if no exception happened.spring-doc.cn
Table 5. High cardinality Keys
HTTP Client Instrumentation
HTTP client exchange observations are created with the name "http.client.requests" for blocking and reactive clients. Unlike their server counterparts, the instrumentation is implemented directly in the client so the only required step is to configure an ObservationRegistry on the client.spring-doc.cn
RestTemplate
Applications must configure an ObservationRegistry on RestTemplate instances to enable the instrumentation; without that, observations are "no-ops". Spring Boot will auto-configure RestTemplateBuilder beans with the observation registry already set.spring-doc.cn
Instrumentation uses the org.springframework.http.client.observation.ClientRequestObservationConvention by default, backed by the ClientRequestObservationContext.spring-doc.cn
Table 6. Low cardinality Keys
URI template used for HTTP request, or "none" if none was provided. Only the path part of the URI is considered.spring-doc.cn
client.name (required)spring-doc.cn
Client name derived from the request URI host.spring-doc.cn
HTTP response raw status code, or "IO_ERROR" in case of IOException, or "CLIENT_ERROR" if no response was received.spring-doc.cn
Outcome of the HTTP client exchange.spring-doc.cn
Table 7. High cardinality Keys
WebClient
Applications must configure an ObservationRegistry on the WebClient builder to enable the instrumentation; without that, observations are "no-ops". Spring Boot will auto-configure WebClient.Builder beans with the observation registry already set.spring-doc.cn
Instrumentation uses the org.springframework.web.reactive.function.client.ClientRequestObservationConvention by default, backed by the ClientRequestObservationContext.spring-doc.cn
Table 8. Low cardinality Keys
Table 9. High cardinality Keys
