For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
View Controllers
This is a shortcut for defining a ParameterizableViewController that immediately forwards to a view when invoked. You can use it in static cases when there is no Java controller logic to run before the view generates the response.spring-doc.cn
The following example of Java configuration forwards a request for / to a view called home:spring-doc.cn
@EnableWebMvc
	public void addViewControllers(ViewControllerRegistry registry) {
		registry.addViewController("/").setViewName("home");
@EnableWebMvc
	override fun addViewControllers(registry: ViewControllerRegistry) {
The following example achieves the same thing as the preceding example, but with XML, by using the <mvc:view-controller> element:spring-doc.cn
<mvc:view-controller path="/" view-name="home"/>
If an @RequestMapping method is mapped to a URL for any HTTP method then a view controller cannot be used to handle the same URL. This is because a match by URL to an annotated controller is considered a strong enough indication of endpoint ownership so that a 405 (METHOD_NOT_ALLOWED), a 415 (UNSUPPORTED_MEDIA_TYPE), or similar response can be sent to the client to help with debugging. For this reason it is recommended to avoid splitting URL handling across an annotated controller and a view controller.spring-doc.cn
