For the latest stable version, please use Spring Framework 6.2.4! |
Pointcut API in Spring
This section describes how Spring handles the crucial pointcut concept.
Concepts
Spring’s pointcut model enables pointcut reuse independent of advice types. You can target different advice with the same pointcut.
The org.springframework.aop.Pointcut
interface is the central interface, used to
target advice to particular classes and methods. The complete interface follows:
public interface Pointcut {
ClassFilter getClassFilter();
MethodMatcher getMethodMatcher();
Splitting the Pointcut
interface into two parts allows reuse of class and method
matching parts and fine-grained composition operations (such as performing a “union”
with another method matcher).
The ClassFilter
interface is used to restrict the pointcut to a given set of target
classes. If the matches()
method always returns true, all target classes are
matched. The following listing shows the ClassFilter
interface definition:
public interface ClassFilter {
boolean matches(Class clazz);
The MethodMatcher
interface is normally more important. The complete interface follows:
public interface MethodMatcher {
boolean matches(Method m, Class<?> targetClass);
boolean isRuntime();
boolean matches(Method m, Class<?> targetClass, Object... args);
The matches(Method, Class)
method is used to test whether this pointcut ever
matches a given method on a target class. This evaluation can be performed when an AOP
proxy is created to avoid the need for a test on every method invocation. If the
two-argument matches
method returns true
for a given method, and the isRuntime()
method for the MethodMatcher returns true
, the three-argument matches method is
invoked on every method invocation. This lets a pointcut look at the arguments passed
to the method invocation immediately before the target advice starts.
Most MethodMatcher
implementations are static, meaning that their isRuntime()
method
returns false
. In this case, the three-argument matches
method is never invoked.
If possible, try to make pointcuts static, allowing the AOP framework to cache the results of pointcut evaluation when an AOP proxy is created. |
Operations on Pointcuts
Spring supports operations (notably, union and intersection) on pointcuts.
Union means the methods that either pointcut matches.
Intersection means the methods that both pointcuts match.
Union is usually more useful.
You can compose pointcuts by using the static methods in the
org.springframework.aop.support.Pointcuts
class or by using the
ComposablePointcut
class in the same package. However, using AspectJ pointcut
expressions is usually a simpler approach.
AspectJ Expression Pointcuts
Since 2.0, the most important type of pointcut used by Spring is
org.springframework.aop.aspectj.AspectJExpressionPointcut
. This is a pointcut that
uses an AspectJ-supplied library to parse an AspectJ pointcut expression string.
See the previous chapter for a discussion of supported AspectJ pointcut primitives.
Convenience Pointcut Implementations
Spring provides several convenient pointcut implementations. You can use some of them directly; others are intended to be subclassed in application-specific pointcuts.
Static Pointcuts
Static pointcuts are based on the method and the target class and cannot take into account the method’s arguments. Static pointcuts suffice — and are best — for most usages. Spring can evaluate a static pointcut only once, when a method is first invoked. After that, there is no need to evaluate the pointcut again with each method invocation.
The rest of this section describes some of the static pointcut implementations that are included with Spring.
Regular Expression Pointcuts
One obvious way to specify static pointcuts is regular expressions. Several AOP
frameworks besides Spring make this possible.
org.springframework.aop.support.JdkRegexpMethodPointcut
is a generic regular
expression pointcut that uses the regular expression support in the JDK.
With the JdkRegexpMethodPointcut
class, you can provide a list of pattern strings.
If any of these is a match, the pointcut evaluates to true
. (As a consequence,
the resulting pointcut is effectively the union of the specified patterns.)
The following example shows how to use JdkRegexpMethodPointcut
<bean id="settersAndAbsquatulatePointcut"
class="org.springframework.aop.support.JdkRegexpMethodPointcut">
<property name="patterns">
<list>
<value>.*set.*</value>
<value>.*absquatulate</value>
</list>
</property>
</bean>
Spring provides a convenience class named RegexpMethodPointcutAdvisor
, which lets us
also reference an Advice
(remember that an Advice
can be an interceptor, before advice,
throws advice, and others). Behind the scenes, Spring uses a JdkRegexpMethodPointcut
Using RegexpMethodPointcutAdvisor
simplifies wiring, as the one bean encapsulates both
pointcut and advice, as the following example shows:
<bean id="settersAndAbsquatulateAdvisor"
class="org.springframework.aop.support.RegexpMethodPointcutAdvisor">
<property name="advice">
<ref bean="beanNameOfAopAllianceInterceptor"/>
</property>
<list>
</list>
</property>
</bean>
You can use RegexpMethodPointcutAdvisor
with any Advice
type.
Dynamic pointcuts
Dynamic pointcuts are costlier to evaluate than static pointcuts. They take into account method arguments as well as static information. This means that they must be evaluated with every method invocation and that the result cannot be cached, as arguments will vary.
The main example is the control flow
pointcut.
Control Flow Pointcuts
Spring control flow pointcuts are conceptually similar to AspectJ cflow
pointcuts,
although less powerful. (There is currently no way to specify that a pointcut runs
below a join point matched by another pointcut.) A control flow pointcut matches the
current call stack. For example, it might fire if the join point was invoked by a method
in the com.mycompany.web
package or by the SomeCaller
class. Control flow pointcuts
are specified by using the org.springframework.aop.support.ControlFlowPointcut
class.
Control flow pointcuts are significantly more expensive to evaluate at runtime than even other dynamic pointcuts. In Java 1.4, the cost is about five times that of other dynamic pointcuts. |
Pointcut Superclasses
Spring provides useful pointcut superclasses to help you to implement your own pointcuts.
Because static pointcuts are most useful, you should probably subclass
StaticMethodMatcherPointcut
. This requires implementing only one
abstract method (although you can override other methods to customize behavior). The
following example shows how to subclass StaticMethodMatcherPointcut
Java
Kotlin
class TestStaticPointcut extends StaticMethodMatcherPointcut {
public boolean matches(Method m, Class targetClass) {
// return true if custom criteria match
class TestStaticPointcut : StaticMethodMatcherPointcut() {
override fun matches(method: Method, targetClass: Class<*>): Boolean {
There are also superclasses for dynamic pointcuts. You can use custom pointcuts with any advice type.
Custom Pointcuts
Because pointcuts in Spring AOP are Java classes rather than language features (as in AspectJ), you can declare custom pointcuts, whether static or dynamic. Custom pointcuts in Spring can be arbitrarily complex. However, we recommend using the AspectJ pointcut expression language, if you can.
Later versions of Spring may offer support for “semantic pointcuts” as offered by JAC — for example, “all methods that change instance variables in the target object.” |
