For the latest stable version, please use Spring Framework 6.2.0! |
Request Mapping
The @RequestMapping
annotation is used to map requests to controllers methods. It has
various attributes to match by URL, HTTP method, request parameters, headers, and media
types. You can use it at the class level to express shared mappings or at the method level
to narrow down to a specific endpoint mapping.
There are also HTTP method specific shortcut variants of @RequestMapping
@GetMapping
@PostMapping
@PutMapping
@DeleteMapping
@PatchMapping
The preceding annotations are Custom Annotations that are provided
because, arguably, most controller methods should be mapped to a specific HTTP method versus
using @RequestMapping
, which, by default, matches to all HTTP methods. At the same time, a
@RequestMapping
is still needed at the class level to express shared mappings.
The following example uses type and method level mappings:
Java
Kotlin
@RestController
@RequestMapping("/persons")
class PersonController {
@GetMapping("/{id}")
public Person getPerson(@PathVariable Long id) {
@PostMapping
@ResponseStatus(HttpStatus.CREATED)
public void add(@RequestBody Person person) {
@RestController
fun getPerson(@PathVariable id: Long): Person {
@PostMapping
fun add(@RequestBody person: Person) {
URI Patterns
You can map requests by using glob patterns and wildcards:
Pattern | Description | Example |
Matches one character |
Matches zero or more characters within a path segment |
Matches zero or more path segments until the end of the path |
Matches a path segment and captures it as a variable named "name" |
Matches the regexp |
Matches zero or more path segments until the end of the path and captures it as a variable named "path" |
Captured URI variables can be accessed with @PathVariable
, as the following example shows:
Java
Kotlin
@GetMapping("/owners/{ownerId}/pets/{petId}")
public Pet findPet(@PathVariable Long ownerId, @PathVariable Long petId) {
fun findPet(@PathVariable ownerId: Long, @PathVariable petId: Long): Pet {
You can declare URI variables at the class and method levels, as the following example shows:
Java
Kotlin
@Controller
@RequestMapping("/owners/{ownerId}") (1)
public class OwnerController {
@GetMapping("/pets/{petId}") (2)
1 | Class-level URI mapping. |
2 | Method-level URI mapping. |
@Controller
URI variables are automatically converted to the appropriate type or a TypeMismatchException
is raised. Simple types (int
, long
, Date
, and so on) are supported by default and you can
register support for any other data type.
See Type Conversion and DataBinder
URI variables can be named explicitly (for example, @PathVariable("customId")
), but you can
leave that detail out if the names are the same and you compile your code with the -parameters
compiler flag.
The syntax {*varName}
declares a URI variable that matches zero or more remaining path
segments. For example /resources/{*path}
matches all files under /resources/
, and the
"path"
variable captures the complete path under /resources
The syntax {varName:regex}
declares a URI variable with a regular expression that has the
syntax: {varName:regex}
. For example, given a URL of /spring-web-3.0.5.jar
, the following method
extracts the name, version, and file extension:
Java
Kotlin
@GetMapping("/{name:[a-z-]+}-{version:\\d\\.\\d\\.\\d}{ext:\\.[a-z]+}")
public void handle(@PathVariable String version, @PathVariable String ext) {
fun handle(@PathVariable version: String, @PathVariable ext: String) {
URI path patterns can also have embedded ${…}
placeholders that are resolved on startup
through PropertySourcesPlaceholderConfigurer
against local, system, environment, and
other property sources. You can use this to, for example, parameterize a base URL based on
some external configuration.
Spring WebFlux uses PathPattern and the PathPatternParser for URI path matching support.
Both classes are located in spring-web and are expressly designed for use with HTTP URL
paths in web applications where a large number of URI path patterns are matched at runtime.
Spring WebFlux does not support suffix pattern matching — unlike Spring MVC, where a
mapping such as /person
also matches to /person.*
. For URL-based content
negotiation, if needed, we recommend using a query parameter, which is simpler, more
explicit, and less vulnerable to URL path based exploits.
Pattern Comparison
When multiple patterns match a URL, they must be compared to find the best match. This is done
with PathPattern.SPECIFICITY_COMPARATOR
, which looks for patterns that are more specific.
For every pattern, a score is computed, based on the number of URI variables and wildcards, where a URI variable scores lower than a wildcard. A pattern with a lower total score wins. If two patterns have the same score, the longer is chosen.
Catch-all patterns (for example, **
, {*varName}
) are excluded from the scoring and are always
sorted last instead. If two patterns are both catch-all, the longer is chosen.
Consumable Media Types
You can narrow the request mapping based on the Content-Type
of the request,
Java
Kotlin
@PostMapping(path = "/pets", consumes = "application/json")
public void addPet(@RequestBody Pet pet) {
@PostMapping("/pets", consumes = ["application/json"])
fun addPet(@RequestBody pet: Pet) {
The consumes attribute also supports negation expressions — for example, !text/plain
means any
content type other than text/plain
You can declare a shared consumes
attribute at the class level. Unlike most other request
mapping attributes, however, when used at the class level, a method-level consumes
attribute
overrides rather than extends the class-level declaration.
MediaType provides constants for commonly used media types — for example,
APPLICATION_JSON_VALUE and APPLICATION_XML_VALUE .
Producible Media Types
You can narrow the request mapping based on the Accept
request header and the list of
content types that a controller method produces, as the following example shows:
Java
Kotlin
@GetMapping(path = "/pets/{petId}", produces = "application/json")
@ResponseBody
public Pet getPet(@PathVariable String petId) {
@GetMapping("/pets/{petId}", produces = ["application/json"])
@ResponseBody
fun getPet(@PathVariable petId: String): Pet {
The media type can specify a character set. Negated expressions are supported — for example,
!text/plain
means any content type other than text/plain
You can declare a shared produces
mapping attributes, however, when used at the class level, a method-level produces
attribute
overrides rather than extend the class level declaration.
MediaType provides constants for commonly used media types — e.g.
APPLICATION_JSON_VALUE , APPLICATION_XML_VALUE .
Parameters and Headers
You can narrow request mappings based on query parameter conditions. You can test for the
presence of a query parameter (myParam
), for its absence (!myParam
), or for a
specific value (myParam=myValue
). The following examples tests for a parameter with a value:
Java
Kotlin
@GetMapping(path = "/pets/{petId}", params = "myParam=myValue") (1)
public void findPet(@PathVariable String petId) {
1 | Check that myParam equals myValue . |
@GetMapping("/pets/{petId}", params = ["myParam=myValue"]) (1)
fun findPet(@PathVariable petId: String) {
You can also use the same with request header conditions, as the following example shows:
Java
Kotlin
@GetMapping(path = "/pets/{petId}", headers = "myHeader=myValue") (1)
1 | Check that myHeader equals myValue . |
@GetMapping("/pets/{petId}", headers = ["myHeader=myValue"]) (1)
HTTP HEAD, OPTIONS
@GetMapping
and @RequestMapping(method=HttpMethod.GET)
support HTTP HEAD
transparently for request mapping purposes. Controller methods need not change.
A response wrapper, applied in the HttpHandler
server adapter, ensures a Content-Length
header is set to the number of bytes written without actually writing to the response.
By default, HTTP OPTIONS is handled by setting the Allow
response header to the list of HTTP
methods listed in all @RequestMapping
methods with matching URL patterns.
For a @RequestMapping
without HTTP method declarations, the Allow
header is set to
GET,HEAD,POST,PUT,PATCH,DELETE,OPTIONS
. Controller methods should always declare the
supported HTTP methods (for example, by using the HTTP method specific variants — @GetMapping
, @PostMapping
, and others).
You can explicitly map a @RequestMapping
method to HTTP HEAD and HTTP OPTIONS, but that
is not necessary in the common case.
Custom Annotations
Spring WebFlux supports the use of composed annotations
for request mapping. Those are annotations that are themselves meta-annotated with
@RequestMapping
and composed to redeclare a subset (or all) of the @RequestMapping
attributes with a narrower, more specific purpose.
@GetMapping
, @PostMapping
, @PutMapping
, @DeleteMapping
, and @PatchMapping
are
examples of composed annotations. They are provided, because, arguably, most
controller methods should be mapped to a specific HTTP method versus using @RequestMapping
which, by default, matches to all HTTP methods. If you need an example of composed
annotations, look at how those are declared.
Spring WebFlux also supports custom request mapping attributes with custom request matching
logic. This is a more advanced option that requires sub-classing
RequestMappingHandlerMapping
and overriding the getCustomMethodCondition
method, where
you can check the custom attribute and return your own RequestCondition
Explicit Registrations
You can programmatically register Handler methods, which can be used for dynamic registrations or for advanced cases, such as different instances of the same handler under different URLs. The following example shows how to do so:
Java
Kotlin
public class MyConfig {
@Autowired
public void setHandlerMapping(RequestMappingHandlerMapping mapping, UserHandler handler) (1)
throws NoSuchMethodException {
RequestMappingInfo info = RequestMappingInfo
.paths("/user/{id}").methods(RequestMethod.GET).build(); (2)
Method method = UserHandler.class.getMethod("getUser", Long.class); (3)
mapping.registerMapping(info, handler, method); (4)
1 | Inject target handlers and the handler mapping for controllers. |
2 | Prepare the request mapping metadata. |
3 | Get the handler method. |
4 | Add the registration. |
class MyConfig {
@Autowired
fun setHandlerMapping(mapping: RequestMappingHandlerMapping, handler: UserHandler) { (1)
val info = RequestMappingInfo.paths("/user/{id}").methods(RequestMethod.GET).build() (2)
val method = UserHandler::class.java.getMethod("getUser", Long::class.java) (3)
mapping.registerMapping(info, handler, method) (4)
