For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Testing
To test code that uses the WebClient, you can use a mock web server, such as the OkHttp MockWebServer. To see an example of its use, check out WebClientIntegrationTests in the Spring Framework test suite or the static-server sample in the OkHttp repository.spring-doc.cn
