For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
@SqlConfig
@SqlConfig defines metadata that is used to determine how to parse and run SQL scripts configured with the @Sql annotation. The following example shows how to use it:spring-doc.cn
@Test
@Sql(
	scripts = "/test-user-data.sql",
	config = @SqlConfig(commentPrefix = "`", separator = "@@") (1)
void userTest() {
	// run code that relies on the test data
1 Set the comment prefix and the separator in SQL scripts.
@Test
@Sql("/test-user-data.sql", config = SqlConfig(commentPrefix = "`", separator = "@@")) (1)
fun userTest() {
