For the latest stable version, please use Spring Framework 6.2.4! |
@WebAppConfiguration
is a class-level annotation that you can use to declare that the
ApplicationContext
loaded for an integration test should be a WebApplicationContext
The mere presence of @WebAppConfiguration
on a test class ensures that a
is loaded for the test, using the default value of
"file:src/main/webapp"
for the path to the root of the web application (that is, the
resource base path). The resource base path is used behind the scenes to create a
MockServletContext
, which serves as the ServletContext
for the test’s
The following example shows how to use the @WebAppConfiguration
annotation:
Java
Kotlin
@ContextConfiguration
@WebAppConfiguration (1)
class WebAppTests {
// class body...
1 | The @WebAppConfiguration annotation. |
class WebAppTests {
// class body...
To override the default, you can specify a different base resource path by using the
implicit value
attribute. Both classpath:
and file:
resource prefixes are
supported. If no resource prefix is supplied, the path is assumed to be a file system
resource. The following example shows how to specify a classpath resource:
Java
Kotlin
@WebAppConfiguration("classpath:test-web-resources") (1)
class WebAppTests {
// class body...
1 | Specifying a classpath resource. |
class WebAppTests {
// class body...
Note that @WebAppConfiguration
must be used in conjunction with
, either within a single test class or within a test class
hierarchy. See the
javadoc for further details.
