For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
@TestPropertySource
@TestPropertySource is a class-level annotation that you can use to configure the locations of properties files and inlined properties to be added to the set of PropertySources in the Environment for an ApplicationContext loaded for an integration test.spring-doc.cn
The following example demonstrates how to declare a properties file from the classpath:spring-doc.cn
@ContextConfiguration
@TestPropertySource("/test.properties") (1)
class MyIntegrationTests {
	// class body...
1 Get properties from test.properties in the root of the classpath.
	// class body...
The following example demonstrates how to declare inlined properties:spring-doc.cn
@TestPropertySource(properties = { "timezone = GMT", "port: 4242" }) (1)
	// class body...
1 Declare timezone and port properties.
@TestPropertySource(properties = ["timezone = GMT", "port: 4242"]) (1)
	// class body...
