For the latest stable version, please use Spring Framework 6.2.4! |
@SqlMergeMode
@SqlMergeMode
is used to annotate a test class or test method to configure whether
method-level @Sql
declarations are merged with class-level @Sql
declarations. If
@SqlMergeMode
is not declared on a test class or test method, the OVERRIDE
merge mode
will be used by default. With the OVERRIDE
mode, method-level @Sql
declarations will
effectively override class-level @Sql
declarations.
Note that a method-level @SqlMergeMode
declaration overrides a class-level declaration.
The following example shows how to use @SqlMergeMode
at the class level.
Java
Kotlin
@SpringJUnitConfig(TestConfig.class)
@Sql("/test-schema.sql")
@SqlMergeMode(MERGE) (1)
class UserTests {
@Test
@Sql("/user-test-data-001.sql")
void standardUserProfile() {
// run code that relies on test data set 001
1 | Set the @Sql merge mode to MERGE for all test methods in the class. |
@SpringJUnitConfig(TestConfig::class)
class UserTests {
@Test
fun standardUserProfile() {
at the method level.
Java
Kotlin
class UserTests {
@Test
1 | Set the @Sql merge mode to MERGE for a specific test method. |
class UserTests {
@Test
