For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
@Commit
@Commit indicates that the transaction for a transactional test method should be committed after the test method has completed. You can use @Commit as a direct replacement for @Rollback(false) to more explicitly convey the intent of the code. Analogous to @Rollback, @Commit can also be declared as a class-level or method-level annotation.spring-doc.cn
The following example shows how to use the @Commit annotation:spring-doc.cn
@Commit (1)
@Test
void testProcessWithoutRollback() {
1 Commit the result of the test to the database.
@Commit (1)
@Test
fun testProcessWithoutRollback() {
