For the latest stable version, please use Spring Framework 6.2.4! |
@ContextConfiguration
defines class-level metadata that is used to determine how to
load and configure an ApplicationContext
for integration tests. Specifically,
declares the application context resource locations
or the
component classes
used to load the context.
Resource locations are typically XML configuration files or Groovy scripts located in the
classpath, while component classes are typically @Configuration
classes. However,
resource locations can also refer to files and scripts in the file system, and component
classes can be @Component
classes, @Service
classes, and so on. See
Component Classes for further details.
The following example shows a @ContextConfiguration
annotation that refers to an XML
file:
Java
Kotlin
@ContextConfiguration("/test-config.xml") (1)
class XmlApplicationContextTests {
// class body...
1 | Referring to an XML file. |
// class body...
annotation that refers to a class:
Java
Kotlin
@ContextConfiguration(classes = TestConfig.class) (1)
class ConfigClassApplicationContextTests {
// class body...
1 | Referring to a class. |
@ContextConfiguration(classes = [TestConfig::class]) (1)
// class body...
As an alternative or in addition to declaring resource locations or component classes,
you can use @ContextConfiguration
to declare ApplicationContextInitializer
classes.
The following example shows such a case:
Java
Kotlin
@ContextConfiguration(initializers = CustomContextInitializer.class) (1)
class ContextInitializerTests {
// class body...
1 | Declaring an initializer class. |
@ContextConfiguration(initializers = [CustomContextInitializer::class]) (1)
// class body...
You can optionally use @ContextConfiguration
to declare the ContextLoader
strategy as
well. Note, however, that you typically do not need to explicitly configure the loader,
since the default loader supports initializers
and either resource locations
or
component classes
The following example uses both a location and a loader:
Java
Kotlin
@ContextConfiguration(locations = "/test-context.xml", loader = CustomContextLoader.class) (1)
class CustomLoaderXmlApplicationContextTests {
// class body...
1 | Configuring both a location and a custom loader. |
@ContextConfiguration("/test-context.xml", loader = CustomContextLoader::class) (1)
// class body...
@ContextConfiguration provides support for inheriting resource locations or
configuration classes as well as context initializers that are declared by superclasses
or enclosing classes.
See Context Management,
@Nested
test class configuration, and the @ContextConfiguration
javadocs for further details.
