此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Framework 6.2.4! |
@RequestParam
您可以使用@RequestParam
注解绑定 Servlet 请求参数(即
查询参数或表单数据)添加到控制器中的方法参数。
以下示例显示了如何执行此作:
Java
Kotlin
@Controller
@RequestMapping("/pets")
public class EditPetForm {
@GetMapping
public String setupForm(@RequestParam("petId") int petId, Model model) { (1)
Pet pet = this.clinic.loadPet(petId);
model.addAttribute("pet", pet);
return "petForm";
1 | 用@RequestParam 绑定petId . |
import org.springframework.ui.set
@Controller
class EditPetForm {
@GetMapping
fun setupForm(@RequestParam("petId") petId: Int, model: Model): String { (1)
val pet = this.clinic.loadPet(petId);
model["pet"] = pet
return "petForm"
1
Using @RequestParam
to bind petId
By default, method parameters that use this annotation are required, but you can specify that
a method parameter is optional by setting the @RequestParam
annotation’s required
flag to
false
or by declaring the argument with a java.util.Optional
wrapper.
Type conversion is automatically applied if the target method parameter type is not
String
. See Type Conversion.
Declaring the argument type as an array or list allows for resolving multiple parameter
values for the same parameter name.
When an @RequestParam
annotation is declared as a Map<String, String>
or
MultiValueMap<String, String>
, without a parameter name specified in the annotation,
then the map is populated with the request parameter values for each given parameter name.
The following example shows how to do so with form data processing:
Java
Kotlin
@Controller
class EditPetForm {
@PostMapping(path = "/process", consumes = MediaType.APPLICATION_FORM_URLENCODED_VALUE)
public String processForm(@RequestParam MultiValueMap<String, String> params) {
@Controller
class EditPetForm {
@PostMapping("/process", consumes = [MediaType.APPLICATION_FORM_URLENCODED_VALUE])
fun processForm(@RequestParam params: MultiValueMap<String, String>): String {
Note that use of @RequestParam
is optional (for example, to set its attributes).
By default, any argument that is a simple value type (as determined by
BeanUtils#isSimpleProperty)
and is not resolved by any other argument resolver, is treated as if it were annotated
with @RequestParam
