此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Framework 6.2.4! |
请求正文
请求正文可以从ReactiveAdapterRegistry
喜欢Mono
或 Kotlin 协程Deferred
如下例所示:
Java
Kotlin
Mono<Person> personMono = ... ;
Mono<Void> result = client.post()
.uri("/persons/{id}", id)
.contentType(MediaType.APPLICATION_JSON)
.body(personMono, Person.class)
.retrieve()
.bodyToMono(Void.class);
val personDeferred: Deferred<Person> = ...
client.post()
.body<Person>(personDeferred)
.retrieve()
.awaitBody<Unit>()
您还可以对对象流进行编码,如下例所示:
Java
Kotlin
Flux<Person> personFlux = ... ;
.contentType(MediaType.APPLICATION_STREAM_JSON)
.body(personFlux, Person.class)
.retrieve()
val people: Flow<Person> = ...
client.post()
.body(people)
.retrieve()
.awaitBody<Unit>()
或者,如果您有实际值,则可以使用bodyValue
快捷方法,
如下例所示:
Java
Kotlin
Person person = ... ;
.bodyValue(person)
.retrieve()
val person: Person = ...
client.post()
.bodyValue(person)
.retrieve()
.awaitBody<Unit>()
表单数据
要发送表单数据,您可以提供MultiValueMap<String, String>
作为 body 进行。请注意,
content 会自动设置为application/x-www-form-urlencoded
由FormHttpMessageWriter
.以下示例演示如何使用MultiValueMap<String, String>
Java
Kotlin
MultiValueMap<String, String> formData = ... ;
.uri("/path", id)
.bodyValue(formData)
.retrieve()
val formData: MultiValueMap<String, String> = ...
client.post()
.uri("/path", id)
.retrieve()
.awaitBody<Unit>()
您还可以使用BodyInserters
,如下例所示:
Java
Kotlin
import static org.springframework.web.reactive.function.BodyInserters.*;
.uri("/path", id)
.body(fromFormData("k1", "v1").with("k2", "v2"))
.retrieve()
import org.springframework.web.reactive.function.BodyInserters.*
client.post()
.uri("/path", id)
.retrieve()
.awaitBody<Unit>()
Multipart Data
To send multipart data, you need to provide a MultiValueMap<String, ?>
whose values are
either Object
instances that represent part content or HttpEntity
instances that represent the content and
headers for a part. MultipartBodyBuilder
provides a convenient API to prepare a
multipart request. The following example shows how to create a MultiValueMap<String, ?>
Java
Kotlin
MultipartBodyBuilder builder = new MultipartBodyBuilder();
builder.part("fieldPart", "fieldValue");
builder.part("filePart1", new FileSystemResource("...logo.png"));
builder.part("jsonPart", new Person("Jason"));
builder.part("myPart", part); // Part from a server request
MultiValueMap<String, HttpEntity<?>> parts = builder.build();
val builder = MultipartBodyBuilder().apply {
part("filePart1", FileSystemResource("...logo.png"))
part("jsonPart", Person("Jason"))
part("myPart", part) // Part from a server request
val parts = builder.build()
In most cases, you do not have to specify the Content-Type
for each part. The content
type is determined automatically based on the HttpMessageWriter
chosen to serialize it
or, in the case of a Resource
, based on the file extension. If necessary, you can
explicitly provide the MediaType
to use for each part through one of the overloaded
builder part
methods.
Once a MultiValueMap
is prepared, the easiest way to pass it to the WebClient
is
through the body
method, as the following example shows:
Java
Kotlin
MultipartBodyBuilder builder = ...;
.uri("/path", id)
.body(builder.build())
.retrieve()
val builder: MultipartBodyBuilder = ...
client.post()
.uri("/path", id)
.retrieve()
.awaitBody<Unit>()
If the MultiValueMap
contains at least one non-String
value, which could also
represent regular form data (that is, application/x-www-form-urlencoded
), you need not
set the Content-Type
to multipart/form-data
. This is always the case when using
, which ensures an HttpEntity
wrapper.
As an alternative to MultipartBodyBuilder
, you can also provide multipart content,
inline-style, through the built-in BodyInserters
Java
Kotlin
.uri("/path", id)
.body(fromMultipartData("fieldPart", "value").with("filePart", resource))
.retrieve()
client.post()
.uri("/path", id)
.retrieve()
.awaitBody<Unit>()
PartEvent
To stream multipart data sequentially, you can provide multipart content through PartEvent
objects.
Form fields can be created via FormPartEvent::create
File uploads can be created via FilePartEvent::create
You can concatenate the streams returned from methods via Flux::concat
, and create a request for
the WebClient
For instance, this sample will POST a multipart form containing a form field and a file.
Java
Kotlin
Resource resource = ...
Mono<String> result = webClient
.post()
.uri("https://example.com")
.body(Flux.concat(
FormPartEvent.create("field", "field value"),
FilePartEvent.create("file", resource)
), PartEvent.class)
.retrieve()
.bodyToMono(String.class);
var resource: Resource = ...
var result: Mono<String> = webClient
.post()
.body(
Flux.concat(
.retrieve()
.bodyToMono()
On the server side, PartEvent
objects that are received via @RequestBody
or
ServerRequest::bodyToFlux(PartEvent.class)
can be relayed to another service
via the WebClient
