此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Framework 6.2.4! |
使用 JSR 330 标准注释
Spring 提供对 JSR-330 标准注释(依赖注入)的支持。那些 Comments 的扫描方式与 Spring Comments 相同。要使用它们,您需要 以将相关的 jar 放在 Classpath 中。
如果您使用 Maven,则
依赖项注入@Inject
和@Named
而不是@Autowired
,您可以使用@jakarta.inject.Inject
如下:
Java
Kotlin
import jakarta.inject.Inject;
public class SimpleMovieLister {
private MovieFinder movieFinder;
@Inject
public void setMovieFinder(MovieFinder movieFinder) {
this.movieFinder = movieFinder;
public void listMovies() {
this.movieFinder.findMovies(...);
@Inject
lateinit var movieFinder: MovieFinder
fun listMovies() {
As with @Autowired
, you can use @Inject
at the field level, method level
and constructor-argument level. Furthermore, you may declare your injection point as a
Provider
, allowing for on-demand access to beans of shorter scopes or lazy access to
other beans through a Provider.get()
call. The following example offers a variant of the
preceding example:
Java
Kotlin
import jakarta.inject.Provider;
private Provider<MovieFinder> movieFinder;
@Inject
public void setMovieFinder(Provider<MovieFinder> movieFinder) {
this.movieFinder.get().findMovies(...);
@Inject
lateinit var movieFinder: Provider<MovieFinder>
fun listMovies() {
If you would like to use a qualified name for the dependency that should be injected,
you should use the @Named
annotation, as the following example shows:
Java
Kotlin
import jakarta.inject.Named;
@Inject
public void setMovieFinder(@Named("main") MovieFinder movieFinder) {
private lateinit var movieFinder: MovieFinder
@Inject
fun setMovieFinder(@Named("main") movieFinder: MovieFinder) {
As with @Autowired
, @Inject
can also be used with java.util.Optional
or
@Nullable
. This is even more applicable here, since @Inject
does not have
a required
attribute. The following pair of examples show how to use @Inject
and
@Nullable
@Inject
public void setMovieFinder(Optional<MovieFinder> movieFinder) {
Java
Kotlin
@Inject
public void setMovieFinder(@Nullable MovieFinder movieFinder) {
@Inject
var movieFinder: MovieFinder? = null
@Named
and @ManagedBean
: Standard Equivalents to the @Component
Annotation
Instead of @Component
, you can use @jakarta.inject.Named
or jakarta.annotation.ManagedBean
Java
Kotlin
@Named("movieListener") // @ManagedBean("movieListener") could be used as well
@Inject
@Inject
It is very common to use @Component
without specifying a name for the component.
@Named
can be used in a similar fashion, as the following example shows:
Java
Kotlin
@Named
@Inject
@Named
@Inject
When you use @Named
or @ManagedBean
, you can use component scanning in the
exact same way as when you use Spring annotations, as the following example shows:
Java
Kotlin
@ComponentScan(basePackages = "org.example")
public class AppConfig {
@ComponentScan(basePackages = ["org.example"])
class AppConfig {
In contrast to @Component
, the JSR-330 @Named
and the JSR-250 @ManagedBean
annotations are not composable. You should use Spring’s stereotype model for building
custom component annotations.
Limitations of JSR-330 Standard Annotations
When you work with standard annotations, you should know that some significant
features are not available, as the following table shows:
Table 1. Spring component model elements versus JSR-330 variants
Spring
jakarta.inject.*
jakarta.inject restrictions / comments
@Autowired
@Inject
@Inject
has no 'required' attribute. Can be used with Java 8’s Optional
instead.
@Component
@Named / @ManagedBean
JSR-330 does not provide a composable model, only a way to identify named components.
@Scope("singleton")
@Singleton
The JSR-330 default scope is like Spring’s prototype
. However, in order to keep it
consistent with Spring’s general defaults, a JSR-330 bean declared in the Spring
container is a singleton
by default. In order to use a scope other than singleton
you should use Spring’s @Scope
annotation. jakarta.inject
also provides a
jakarta.inject.Scope
annotation: however, this one is only intended to be used
for creating custom annotations.
@Qualifier
@Qualifier / @Named
jakarta.inject.Qualifier
is just a meta-annotation for building custom qualifiers.
Concrete String
qualifiers (like Spring’s @Qualifier
with a value) can be associated
through jakarta.inject.Named
@Value
no equivalent
@Lazy
no equivalent
ObjectFactory
Provider
is a direct alternative to Spring’s ObjectFactory
only with a shorter get()
method name. It can also be used in combination with
Spring’s @Autowired
or with non-annotated constructors and setter methods.
