For the latest stable version, please use Spring Framework 6.2.6!spring-doc.cn
@RequestParam
You can use the @RequestParam annotation to bind Servlet request parameters (that is, query parameters or form data) to a method argument in a controller.spring-doc.cn
The following example shows how to do so:spring-doc.cn
@Controller
@RequestMapping("/pets")
public class EditPetForm {
	@GetMapping
	public String setupForm(@RequestParam("petId") int petId, Model model) { (1)
		Pet pet = this.clinic.loadPet(petId);
		model.addAttribute("pet", pet);
		return "petForm";
1 Using @RequestParam to bind petId.
import org.springframework.ui.set
@Controller
class EditPetForm {
	@GetMapping
	fun setupForm(@RequestParam("petId") petId: Int, model: Model): String { (1)
		val pet = this.clinic.loadPet(petId);
		model["pet"] = pet
		return "petForm"
By default, method parameters that use this annotation are required, but you can specify that a method parameter is optional by setting the @RequestParam annotation’s required flag to false or by declaring the argument with an java.util.Optional wrapper.spring-doc.cn
Type conversion is automatically applied if the target method parameter type is not String. See Type Conversion.spring-doc.cn
Declaring the argument type as an array or list allows for resolving multiple parameter values for the same parameter name.spring-doc.cn
When an @RequestParam annotation is declared as a Map<String, String> or MultiValueMap<String, String>, without a parameter name specified in the annotation, then the map is populated with the request parameter values for each given parameter name.spring-doc.cn
Note that use of @RequestParam is optional (for example, to set its attributes). By default, any argument that is a simple value type (as determined by BeanUtils#isSimpleProperty) and is not resolved by any other argument resolver, is treated as if it were annotated with @RequestParam.spring-doc.cn
