对于最新的稳定版本,请使用 Spring Framework 6.2.4! |
启用 STOMP
STOMP over WebSocket 支持在spring-messaging
和spring-websocket
模块。拥有这些依赖项后,就可以公开 STOMP
endpoint,如下例所示:
import org.springframework.web.socket.config.annotation.EnableWebSocketMessageBroker;
import org.springframework.web.socket.config.annotation.StompEndpointRegistry;
@EnableWebSocketMessageBroker
public class WebSocketConfig implements WebSocketMessageBrokerConfigurer {
public void registerStompEndpoints(StompEndpointRegistry registry) {
registry.addEndpoint("/portfolio"); (1)
public void configureMessageBroker(MessageBrokerRegistry config) {
config.setApplicationDestinationPrefixes("/app"); (2)
config.enableSimpleBroker("/topic", "/queue"); (3)
1
/portfolio
is the HTTP URL for the endpoint to which a WebSocket (or SockJS)
client needs to connect for the WebSocket handshake.
2
STOMP messages whose destination header begins with /app
are routed to
@MessageMapping
methods in @Controller
classes.
3
Use the built-in message broker for subscriptions and broadcasting and
route messages whose destination header begins with /topic
or /queue
to the broker.
The following example shows the XML configuration equivalent of the preceding example:
xmlns:websocket="http://www.springframework.org/schema/websocket"
xsi:schemaLocation="
https://www.springframework.org/schema/websocket/spring-websocket.xsd">
<websocket:message-broker application-destination-prefix="/app">
<websocket:stomp-endpoint path="/portfolio" />
<websocket:simple-broker prefix="/topic, /queue"/>
</websocket:message-broker>
</beans>
For the built-in simple broker, the /topic
and /queue
prefixes do not have any special
meaning. They are merely a convention to differentiate between pub-sub versus point-to-point
messaging (that is, many subscribers versus one consumer). When you use an external broker,
check the STOMP page of the broker to understand what kind of STOMP destinations and
prefixes it supports.
To connect from a browser, for STOMP, you can use
stomp-js/stompjs
which is the most
actively maintained JavaScript library.
The following example code is based on it:
const stompClient = new StompJs.Client({
brokerURL: 'ws://domain.com/portfolio',
onConnect: () => {
Alternatively, if you connect through SockJS, you can enable the
SockJS Fallback on server-side with
registry.addEndpoint("/portfolio").withSockJS()
and on JavaScript side,
by following
those instructions.
Note that stompClient
in the preceding example does not need to specify login
and passcode
headers. Even if it did, they would be ignored (or, rather,
overridden) on the server side. See Connecting to a Broker
and Authentication for more information on authentication.
For more example code see:
Using WebSocket to build an
interactive web application — a getting started guide.
Stock Portfolio — a sample
application.
