对于最新的稳定版本,请使用 Spring Framework 6.2.4! |
为事务性作提供咨询
假设您要同时运行事务作和一些基本的分析建议。
在<tx:annotation-driven/>
当您调用updateFoo(Foo)
方法,您希望看到以下作:
配置的分析方面将启动。
事务性建议运行。
将运行建议对象上的方法。
事务提交。
分析方面报告整个事务方法调用的确切持续时间。
本章不涉及对 AOP 的任何详细解释(除了它 适用于交易)。有关 AOP 的详细覆盖范围,请参阅 AOP 配置和 AOP 的 AOP 进行配置。 |
以下代码显示了前面讨论的简单性能分析方面:
Java
Kotlin
package x.y;
import org.aspectj.lang.ProceedingJoinPoint;
import org.springframework.util.StopWatch;
import org.springframework.core.Ordered;
public class SimpleProfiler implements Ordered {
private int order;
// allows us to control the ordering of advice
public int getOrder() {
return this.order;
public void setOrder(int order) {
this.order = order;
// this method is the around advice
public Object profile(ProceedingJoinPoint call) throws Throwable {
Object returnValue;
StopWatch clock = new StopWatch(getClass().getName());
try {
clock.start(call.toShortString());
returnValue = call.proceed();
} finally {
clock.stop();
System.out.println(clock.prettyPrint());
return returnValue;
package x.y
class SimpleProfiler : Ordered {
private var order: Int = 0
override fun getOrder(): Int {
return this.order
fun setOrder(order: Int) {
this.order = order
fun profile(call: ProceedingJoinPoint): Any {
var returnValue: Any
val clock = StopWatch(javaClass.name)
try {
} finally {
clock.stop()
return returnValue
The ordering of advice
is controlled through the Ordered
interface. For full details on advice ordering, see
Advice ordering.
The following configuration creates a fooService
bean that has profiling and
transactional aspects applied to it in the desired order:
xmlns:aop="http://www.springframework.org/schema/aop"
xmlns:tx="http://www.springframework.org/schema/tx"
xsi:schemaLocation="
https://www.springframework.org/schema/tx/spring-tx.xsd
https://www.springframework.org/schema/aop/spring-aop.xsd">
<bean id="fooService" class="x.y.service.DefaultFooService"/>
<!-- this is the aspect -->
<bean id="profiler" class="x.y.SimpleProfiler">
<!-- run before the transactional advice (hence the lower order number) -->
<property name="order" value="1"/>
</bean>
<tx:annotation-driven transaction-manager="txManager" order="200"/>
<aop:config>
<!-- this advice runs around the transactional advice -->
<aop:aspect id="profilingAspect" ref="profiler">
<aop:pointcut id="serviceMethodWithReturnValue"
expression="execution(!void x.y..*Service.*(..))"/>
<aop:around method="profile" pointcut-ref="serviceMethodWithReturnValue"/>
</aop:aspect>
</aop:config>
<bean id="dataSource" class="org.apache.commons.dbcp.BasicDataSource" destroy-method="close">
<property name="driverClassName" value="oracle.jdbc.driver.OracleDriver"/>
<property name="url" value="jdbc:oracle:thin:@rj-t42:1521:elvis"/>
<property name="username" value="scott"/>
<property name="password" value="tiger"/>
</bean>
<bean id="txManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
<property name="dataSource" ref="dataSource"/>
</bean>
</beans>
You can configure any number
of additional aspects in similar fashion.
The following example creates the same setup as the previous two examples but uses the purely XML
declarative approach:
<!-- the profiling advice -->
</bean>
<aop:config>
<aop:pointcut id="entryPointMethod" expression="execution(* x.y..*Service.*(..))"/>
<!-- runs after the profiling advice (cf. the order attribute) -->
<aop:advisor advice-ref="txAdvice" pointcut-ref="entryPointMethod" order="2"/>
<!-- order value is higher than the profiling aspect -->
</aop:aspect>
</aop:config>
<tx:advice id="txAdvice" transaction-manager="txManager">
<tx:attributes>
<tx:method name="get*" read-only="true"/>
<tx:method name="*"/>
</tx:attributes>
</tx:advice>
<!-- other <bean/> definitions such as a DataSource and a TransactionManager here -->
</beans>
The result of the preceding configuration is a fooService
transactional aspects applied to it in that order. If you want the profiling advice
to run after the transactional advice on the way in and before the
transactional advice on the way out, you can swap the value of the profiling
aspect bean’s order
property so that it is higher than the transactional advice’s
order value.
You can configure additional aspects in similar fashion.
