对于最新的稳定版本,请使用 Spring Framework 6.2.4! |
Java Bean 验证
Spring Framework 提供了对 Java Bean 验证 API 的支持。
Bean 验证概述
Bean Validation 提供了一种常见的验证方法,通过 constraint declaration 和 元数据。要使用它,您可以使用 声明性验证约束,然后由运行时强制执行。有 built-in constraints,您还可以定义自己的自定义 constraints。
请考虑以下示例,它显示了一个简单的PersonForm
model 具有两个属性:
Java
Kotlin
public class PersonForm {
private String name;
private int age;
class PersonForm(
private val name: String,
private val age: Int
Bean 验证允许您声明约束,如下例所示:
Java
Kotlin
@NotNull
@Size(max=64)
@Min(0)
private int age;
class PersonForm(
@get:NotNull @get:Size(max=64)
@get:Min(0)
然后,Bean 验证器根据声明的 约束。有关 API 的 API 创建。请参阅 Hibernate Validator 文档 特定约束。了解如何将 Bean 验证提供程序设置为 Spring Bean,请继续阅读。
配置 Bean 验证提供程序
Spring 提供了对 Bean 验证 API 的全面支持,包括
Bean Validation 提供程序作为 Spring Bean。这样,您就可以注入jakarta.validation.ValidatorFactory
或jakarta.validation.Validator
Where 验证
在您的应用程序中需要。
您可以使用LocalValidatorFactoryBean
将默认 Validator 配置为 Spring
bean,如下例所示:
Java
XML
import org.springframework.validation.beanvalidation.LocalValidatorFactoryBean;
public class AppConfig {
public LocalValidatorFactoryBean validator() {
return new LocalValidatorFactoryBean();
<bean id="validator"
class="org.springframework.validation.beanvalidation.LocalValidatorFactoryBean"/>
The basic configuration in the preceding example triggers bean validation to initialize by
using its default bootstrap mechanism. A Bean Validation provider, such as the Hibernate
Validator, is expected to be present in the classpath and is automatically detected.
Inject Jakarta Validator
implements both jakarta.validation.ValidatorFactory
and
, so you can inject a reference to the latter to
apply validation logic if you prefer to work with the Bean Validation API directly,
as the following example shows:
Java
Kotlin
import jakarta.validation.Validator;
@Service
public class MyService {
@Autowired
private Validator validator;
@Service
class MyService(@Autowired private val validator: Validator)
Inject Spring Validator
In addition to implementing jakarta.validation.Validator
, LocalValidatorFactoryBean
also adapts to org.springframework.validation.Validator
to the latter if your bean requires the Spring Validation API.
For example:
Java
Kotlin
import org.springframework.validation.Validator;
@Service
@Autowired
@Service
When used as org.springframework.validation.Validator
invokes the underlying jakarta.validation.Validator
, and then adapts
ConstraintViolation
s to FieldError
s, and registers them with the Errors
object
passed into the validate
method.
Configure Custom Constraints
Each bean validation constraint consists of two parts:
A @Constraint
annotation that declares the constraint and its configurable properties.
An implementation of the jakarta.validation.ConstraintValidator
interface that implements
the constraint’s behavior.
To associate a declaration with an implementation, each @Constraint
annotation
references a corresponding ConstraintValidator
implementation class. At runtime, a
ConstraintValidatorFactory
instantiates the referenced implementation when the
constraint annotation is encountered in your domain model.
By default, the LocalValidatorFactoryBean
configures a SpringConstraintValidatorFactory
that uses Spring to create ConstraintValidator
instances. This lets your custom
ConstraintValidators
benefit from dependency injection like any other Spring bean.
The following example shows a custom @Constraint
declaration followed by an associated
ConstraintValidator
implementation that uses Spring for dependency injection:
Java
Kotlin
@Target({ElementType.METHOD, ElementType.FIELD})
@Constraint(validatedBy=MyConstraintValidator.class)
public @interface MyConstraint {
@Target(AnnotationTarget.FUNCTION, AnnotationTarget.FIELD)
@Retention(AnnotationRetention.RUNTIME)
@Constraint(validatedBy = MyConstraintValidator::class)
annotation class MyConstraint
Java
Kotlin
import jakarta.validation.ConstraintValidator;
public class MyConstraintValidator implements ConstraintValidator {
@Autowired;
private Foo aDependency;
class MyConstraintValidator(private val aDependency: Foo) : ConstraintValidator {
As the preceding example shows, a ConstraintValidator
implementation can have its dependencies
@Autowired
as any other Spring bean.
Spring-driven Method Validation
You can integrate the method validation feature of Bean Validation into a
Spring context through a MethodValidationPostProcessor
bean definition:
Java
XML
import org.springframework.validation.beanvalidation.MethodValidationPostProcessor;
public static MethodValidationPostProcessor validationPostProcessor() {
return new MethodValidationPostProcessor();
<bean class="org.springframework.validation.beanvalidation.MethodValidationPostProcessor"/>
To be eligible for Spring-driven method validation, target classes need to be annotated
with Spring’s @Validated
annotation, which can optionally also declare the validation
groups to use. See
for setup details with the Hibernate Validator and Bean Validation providers.
Method validation relies on AOP Proxies around the
target classes, either JDK dynamic proxies for methods on interfaces or CGLIB proxies.
There are certain limitations with the use of proxies, some of which are described in
Understanding AOP Proxies. In addition remember
to always use methods and accessors on proxied classes; direct field access will not work.
Spring MVC and WebFlux have built-in support for the same underlying method validation but without
the need for AOP. Therefore, do check the rest of this section, and also see the Spring MVC
Validation and
Error Responses sections, and the WebFlux
Validation and
Error Responses sections.
Method Validation Exceptions
By default, jakarta.validation.ConstraintViolationException
is raised with the set of
ConstraintViolation
s returned by jakarta.validation.Validator
. As an alternative,
you can have MethodValidationException
raised instead with ConstraintViolation
s
adapted to MessageSourceResolvable
errors. To enable set the following flag:
Java
XML
MethodValidationPostProcessor processor = new MethodValidationPostProcessor();
processor.setAdaptConstraintViolations(true);
return processor;
<bean class="org.springframework.validation.beanvalidation.MethodValidationPostProcessor">
<property name="adaptConstraintViolations" value="true"/>
</bean>
contains a list of ParameterValidationResult
s which
group errors by method parameter, and each exposes a MethodParameter
, the argument
value, and a list of MessageSourceResolvable
errors adapted from
ConstraintViolation
s. For @Valid
method parameters with cascaded violations on
fields and properties, the ParameterValidationResult
is ParameterErrors
which
implements org.springframework.validation.Errors
and exposes validation errors as
FieldError
s.
Customizing Validation Errors
The adapted MessageSourceResolvable
errors can be turned into error messages to
display to users through the configured MessageSource
with locale and language specific
resource bundles. This section provides an example for illustration.
Given the following class declarations:
Java
Kotlin
record Person(@Size(min = 1, max = 10) String name) {
@Validated
void addStudent(@Valid Person person, @Max(2) int degrees) {
@JvmRecord
internal data class Person(@Size(min = 1, max = 10) val name: String)
@Validated
class MyService {
fun addStudent(person: @Valid Person?, degrees: @Max(2) Int) {
A ConstraintViolation
on Person.name()
is adapted to a FieldError
with the following:
Error codes "Size.person.name"
, "Size.name"
, "Size.java.lang.String"
, and "Size"
Message arguments "name"
, 10
, and 1
(the field name and the constraint attributes)
Default message "size must be between 1 and 10"
To customize the default message, you can add properties to
MessageSource
resource bundles using any of the above errors codes and message arguments. Note also that the
message argument "name"
is itself a MessagreSourceResolvable
with error codes
"person.name"
and "name"
and can customized too. For example:
- Properties
Size.person.name=Please, provide a {0} that is between {2} and {1} characters long
person.name=username
on the degrees
method parameter is adapted to a
with the following:
Error codes "Max.myService#addStudent.degrees"
, "Max.degrees"
, "Max.int"
, "Max"
Message arguments "degrees2 and 2 (the field name and the constraint attribute)
Default message "must be less than or equal to 2"
To customize the above default message, you can add a property such as:
- Properties
Max.degrees=You cannot provide more than {1} {0}
Additional Configuration Options
The default LocalValidatorFactoryBean
configuration suffices for most
cases. There are a number of configuration options for various Bean Validation
constructs, from message interpolation to traversal resolution. See the
javadoc for more information on these options.
Configuring a DataBinder
You can configure a DataBinder
instance with a Validator
. Once configured, you can
invoke the Validator
by calling binder.validate()
. Any validation Errors
are
automatically added to the binder’s BindingResult
The following example shows how to use a DataBinder
programmatically to invoke validation
logic after binding to a target object:
Java
Kotlin
Foo target = new Foo();
DataBinder binder = new DataBinder(target);
binder.setValidator(new FooValidator());
// bind to the target object
binder.bind(propertyValues);
// validate the target object
binder.validate();
// get BindingResult that includes any validation errors
BindingResult results = binder.getBindingResult();
val target = Foo()
val binder = DataBinder(target)
binder.validator = FooValidator()
binder.validate()
val results = binder.bindingResult
You can also configure a DataBinder
with multiple Validator
instances through
dataBinder.addValidators
and dataBinder.replaceValidators
. This is useful when
combining globally configured bean validation with a Spring Validator
configured
locally on a DataBinder instance. See
Spring MVC Validation Configuration.
Spring MVC 3 Validation
See Validation in the Spring MVC chapter.
