对于最新的稳定版本,请使用 Spring Framework 6.2.4spring-doc.cadn.net.cn
使用 实例化 Spring 容器AnnotationConfigApplicationContext
以下部分记录了 Spring 的AnnotationConfigApplicationContext,在 Spring 中引入 3.0. 这个多才多艺的ApplicationContextimplementation 不仅能够接受@Configuration类作为输入,但也作为普通类@Component类和类 使用 JSR-330 元数据进行注释。spring-doc.cadn.net.cn
什么时候@Configuration类作为输入提供,@Configuration类本身 注册为 Bean 定义,并且所有声明@Bean类中 methods 也注册为 Bean 定义。spring-doc.cadn.net.cn
什么时候@Component和 JSR-330 类,它们被注册为 bean 定义,并假设 DI 元数据(如@Autowired@Inject是 在必要时使用这些类。spring-doc.cadn.net.cn
结构简单
与在实例化ClassPathXmlApplicationContext,您可以使用@Configuration类作为输入,当 实例化AnnotationConfigApplicationContext.这允许完全 Spring 容器的无 XML 用法,如下例所示:spring-doc.cadn.net.cn
	ApplicationContext ctx = new AnnotationConfigApplicationContext(AppConfig.class);
	MyService myService = ctx.getBean(MyService.class);
	myService.doStuff();
import org.springframework.beans.factory.getBean
fun main() {
	val ctx = AnnotationConfigApplicationContext(AppConfig::class.java)
	val myService = ctx.getBean<MyService>()
	myService.doStuff()
As mentioned earlier, AnnotationConfigApplicationContext is not limited to working only with @Configuration classes. Any @Component or JSR-330 annotated class may be supplied as input to the constructor, as the following example shows:spring-doc.cadn.net.cn
	ApplicationContext ctx = new AnnotationConfigApplicationContext(MyServiceImpl.class, Dependency1.class, Dependency2.class);
fun main() {
	val ctx = AnnotationConfigApplicationContext(MyServiceImpl::class.java, Dependency1::class.java, Dependency2::class.java)
	myService.doStuff()
The preceding example assumes that MyServiceImpl, Dependency1, and Dependency2 use Spring dependency injection annotations such as @Autowired.spring-doc.cadn.net.cn
Building the Container Programmatically by Using register(Class<?>…​)
You can instantiate an AnnotationConfigApplicationContext by using a no-arg constructor and then configure it by using the register() method. This approach is particularly useful when programmatically building an AnnotationConfigApplicationContext. The following example shows how to do so:spring-doc.cadn.net.cn
	AnnotationConfigApplicationContext ctx = new AnnotationConfigApplicationContext();
	ctx.register(AppConfig.class, OtherConfig.class);
	ctx.register(AdditionalConfig.class);
	ctx.refresh();
fun main() {
	val ctx = AnnotationConfigApplicationContext()
	ctx.register(AppConfig::class.java, OtherConfig::class.java)
	ctx.register(AdditionalConfig::class.java)
	ctx.refresh()
	myService.doStuff()
Enabling Component Scanning with scan(String…​)
To enable component scanning, you can annotate your @Configuration class as follows:spring-doc.cadn.net.cn
@ComponentScan(basePackages = "com.acme") (1)
public class AppConfig  {
1 This annotation enables component scanning.
@ComponentScan(basePackages = ["com.acme"]) (1)
class AppConfig  {
Experienced Spring users may be familiar with the XML declaration equivalent from Spring’s context: namespace, shown in the following example:spring-doc.cadn.net.cn
<beans>
	<context:component-scan base-package="com.acme"/>
</beans>
In the preceding example, the com.acme package is scanned to look for any @Component-annotated classes, and those classes are registered as Spring bean definitions within the container. AnnotationConfigApplicationContext exposes the scan(String…​) method to allow for the same component-scanning functionality, as the following example shows:spring-doc.cadn.net.cn
	ctx.scan("com.acme");
	ctx.refresh();
fun main() {
	ctx.refresh()
Remember that @Configuration classes are meta-annotated with @Component, so they are candidates for component-scanning. In the preceding example, assuming that AppConfig is declared within the com.acme package (or any package underneath), it is picked up during the call to scan(). Upon refresh(), all its @Bean methods are processed and registered as bean definitions within the container.
Support for Web Applications with AnnotationConfigWebApplicationContext
A WebApplicationContext variant of AnnotationConfigApplicationContext is available with AnnotationConfigWebApplicationContext. You can use this implementation when configuring the Spring ContextLoaderListener servlet listener, Spring MVC DispatcherServlet, and so forth. The following web.xml snippet configures a typical Spring MVC web application (note the use of the contextClass context-param and init-param):spring-doc.cadn.net.cn
<web-app>
	<!-- Configure ContextLoaderListener to use AnnotationConfigWebApplicationContext
		instead of the default XmlWebApplicationContext -->
	<context-param>
		<param-name>contextClass</param-name>
		<param-value>
			org.springframework.web.context.support.AnnotationConfigWebApplicationContext
		</param-value>
	</context-param>
	<!-- Configuration locations must consist of one or more comma- or space-delimited
		fully-qualified @Configuration classes. Fully-qualified packages may also be
		specified for component-scanning -->
	<context-param>
		<param-name>contextConfigLocation</param-name>
		<param-value>com.acme.AppConfig</param-value>
	</context-param>
	<!-- Bootstrap the root application context as usual using ContextLoaderListener -->
	<listener>
		<listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
	</listener>
	<!-- Declare a Spring MVC DispatcherServlet as usual -->
	<servlet>
		<servlet-name>dispatcher</servlet-name>
		<servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
		<!-- Configure DispatcherServlet to use AnnotationConfigWebApplicationContext
		<init-param>
			<param-value>
			</param-value>
		</init-param>
		<!-- Again, config locations must consist of one or more comma- or space-delimited
			and fully-qualified @Configuration classes -->
		<init-param>
			<param-value>com.acme.web.MvcConfig</param-value>
		</init-param>
	</servlet>
	<!-- map all requests for /app/* to the dispatcher servlet -->
	<servlet-mapping>
		<url-pattern>/app/*</url-pattern>
	</servlet-mapping>
</web-app>
For programmatic use cases, a GenericWebApplicationContext can be used as an alternative to AnnotationConfigWebApplicationContext. See the GenericWebApplicationContext javadoc for details.
