For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
@CookieValue
You can use the @CookieValue annotation to bind the value of an HTTP cookie to a method argument in a controller.spring-doc.cn
Consider a request with the following cookie:spring-doc.cn
JSESSIONID=415A4AC178C59DACE0B2C9CA727CDD84
The following example shows how to get the cookie value:spring-doc.cn
@GetMapping("/demo")
public void handle(@CookieValue("JSESSIONID") String cookie) { (1)
1 Get the value of the JSESSIONID cookie.
fun handle(@CookieValue("JSESSIONID") cookie: String) { (1)
If the target method parameter type is not String, type conversion is applied automatically. See Type Conversion.spring-doc.cn
