此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Boot 3.3.1! |
端点以 Prometheus 服务器抓取所需的格式提供 Spring Boot 应用程序的指标。prometheus
检索所有指标
若要检索所有指标,请向 发出请求,如以下基于 curl 的示例所示:GET
/actuator/prometheus
$ curl 'http://localhost:8080/actuator/prometheus' -i -X GET
生成的响应类似于以下内容:
HTTP/1.1 200 OK
Content-Type: text/plain;version=0.0.4;charset=utf-8
Content-Length: 3096
# HELP jvm_buffer_count_buffers An estimate of the number of buffers in the pool
# TYPE jvm_buffer_count_buffers gauge
jvm_buffer_count_buffers{id="direct"} 16.0
jvm_buffer_count_buffers{id="mapped"} 0.0
jvm_buffer_count_buffers{id="mapped - 'non-volatile memory'"} 0.0
# HELP jvm_buffer_memory_used_bytes An estimate of the memory that the Java virtual machine is using for this buffer pool
# TYPE jvm_buffer_memory_used_bytes gauge
jvm_buffer_memory_used_bytes{id="direct"} 1.7043464E7
jvm_buffer_memory_used_bytes{id="mapped"} 0.0
jvm_buffer_memory_used_bytes{id="mapped - 'non-volatile memory'"} 0.0
# HELP jvm_buffer_total_capacity_bytes An estimate of the total capacity of the buffers in this pool
# TYPE jvm_buffer_total_capacity_bytes gauge
jvm_buffer_total_capacity_bytes{id="direct"} 1.7043463E7
jvm_buffer_total_capacity_bytes{id="mapped"} 0.0
jvm_buffer_total_capacity_bytes{id="mapped - 'non-volatile memory'"} 0.0
# HELP jvm_memory_committed_bytes The amount of memory in bytes that is committed for the Java virtual machine to use
# TYPE jvm_memory_committed_bytes gauge
jvm_memory_committed_bytes{area="heap",id="G1 Eden Space"} 4.8234496E7
jvm_memory_committed_bytes{area="heap",id="G1 Old Gen"} 1.17440512E8
jvm_memory_committed_bytes{area="heap",id="G1 Survivor Space"} 4194304.0
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 2555904.0
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4390912.0
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 2.031616E7
jvm_memory_committed_bytes{area="nonheap",id="Compressed Class Space"} 1.212416E7
jvm_memory_committed_bytes{area="nonheap",id="Metaspace"} 8.8539136E7
# HELP jvm_memory_max_bytes The maximum amount of memory in bytes that can be used for memory management
# TYPE jvm_memory_max_bytes gauge
jvm_memory_max_bytes{area="heap",id="G1 Eden Space"} -1.0
jvm_memory_max_bytes{area="heap",id="G1 Old Gen"} 1.073741824E9
jvm_memory_max_bytes{area="heap",id="G1 Survivor Space"} -1.0
jvm_memory_max_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 5836800.0
jvm_memory_max_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 1.22912768E8
jvm_memory_max_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 1.22908672E8
jvm_memory_max_bytes{area="nonheap",id="Compressed Class Space"} 1.073741824E9
jvm_memory_max_bytes{area="nonheap",id="Metaspace"} -1.0
# HELP jvm_memory_used_bytes The amount of used memory
# TYPE jvm_memory_used_bytes gauge
jvm_memory_used_bytes{area="heap",id="G1 Eden Space"} 2.097152E7
jvm_memory_used_bytes{area="heap",id="G1 Old Gen"} 8.4777984E7
jvm_memory_used_bytes{area="heap",id="G1 Survivor Space"} 3597888.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 1441152.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4357632.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 2.0311424E7
jvm_memory_used_bytes{area="nonheap",id="Compressed Class Space"} 1.1754176E7
jvm_memory_used_bytes{area="nonheap",id="Metaspace"} 8.7801872E7
默认响应内容类型为 。
当使用适当的标头调用时,终结点也可以生成,如以下基于 curl 的示例所示:text/plain;version=0.0.4
application/openmetrics-text;version=1.0.0
Accept
$ curl 'http://localhost:8080/actuator/prometheus' -i -X GET \
-H 'Accept: application/openmetrics-text; version=1.0.0; charset=utf-8'
生成的响应类似于以下内容:
HTTP/1.1 200 OK
Content-Type: application/openmetrics-text;version=1.0.0;charset=utf-8
Content-Length: 3103
jvm_memory_used_bytes{area="heap",id="G1 Eden Space"} 1.9922944E7
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4355328.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 2.0263808E7
jvm_memory_used_bytes{area="nonheap",id="Compressed Class Space"} 1.1750256E7
jvm_memory_used_bytes{area="nonheap",id="Metaspace"} 8.7762744E7
# EOF
参数 | 描述 |
将样本限制为与名称匹配的样本。自选。 |
检索筛选的指标
若要检索与特定名称匹配的指标,请使用 query 参数发出请求,如以下基于 curl 的示例所示:GET
includedNames
$ curl 'http://localhost:8080/actuator/prometheus?includedNames=jvm_memory_used_bytes%2Cjvm_memory_committed_bytes' -i -X GET
生成的响应类似于以下内容:
HTTP/1.1 200 OK
Content-Length: 1459
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 2.0381696E7
jvm_memory_committed_bytes{area="nonheap",id="Metaspace"} 8.8604672E7
jvm_memory_used_bytes{area="heap",id="G1 Eden Space"} 2.2020096E7
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4363008.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 2.0333568E7
jvm_memory_used_bytes{area="nonheap",id="Compressed Class Space"} 1.1754776E7
jvm_memory_used_bytes{area="nonheap",id="Metaspace"} 8.7809E7
