此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Boot 3.3.1
终结点提供有关应用程序的 .envEnvironment
检索整个环境
若要检索整个环境,请向 发出请求,如以下基于 curl 的示例所示:GET/actuator/env
$ curl 'http://localhost:8080/actuator/env' -i -X GET
生成的响应类似于以下内容:
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 78829
  "activeProfiles" : [ ],
  "defaultProfiles" : [ "default" ],
  "propertySources" : [ {
    "name" : "servletContextInitParams",
    "properties" : { }
    "name" : "systemProperties",
    "properties" : {
      "java.specification.version" : {
        "value" : "17"
      "java.class.path" : {
        "value" : "/home/runner/.gradle/caches/7.6.4/workerMain/gradle-worker.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator-autoconfigure/build/classes/java/test:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator-autoconfigure/build/resources/test:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator-autoconfigure/build/classes/java/main:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator-autoconfigure/build/resources/main:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-tools/spring-boot-test-support/build/libs/spring-boot-test-support-3.3.2-SNAPSHOT.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator/build/libs/spring-boot-actuator-3.3.2-SNAPSHOT.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-autoconfigure/build/libs/spring-boot-autoconfigure-3.3.2-SNAPSHOT.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-test/build/libs/spring-boot-test-3.3.2-SNAPSHOT.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot/build/libs/spring-boot-3.3.2-SNAPSHOT.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.dataformat/jackson-dataformat-xml/2.17.1/e6a168dba62aa63743b9e2b83f4e0f0dfdc143d3/jackson-dataformat-xml-2.17.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-wavefront/1.13.1/a73d6499334cffa4f5fc1e7f02ae7227a92ad610/micrometer-registry-wavefront-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-tracing-reporter-wavefront/1.3.1/fd51e75bacce183830a5ebcc76330917de6d173f/micrometer-tracing-reporter-wavefront-1.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.wavefront/wavefront-internal-reporter-java/1.7.16/135f9be9f149a6f0614db155ddf51e216d0d2891/wavefront-internal-reporter-java-1.7.16.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.wavefront/wavefront-sdk-java/3.4.3/48a767aa5aa56b56e09c88e8be87de8707cafe77/wavefront-sdk-java-3.4.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.datatype/jackson-datatype-jsr310/2.17.1/969b0c3cb8c75d759e9a6c585c44c9b9f3a4f75/jackson-datatype-jsr310-2.17.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-cassandra/4.3.1/1bf66028994a26606827931d7710f092891c4d07/spring-data-cassandra-4.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.cassandra/java-driver-query-builder/4.18.1/a771500f0d15729c740c43711f684a605157d5f7/java-driver-query-builder-4.18.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.cassandra/java-driver-core/4.18.1/1b80caa76a9b4f88b5adf866799aaa4a80f378f7/java-driver-core-4.18.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-elasticsearch/5.3.1/7b92031094f11d8fce83ed5ab692ada1f5c624e6/spring-data-elasticsearch-5.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.flywaydb/flyway-core/10.10.0/8761d308b9fc9697a95ae362bcbbb5abe8f6e08f/flyway-core-10.10.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.dataformat/jackson-dataformat-toml/2.17.1/430269726ae331661a3b53a7da9440fd05d1636/jackson-dataformat-toml-2.17.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.media/jersey-media-json-jackson/3.1.7/9c415137c1f36ee525977eec9580e23a269602b2/jersey-media-json-jackson-3.1.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.module/jackson-module-jakarta-xmlbind-annotations/2.17.1/1119f6cb1dcafe770baac9924f9648397f1d52aa/jackson-module-jakarta-xmlbind-annotations-2.17.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.dataformat/jackson-dataformat-yaml/2.17.1/b4c7b8a9ea3f398116a75c146b982b22afebc4ee/jackson-dataformat-yaml-2.17.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-rest-webmvc/4.3.1/2644e59b9d97a4af2856b7ddeb170db4a13a0c69/spring-data-rest-webmvc-4.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-rest-core/4.3.1/1cb2cc5c7ef56104c5e6f55761ebaa913db06e26/spring-data-rest-core-4.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.datatype/jackson-datatype-jdk8/2.17.1/76b495194c36058904c82e288d285a1bd13f0ffa/jackson-datatype-jdk8-2.17.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.core/jackson-core/2.17.1/5e52a11644cd59a28ef79f02bddc2cc3bab45edb/jackson-core-2.17.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.kafka/kafka-streams/3.7.0/bc6ebe8f19fe964a14a87edd0b4f009c546e0117/kafka-streams-3.7.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.core/jackson-annotations/2.17.1/fca7ef6192c9ad05d07bc50da991bf937a84af3a/jackson-annotations-2.17.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-couchbase/5.3.1/2b47933d67613ff4cbd90e36bd568dc747c58948/spring-data-couchbase-5.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.restdocs/spring-restdocs-mockmvc/3.0.1/105b72b6c72416492cd483045e902a8ba30e2b1b/spring-restdocs-mockmvc-3.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.restdocs/spring-restdocs-webtestclient/3.0.1/5faab99b39fb34d865aa7d4800e2d22b47491e01/spring-restdocs-webtestclient-3.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.restdocs/spring-restdocs-core/3.0.1/4fe6b10f656d1fc0f84860f5449866626c4be6b5/spring-restdocs-core-3.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.core/jackson-databind/2.17.1/524dcbcccdde7d45a679dfc333e4763feb09079/jackson-databind-2.17.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/ch.qos.logback/logback-classic/1.5.6/afc75d260d838a3bddfb8f207c2805ed7d1b34f9/logback-classic-1.5.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-jakarta-server/2.33.0/b4b9c8fe9069cd12d8ec6fa79964cabbea8836fb/artemis-jakarta-server-2.33.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-server/2.33.0/9268e60bca51745cbbae9bcecadc300fc0caccf8/artemis-server-2.33.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.ben-manes.caffeine/caffeine/3.1.8/24795585df8afaf70a2cd534786904ea5889c047/caffeine-3.1.8.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.hazelcast/hazelcast-spring/5.4.0/5e5f37782abc83485e693835aa470a59e0a5b110/hazelcast-spring-5.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.hazelcast/hazelcast/5.4.0/91f9e08c36d8a3c3d0c389b974321159874f3b68/hazelcast-5.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.zaxxer/HikariCP/5.1.0/8c96e36c14461fc436bb02b264b96ef3ca5dca8c/HikariCP-5.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.lettuce/lettuce-core/6.3.2.RELEASE/29b2aac09256c5fc2e9e9ad1df41c65dad5e557a/lettuce-core-6.3.2.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.kafka/spring-kafka/3.2.1/ebd9d79b63e9b343f589168a1441f4686a1daeda/spring-kafka-3.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-jakarta9/1.13.1/5dbc52b9e0f222edbc85c38543e01bc1836e1deb/micrometer-jakarta9-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-observation-test/1.13.1/85880bfce710bdd7bc3019ea03b66d8d0ee39084/micrometer-observation-test-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-tracing-bridge-brave/1.3.1/193e63079b70ae4278afb1cb6dc4bc64a4b6496b/micrometer-tracing-bridge-brave-1.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-tracing-bridge-otel/1.3.1/9028230f221b48ddd8e82d1e6a2744b2cb5d626d/micrometer-tracing-bridge-otel-1.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-tracing/1.3.1/c585a48056f62eb6dcd2748bc882fe118a9dcd8a/micrometer-tracing-1.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.amqp/spring-rabbit/3.1.6/e3d5fed3ca8f84b950afea6ce128e9ca81d3436b/spring-rabbit-3.1.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.batch/spring-batch-core/5.1.2/461b30be2f5e0daaa7fb96e9fbcb98b2a1c12e24/spring-batch-core-5.1.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.graphql/spring-graphql/1.3.1/15bb7a02053a0835a45f7ebf8c072e015d561d1a/spring-graphql-1.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-jpa/3.3.1/bf75f2140be9325d78de2c1c88eb9b7388a41bb1/spring-data-jpa-3.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-mongodb/4.3.1/e67d7b3d8eb93066ab9a9e26fc99957b42580c4/spring-data-mongodb-4.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-ldap/3.3.1/f671bc490f8a7e4f3727cb966560ab3781b89c5c/spring-data-ldap-3.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-webmvc/6.1.10/476344c2f21ab070bc72108375d9355f2ec0ddd1/spring-webmvc-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.integration/spring-integration-jmx/6.3.1/92400386a18f5ac54cd5e5284b1eea7aeff070dd/spring-integration-jmx-6.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.integration/spring-integration-core/6.3.1/dab59a2af6e1ecb9cbcee2b11ab48829d9c2e4cf/spring-integration-core-6.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-config/6.3.1/e4f6c1cf4f8969c9e5ed26121f0fbd7ee35a7ca4/spring-security-config-6.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-oauth2-resource-server/6.3.1/cfde67bb939df6b9683f0779b82c2e007733f265/spring-security-oauth2-resource-server-6.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-saml2-service-provider/6.3.1/d01dff21bf3db4831083373d9361691039ec7241/spring-security-saml2-service-provider-6.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-test/6.3.1/d583178e488bc2c165876a1c053c72b3d619cf10/spring-security-test-6.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-web/6.3.1/aff43933f28c808252b2d31f768b92fa61b634f6/spring-security-web-6.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-redis/3.3.1/711c360a0998962e7e5384576976ceb3b0220b70/spring-data-redis-3.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-context-support/6.1.10/e51a2bdfcc004ae6e420edcfb29e628aaf26e00c/spring-context-support-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-keyvalue/3.3.1/c2433ea3ae3c72ec6ef8c92aa45215942d240c04/spring-data-keyvalue-3.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-oauth2-jose/6.3.1/442a8af56b7f108473e146af0b21bd3b1538e194/spring-security-oauth2-jose-6.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-oauth2-core/6.3.1/2f68a3b5a10022599b72430eb89bde5e6630975c/spring-security-oauth2-core-6.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-core/6.3.1/598c2461a17c29705ca7fd8c02efd23a1f650ccd/spring-security-core-6.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.hateoas/spring-hateoas/2.3.0/5c57e47876479ccfde51f1b095e6e25a23f28bd0/spring-hateoas-2.3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.plugin/spring-plugin-core/3.0.0/d56aa02dd7272dca30aa598dc8b72e823227046a/spring-plugin-core-3.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-context/6.1.10/6f869ea35a26028f3bfbfb52c72ef2b077fbb6e5/spring-context-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-jms/6.1.10/6cef1c0f516105c76c2083dbf7efe7cb8cc28ece/spring-jms-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cache2k/cache2k-micrometer/2.6.1.Final/58731da010cc872915e012325027954bdc3122c8/cache2k-micrometer-2.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hibernate.orm/hibernate-micrometer/6.5.2.Final/a3742bffc90b8d39c3d3f69a6bfc341d34322817/hibernate-micrometer-6.5.2.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-stackdriver/1.13.1/8389e8fe7af3a0146fb85be33ec5d6f317d1d5e2/micrometer-registry-stackdriver-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.ext/jersey-micrometer/3.1.7/a2ae486634231734510579bf871c73b8556ce509/jersey-micrometer-3.1.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-appoptics/1.13.1/9b465974bdfde2667af0810da48277d26f2b9bb8/micrometer-registry-appoptics-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-atlas/1.13.1/ddf8ddc2beddcc55c0b5a3ec93826180e81e3afa/micrometer-registry-atlas-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-datadog/1.13.1/e25f07c053fe87495cfdb5451a458992d6d10084/micrometer-registry-datadog-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-dynatrace/1.13.1/65d19fcc8133ef5f6b621cacbb639a88b55f801d/micrometer-registry-dynatrace-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-elastic/1.13.1/579c9faf4442868a2be26b1a7854e993b7498eb3/micrometer-registry-elastic-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-ganglia/1.13.1/a31fb1a6bbf94334bad22664b546aed16cc934c7/micrometer-registry-ganglia-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-graphite/1.13.1/9aacd7a82ae8f65964a396da1a8aeb715f77e0f3/micrometer-registry-graphite-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-humio/1.13.1/39cd37ea2a539c116e506629a4789f8a8d16aa5d/micrometer-registry-humio-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-influx/1.13.1/7ea9d10109f2b14f188d47f74a27562220c349cb/micrometer-registry-influx-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-jmx/1.13.1/bc74f62f06fe9c686b50a289ce7cfff892aa7774/micrometer-registry-jmx-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-kairos/1.13.1/fa336ed210a41ddf381861a6c9843e595f39b32d/micrometer-registry-kairos-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-new-relic/1.13.1/c273052d743306ab7a9fd2b2a886b444aa21da33/micrometer-registry-new-relic-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-otlp/1.13.1/46b9f1928775882c8da783ca4496fd0f76ca4551/micrometer-registry-otlp-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-prometheus/1.13.1/153cf08090f3743154be84a3bc02c33ebfcd3d9d/micrometer-registry-prometheus-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-prometheus-simpleclient/1.13.1/f0da0fc05043cd7f35c1a78b6f9c3efeb4380491/micrometer-registry-prometheus-simpleclient-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-signalfx/1.13.1/70302a829fbd44c39349c986b5e736d4032b6f04/micrometer-registry-signalfx-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-statsd/1.13.1/db2adac504b98668dcd1a795f24a1604b57e23e6/micrometer-registry-statsd-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-core/1.13.1/b00758ad616bd820d793f305215f0b80b9a08fd8/micrometer-core-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-webflux/6.1.10/c8d75066a9f8af61681be635ea0e61cef320b53e/spring-webflux-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-web/6.1.10/876a856af61ef5712fb9a3013b798aa2b4a9475e/spring-web-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-observation/1.13.1/f6f5fa79e482431531cc253a7204e5c085c7bb20/micrometer-observation-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/simpleclient_pushgateway/0.16.0/65935d9855ece6f85c21ad38634703d0917bf88c/simpleclient_pushgateway-0.16.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.reporter2/zipkin-reporter-brave/3.4.0/4097b2a4d61646071e15f990459ac5e315227999/zipkin-reporter-brave-3.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.reporter2/zipkin-sender-urlconnection/3.4.0/6da700eb89a42d69bf8c7e5d99375f61373982cf/zipkin-sender-urlconnection-3.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-zipkin/1.37.0/d4aa3b20f16131fcfc94059692ee46c6edb30444/opentelemetry-exporter-zipkin-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-otlp/1.37.0/c54e41827e2fbf089aaf6a2f7a4fca7795e8b9c1/opentelemetry-exporter-otlp-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor.netty/reactor-netty-http/1.1.20/8d4ee98405a5856cf0c9d7c1a70f3f14631e3c46/reactor-netty-http-1.1.20.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.r2dbc/r2dbc-pool/1.0.1.RELEASE/41ec552a21fc0884dfb85335bd3f4c757a269ab1/r2dbc-pool-1.0.1.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.r2dbc/r2dbc-proxy/1.1.5.RELEASE/ca3de357825915774cf2464deeaf470c368c7cd7/r2dbc-proxy-1.1.5.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.r2dbc/r2dbc-h2/1.0.0.RELEASE/b99b52c87e7f32136f58131ad7b7a3e2eb168f75/r2dbc-h2-1.0.0.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.r2dbc/r2dbc-spi/1.0.0.RELEASE/e3d15b2d27fdb8fdb76a181b21d5c752adf1d165/r2dbc-spi-1.0.0.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/activemq-client/6.1.2/29c1e3ba1d6d6b4b8f215387c4754f53a0cde94e/activemq-client-6.1.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-jakarta-service-extensions/2.33.0/eaa812948ad099dd94387be5953becf26717b4fe/artemis-jakarta-service-extensions-2.33.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-jakarta-client/2.33.0/402d24fdb2e72f323950c970ec222654b9756a51/artemis-jakarta-client-2.33.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.jms/jakarta.jms-api/3.1.0/e194cf91a3f908e4846542849ac11a8e0b3c68ad/jakarta.jms-api-3.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hibernate.orm/hibernate-core/6.5.2.Final/e9e0cc47f6cd2b2553968aee66bd9e55e7485221/hibernate-core-6.5.2.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.persistence/jakarta.persistence-api/3.1.0/66901fa1c373c6aff65c13791cc11da72060a8d6/jakarta.persistence-api-3.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.undertow/undertow-servlet/2.3.13.Final/b1de937a4a6b5c941e5dda5d6a37c86f09103860/undertow-servlet-2.3.13.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty.ee10/jetty-ee10-webapp/12.0.10/8eab75fc65cb5d9d0058894ab37fb21e6c9415be/jetty-ee10-webapp-12.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty.ee10/jetty-ee10-servlet/12.0.10/a8d087bde78f231084901553bb6829663b4a22f1/jetty-ee10-servlet-12.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.servlet/jakarta.servlet-api/6.0.0/abecc699286e65035ebba9844c03931357a6a963/jakarta.servlet-api-6.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/javax.cache/cache-api/1.1.1/c56fb980eb5208bfee29a9a5b9d951aba076bd91/cache-api-1.1.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-jdbc-store/2.33.0/4b2e18b3736a9dad998b48107ace88edf865e6f/artemis-jdbc-store-2.33.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-dbcp2/2.12.0/45698ece9fda230d0b1c96282c03ce1ebbd6c3ce/commons-dbcp2-2.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.kafka/kafka-clients/3.7.0/b8f9f75bc3edc06f842dd16071465544198bc045/kafka-clients-3.7.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.logging.log4j/log4j-to-slf4j/2.23.1/425ad1eb8a39904d2830e907a324e956fb456520/log4j-to-slf4j-2.23.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.logging.log4j/log4j-api/2.23.1/9c15c29c526d9c6783049c0a77722693c66706e1/log4j-api-2.23.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat.embed/tomcat-embed-core/10.1.25/c1e5ee12f537e6b4fea2b98a7160dcf0db610561/tomcat-embed-core-10.1.25.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat.embed/tomcat-embed-el/10.1.25/2f030e4971e29245c10e58723fb6b364ce23933b/tomcat-embed-el-10.1.25.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat/tomcat-jdbc/10.1.25/7a7868ce37097aa8fcd4f1cbd6cb902cb9270816/tomcat-jdbc-10.1.25.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-aspects/6.1.10/8d869a8bcc99e71b98b9d5ca141539d6e6ba3061/spring-aspects-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.aspectj/aspectjweaver/1.9.22/10736ab74a53af5e2e1b07e76335a5391526b6f8/aspectjweaver-1.9.22.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cache2k/cache2k-spring/2.6.1.Final/cd312efb1645de91bdd8571b98273cb0acf52d15/cache2k-spring-2.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.angus/angus-mail/2.0.3/56f811522d693700013768db83b741a65da6c61c/angus-mail-2.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-ee/12.0.10/51d7c54b0d51eeece2918b73d304f95d9d4ed80d/jetty-ee-12.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-session/12.0.10/96dd580a79d938b532e8cff47475efbcaa80ea58/jetty-session-12.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-security/12.0.10/a7bd8056fa84439411f60fedd8a94b1983880cf9/jetty-security-12.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-server/12.0.10/dcdef1c9ead5040e6b637512ab1794191058a22/jetty-server-12.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/co.elastic.clients/elasticsearch-java/8.13.4/3c8e5b92bef09595d94dd607810a1c2697a743ad/elasticsearch-java-8.13.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.elasticsearch.client/elasticsearch-rest-client/8.13.4/eb5be3f924f72faaec1df2a6a3890147e00d27ec/elasticsearch-rest-client-8.13.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.ext/jersey-spring6/3.1.7/7d9345d4ecc0b5370e01037f77ef166bf3091a54/jersey-spring6-3.1.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.containers/jersey-container-servlet-core/3.1.7/245f1fe64443033d46cad33163e7acd659ee3071/jersey-container-servlet-core-3.1.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.core/jersey-server/3.1.7/fed4e119e3502b83ecb019ddf694b8b74c495a05/jersey-server-3.1.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hibernate.validator/hibernate-validator/8.0.1.Final/e49e116b3d3928060599b176b3538bb848718e95/hibernate-validator-8.0.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.influxdb/influxdb-java/2.24/638b1ca7c63aa94ce7024fc7bebb1e458a3fb6f6/influxdb-java-2.24.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.liquibase/liquibase-core/4.27.0/759da7263b8b282202d8a157a0c47653b92e473e/liquibase-core-4.27.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/mongodb-driver-reactivestreams/5.0.1/26841dc96d29883ccdd1d0f51cdaa003390b893d/mongodb-driver-reactivestreams-5.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/mongodb-driver-sync/5.0.1/3723fc6a032986dc4cb1c4929bafa85ce9f93950/mongodb-driver-sync-5.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.neo4j.driver/neo4j-java-driver/5.21.0/345727d93af0ade46f71f76aae400eefa3881365/neo4j-java-driver-5.21.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.quartz-scheduler/quartz/2.3.2/18a6d6b5a40b77bd060b34cb9f2acadc4bae7c8a/quartz-2.3.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-orm/6.1.10/b4cd93ddd043407b3ba3fdfca3b07db776581fec/spring-orm-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-jdbc/6.1.10/bba7d7de1d944443bd9e45d0ebcbbb6ec6864be0/spring-jdbc-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-messaging/6.1.10/7bdfa101b8e38c450738c4eb040ca7686ccb4ab9/spring-messaging-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.session/spring-session-core/3.3.1/24d478aaf5f5b4f14013ca22a5735caf93758951/spring-session-core-3.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/redis.clients/jedis/5.0.2/47d917ce322cef3fc1fbe7534f351e25d977e52b/jedis-5.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor/reactor-test/3.6.7/283b9125a7384da6da015a06ecba7fbda7d961e9/reactor-test-3.6.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-exposition-formats/1.2.1/64190364467197c39bcc296ec80a99f6c979a7dc/prometheus-metrics-exposition-formats-1.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.okhttp3/mockwebserver/4.12.0/3bc54cc5c87cd632031d0881f3c313d3799a1476/mockwebserver-4.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.jayway.jsonpath/json-path/2.9.0/37fe2217f577b0b68b18e62c4d17a8858ecf9b69/json-path-2.9.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.undertow/undertow-core/2.3.13.Final/249236b81e21dc26066232086bb54c73b34a3ecc/undertow-core-2.3.13.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jaxb/jaxb-runtime/4.0.5/ca84c2a7169b5293e232b9d00d1e4e36d4c3914a/jaxb-runtime-4.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jaxb/jaxb-core/4.0.5/7b4b11ea5542eea4ad55e1080b23be436795b3/jaxb-core-4.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.xml.bind/jakarta.xml.bind-api/4.0.2/6cd5a999b834b63238005b7144136379dc36cad2/jakarta.xml.bind-api-4.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.aspectj/aspectjrt/1.9.22/99757727fd7242c2198af164435fa95fdb25b50d/aspectjrt-1.9.22.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-core-test/6.1.10/f9ba5972158c4d0a604fa2a5514a2a9f1dce0ad7/spring-core-test-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.assertj/assertj-core/3.25.3/792b270e73aa1cfc28fa135be0b95e69ea451432/assertj-core-3.25.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.awaitility/awaitility/4.2.1/e56b600e0b184182ba5b2baccd2bab593a98a624/awaitility-4.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cache2k/cache2k-core/2.6.1.Final/7e333caaafa2bf4e489b58537b5c4218a4e6505/cache2k-core-2.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cache2k/cache2k-api/2.6.1.Final/6afd23d7897fff56515f0cefa6a846bdebe10bce/cache2k-api-2.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hamcrest/hamcrest-library/2.2/cf530c8a0bc993487c64e940ae639bb4a6104dc6/hamcrest-library-2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/junit/junit/4.13.2/8ac9e16d933b6fb43bc7f576336b8f4d7eb5ba12/junit-4.13.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hamcrest/hamcrest-core/2.2/3f2bd07716a31c395e2837254f37f21f0f0ab24b/hamcrest-core-2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hamcrest/hamcrest/2.2/1820c0968dba3a11a1b30669bb1f01978a91dedc/hamcrest-2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hsqldb/hsqldb/2.7.3/85b49338b36f3051d217295596cf92beb92e4bfb/hsqldb-2.7.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.platform/junit-platform-launcher/1.10.2/8125dd29e847ca274dd1a7a9ca54859acc284cb3/junit-platform-launcher-1.10.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mockito/mockito-junit-jupiter/5.11.0/8e658dd339f40305ed4293db25545b5df98b171b/mockito-junit-jupiter-5.11.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.jupiter/junit-jupiter-params/5.10.2/359132c82a9d3fa87a325db6edd33b5fdc67a3d8/junit-jupiter-params-5.10.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.jupiter/junit-jupiter-engine/5.10.2/f1f8fe97bd58e85569205f071274d459c2c4f8cd/junit-jupiter-engine-5.10.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.jupiter/junit-jupiter-api/5.10.2/fb55d6e2bce173f35fd28422e7975539621055ef/junit-jupiter-api-5.10.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.platform/junit-platform-engine/1.10.2/d53bb4e0ce7f211a498705783440614bfaf0df2e/junit-platform-engine-1.10.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.platform/junit-platform-commons/1.10.2/3197154a1f0c88da46c47a9ca27611ac7ec5d797/junit-platform-commons-1.10.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.jupiter/junit-jupiter/5.10.2/831c0b86ddc2ce38391c5b81ea662b0cfdc02cce/junit-jupiter-5.10.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mockito/mockito-core/5.11.0/e4069fa4f4ff2c94322cfec5f2e45341c6c70aff/mockito-core-5.11.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.skyscreamer/jsonassert/1.5.1/6d842d0faf4cf6725c509a5e5347d319ee0431c3/jsonassert-1.5.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.yaml/snakeyaml/2.2/3af797a25458550a16bf89acc8e4ab2b7f2bfce0/snakeyaml-2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.management.j2ee/jakarta.management.j2ee-api/1.1.4/dbbe7575f97efd0b04f3a8455cf82c256c853055/jakarta.management.j2ee-api-1.1.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.transaction/jakarta.transaction-api/2.0.1/51a520e3fae406abb84e2e1148e6746ce3f80a1a/jakarta.transaction-api-2.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-saml-impl/4.0.1/995986fd848ede1443469f3aff1f82b740224262/opensaml-saml-impl-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-saml-api/4.0.1/2205aba935f4da468382a3dc5f32c3821ec1564c/opensaml-saml-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-soap-impl/4.0.1/38bfaf5fc189774e94ead218bd1c754da295c226/opensaml-soap-impl-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-profile-api/4.0.1/bece5f6d30d4051e6eeaf2b88dd1e5a13f6b28b7/opensaml-profile-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-soap-api/4.0.1/d8e11e31cb5164788a530478e1831969e94a38b6/opensaml-soap-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-xmlsec-impl/4.0.1/efa15ba85127ac3b20c75b8d4f04c7e92325a00a/opensaml-xmlsec-impl-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-xmlsec-api/4.0.1/edb4365d3d183933cf0d0b31966ea352b8d20c60/opensaml-xmlsec-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-security-impl/4.0.1/64568e9aa8bd7bcd76983e462f9eb2c3dcacbdce/opensaml-security-impl-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-security-api/4.0.1/f3d33ca18cde2a7c7e3643aeca9f03974be9577d/opensaml-security-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-messaging-api/4.0.1/eb9c9971f6bd2a6681a2a692a1f29a35874de389/opensaml-messaging-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-core/4.0.1/ec3d1734137d6ccabba7d6d5e149f571beeaa673/opensaml-core-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-test/6.1.10/82d3c12836121e37843f21bf382a8c46c0448b59/spring-test-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.ldap/spring-ldap-core/3.2.4/96d060e8a3d0edd1f7de64015f37eb243ae12f3e/spring-ldap-core-3.2.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-tx/6.1.10/1a2361bc1881ed1a0dc2e09561e8f560e1949c8e/spring-tx-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.amqp/spring-amqp/3.1.6/173c0388be9ae83c4bea13400a517235e06c3efe/spring-amqp-3.1.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-aop/6.1.10/aa6a147eb08820fb503a992a8fe2c9fee3439129/spring-aop-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-commons/3.3.1/fe179b4f9f5d4fafdcf9e2a2030033d61423c3f6/spring-data-commons-3.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-oxm/6.1.10/9db3d67a285fca31091d7c97a45de68842c38796/spring-oxm-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-beans/6.1.10/a49252929fb2918f73eb7659ef98dff7306a7c2c/spring-beans-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.batch/spring-batch-infrastructure/5.1.2/bfc8439a45a0681f44771d3b15f5c61fe4751db7/spring-batch-infrastructure-5.1.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-expression/6.1.10/a17d61f1388d0e13d6e7a740304e9d648fffc7c/spring-expression-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-core/6.1.10/eaf5b1f3e3bb5aa8b45ab255cf3270c1c4578f1d/spring-core-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.vaadin.external.google/android-json/0.0.20131108.vaadin1/fa26d351fe62a6a17f5cda1287c1c6110dec413f/android-json-0.0.20131108.vaadin1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.mchange/c3p0/0.9.5.5/37dfc3021e5589d65ff2ae0becf811510b87ab01/c3p0-0.9.5.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-resolver-provider/3.9.4/d5e38634c1251e000f7718437973a730346bc336/maven-resolver-provider-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-model-builder/3.9.4/b12e45736ddfb51f648e1579877a293659e5a96e/maven-model-builder-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-connector-basic/1.9.14/ffeb368f5587513b29ef9771514ec36d246e65f5/maven-resolver-connector-basic-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-impl/1.9.14/2aa090aca572f7061e5c57f714ef0445bbb4555f/maven-resolver-impl-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-transport-http/1.9.14/1eb4acdce7f21526bd06654b3d7b1edf80370ce8/maven-resolver-transport-http-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-spi/1.9.14/a190c3d49791240c87799f29848505fc9fd8be11/maven-resolver-spi-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-util/1.9.14/ea6fd2997903700191711dee4448746ed30fe4b9/maven-resolver-util-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-api/1.9.14/bd5b7cd9d15c2efcab4d8c8215e769523e8843e4/maven-resolver-api-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/context-propagation/1.1.1/7c62beb1188d7458f5a4b60fcaf4a795cc290508/context-propagation-1.1.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.core/jersey-client/3.1.7/7c49b9703ac868d2e11df6a3fe2b455abc42dca9/jersey-client-3.1.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.inject/jersey-hk2/3.1.7/3f11846472c1f13d4f4f37593e0d16bd47fe01da/jersey-hk2-3.1.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.core/jersey-common/3.1.7/1d8d9a904de672674286af92b0f63251e6694ce5/jersey-common-3.1.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2/3.0.6/12187beb6321e6a7fdc2ef4d196e16c8c58a3a1/hk2-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-core/3.0.6/78dfb2117c3148e357a0cec8f514e60bbf689efd/hk2-core-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-runlevel/3.0.6/3c347e9bb20f13d98b72ae2b4fc84f14bcbb187e/hk2-runlevel-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-locator/3.0.6/92d5c92c9f23bea4b8681c6f8d6ba3d708619f81/hk2-locator-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-api/3.0.6/5a5152dea2c43384f5c07985eb27140134074ecb/hk2-api-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-utils/3.0.6/b3187d0673c0fd52de197e52c62545c34d4eda29/hk2-utils-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.inject/jakarta.inject-api/2.0.1/4c28afe1991a941d7702fe1362c365f0a8641d1e/jakarta.inject-api-2.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-storage-api/4.0.1/4e46a7f965ac9f91976b0f298fd4d4e69e9056db/opensaml-storage-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.shibboleth.utilities/java-support/8.0.0/298f946e93922d789b6231599a446cea9dbbe80e/java-support-8.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.santuario/xmlsec/2.1.4/cb43326f02e3e77526c24269c8b5d3cc3f7f6653/xmlsec-2.1.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.cloud/google-cloud-monitoring/3.43.0/8423352e76f7e3b8c363cfef3298af4284163c71/google-cloud-monitoring-3.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.auth/google-auth-library-oauth2-http/1.23.0/f9ebd75a55b8e2cfa62e1f66d04a62b46a2f3b70/google-auth-library-oauth2-http-1.23.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.http-client/google-http-client-gson/1.44.1/f3b8967c6f7078da6380687859d0873105f84d39/google-http-client-gson-1.44.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.http-client/google-http-client/1.44.1/d8956bacb8a4011365fa15a690482c49a70c78c5/google-http-client-1.44.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.httpcomponents/httpclient/4.5.14/1194890e6f56ec29177673f2f12d0b8e627dec98/httpclient-4.5.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/commons-codec/commons-codec/1.16.1/47bd4d333fba53406f6c6c51884ddbca435c8862/commons-codec-1.16.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opencensus/opencensus-contrib-http-util/0.31.1/3c13fc5715231fadb16a9b74a44d9d59c460cfa8/opencensus-contrib-http-util-0.31.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.guava/guava/33.1.0-jre/9b7ed39143d59e8eabcc6f91ffe4d23db2efe558/guava-33.1.0-jre.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api.grpc/proto-google-cloud-monitoring-v3/3.43.0/191267f5c2995f7cbb8863f0f0e8f2ea55c99739/proto-google-cloud-monitoring-v3-3.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.code.findbugs/jsr305/3.0.2/25ea2e8b0c338a877313bd4672d3fe056ea78f0d/jsr305-3.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.dropwizard.metrics/metrics-graphite/4.2.26/84dd3856e88931eb753db1155c22228178d26bbb/metrics-graphite-4.2.26.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.dropwizard.metrics/metrics-jmx/4.2.26/abafdb8fc03b47447e197248fda192d12c6a9130/metrics-jmx-4.2.26.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.dropwizard.metrics/metrics-core/4.2.26/9cd762999669e726f694a3ac8f9d8a1400cdb332/metrics-core-4.2.26.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.velocity/velocity-engine-core/2.2/68d899cb70cd27d495562fa808feb2da4926d38f/velocity-engine-core-2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-named-locks/1.9.14/71cf74d91b4f6de1bff8fc1fafb401d9ac42b1b8/maven-resolver-named-locks-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.zaxxer/HikariCP-java7/2.4.13/3e441eddedb374d4de8e3abbb0c90997f51cc97b/HikariCP-java7-2.4.13.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-core-client/2.33.0/31188ee6cf5b28736d7d22759cee89f269b1762f/artemis-core-client-2.33.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-selector/2.33.0/b2a96664e487de682f5349b53a8c3b3e37e619a4/artemis-selector-2.33.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-journal/2.33.0/71f43d0dad511aabedcaa8fc75ce0f4384fa7f98/artemis-journal-2.33.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-commons/2.33.0/d210a181d855171857c93c364dd7eb3113cf094c/artemis-commons-2.33.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-xml/12.0.10/fe893478d62893e2a50b24fe45d9ec751c399ecc/jetty-xml-12.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-http/12.0.10/71f438b9cf1ba0b3411c5eddd386eeeeca25168a/jetty-http-12.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-io/12.0.10/4d5ddfc6ad4d6504531861806fade68c7d477f1b/jetty-io-12.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.netflix.spectator/spectator-reg-atlas/1.7.13/b3df785a631303db26d140ce2b513662b91118e6/spectator-reg-atlas-1.7.13.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.rabbitmq/amqp-client/5.21.0/70797e8a66e800391940edcf21f31423b9768f1/amqp-client-5.21.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.graphql-java/graphql-java/22.0/faf262edab4c4cc76d2f3294de5cf35ebb5c3187/graphql-java-22.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.graphql-java/java-dataloader/3.3.0/1786c5efbf871395a32cbce1a2114d6788ac4f53/java-dataloader-3.3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-util/12.0.10/ec7c95b5a289560f4a7be57170f4fdbedde72b92/jetty-util-12.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.netflix.spectator/spectator-ext-ipc/1.7.13/30f2d9e47d359ea59d356a4be98c38def649c5fa/spectator-ext-ipc-1.7.13.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.netflix.spectator/spectator-api/1.7.13/b067b3786652e635cd58df512ca327f4f1c35cc/spectator-api-1.7.13.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.couchbase.client/java-client/3.6.2/729665435ed392a7bf36e251d399a0d141015f89/java-client-3.6.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.couchbase.client/core-io/2.6.2/e514de357630f60e1d565b776d187092e85b2984/core-io-2.6.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.slf4j/slf4j-api/2.0.13/80229737f704b121a318bba5d5deacbcf395bc77/slf4j-api-2.0.13.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.httpcomponents/httpcore/4.4.16/51cf043c87253c9f58b539c9f7e44c8894223850/httpcore-4.4.16.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.bytebuddy/byte-buddy/1.14.17/a8d08f3c1e75ecc7f38a8cfd7e9fa47919096373/byte-buddy-1.14.17.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.bytebuddy/byte-buddy-agent/1.14.17/e3c251a39dc90badaf71c83427ba46840f219d8d/byte-buddy-agent-1.14.17.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml/classmate/1.7.0/e98374da1f2143ac8e6e0a95036994bb19137a3/classmate-1.7.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.opencsv/opencsv/5.9/284ea0b60a24b71a530100783185e7d547ab5339/opencsv-5.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-configuration2/2.9.0/adc3ee6b84fc62a6e75e901d080adacb72aac61e/commons-configuration2-2.9.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-text/1.11.0/2bb044b7717ec2eccaf9ea7769c1509054b50e9a/commons-text-1.11.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-artifact/3.9.4/9738999a0459221e758ebe728449c43567d7fecc/maven-artifact-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-lang3/3.14.0/1ed471194b02f2c6cb734a0cd6f6f107c673afae/commons-lang3-3.14.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-pool2/2.12.0/458563f69fbdaebf7daadfe10dc3a22e42a7de50/commons-pool2-2.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.code.gson/gson/2.10.1/b3add478d4382b78ea20b1671390a858002feb6c/gson-2.10.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.h2database/h2/2.2.224/7bdade27d8cd197d9b5ce9dc251f41d2edc5f7ad/h2-2.2.224.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.httpcomponents/httpasyncclient/4.1.5/cd18227f1eb8e9a263286c1d7362ceb24f6f9b32/httpasyncclient-4.1.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.httpcomponents/httpcore-nio/4.4.16/cd21c80a9956be48c4c1cfd2f594ba02857d0927/httpcore-nio-4.4.16.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.angus/angus-activation/2.0.2/41f1e0ddd157c856926ed149ab837d110955a9fc/angus-activation-2.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.mail/jakarta.mail-api/2.1.3/a327aa5f514ba86e80d54584417d7376ed2bde0e/jakarta.mail-api-2.1.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.activation/jakarta.activation-api/2.1.3/fa165bd70cda600368eee31555222776a46b881f/jakarta.activation-api-2.1.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.annotation/jakarta.annotation-api/2.1.1/48b9bda22b091b1f48b13af03fe36db3be6e1ae3/jakarta.annotation-api-2.1.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.parsson/parsson/1.0.5/f68020271ff70f79412f70ca45973703b6e907c/parsson-1.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.json/jakarta.json-api/2.1.3/4febd83e1d9d1561d078af460ecd19532383735c/jakarta.json-api-2.1.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.validation/jakarta.validation-api/3.0.2/92b6631659ba35ca09e44874d3eb936edfeee532/jakarta.validation-api-3.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.ext/jersey-entity-filtering/3.1.7/ec4806d070c14760b26c40abbe86d9152b0ea4b9/jersey-entity-filtering-3.1.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.ws.rs/jakarta.ws.rs-api/3.1.0/15ce10d249a38865b58fc39521f10f29ab0e3363/jakarta.ws.rs-api-3.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jboss.xnio/xnio-nio/3.8.8.Final/a5d2faf8d02e0a0bb9e9eabca8e38173cb640331/xnio-nio-3.8.8.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jboss.xnio/xnio-api/3.8.8.Final/1ba9c8b9a8dea1c6cd656155943e6d4c2c631fa7/xnio-api-3.8.8.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.wildfly.client/wildfly-client-config/1.0.1.Final/2a803b23c40a0de0f03a90d1fd3755747bc05f4b/wildfly-client-config-1.0.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jboss.threads/jboss-threads/3.5.0.Final/dd23d4788b3eafe9597ef3fe028e46ceb293ba8d/jboss-threads-3.5.0.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jboss.logging/jboss-logging/3.5.3.Final/c88fc1d8a96d4c3491f55d4317458ccad53ca663/jboss-logging-3.5.3.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.minidev/json-smart/2.5.1/4c11d2808d009132dfbbf947ebf37de6bf266c8e/json-smart-2.5.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/ch.qos.logback/logback-core/1.5.6/41cbe874701200c5624c19e0ab50d1b88dfcc77d/logback-core-1.5.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/mongodb-driver-core/5.0.1/f9a18eb8015b9e05f0312c9e5752dcdc01dbd784/mongodb-driver-core-5.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/bson-record-codec/5.0.1/7d856a5b4250b22ec011661b4fca260663b452d5/bson-record-codec-5.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/bson/5.0.1/757035ed1e9c94fa95ee13b1f9a0af93269ff20/bson-5.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor.addons/reactor-pool/1.0.6/a43af2585f3e1e673b9b6c5e373c49fa6d6f9b58/reactor-pool-1.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor.netty/reactor-netty-core/1.1.20/1a5ef52a470a82d9313e2e1ad8ba064bdbd38948/reactor-netty-core-1.1.20.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor/reactor-core/3.6.7/6d1918147645b5b8e577555a89ab271319f25d2f/reactor-core-3.6.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.reactivestreams/reactive-streams/1.0.4/3864a1320d97d7b045f729a326e1e077661f31b7/reactive-streams-1.0.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.retry/spring-retry/2.0.6/812ca80eb5f418c679cb239d2d009c4bf075f3a/spring-retry-2.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat/tomcat-annotations-api/10.1.25/cf0a9083fd08aba5db0233abdd1b88d064658a95/tomcat-annotations-api-10.1.25.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-model/3.9.4/5b79d873cf6d13b3fc4020eac04e2a62ebbfa0aa/maven-model-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-repository-metadata/3.9.4/ef368d45a2caa54634de221540994ca2d810c4c9/maven-repository-metadata-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.codehaus.plexus/plexus-utils/3.5.1/c6bfb17c97ecc8863e88778ea301be742c62b06d/plexus-utils-3.5.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.guava/failureaccess/1.0.2/c4a06a64e650562f30b7bf9aaec1bfed43aca12b/failureaccess-1.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.guava/listenablefuture/9999.0-empty-to-avoid-conflict-with-guava/b421526c5f297295adef1c886e5246c39d4ac629/listenablefuture-9999.0-empty-to-avoid-conflict-with-guava.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.checkerframework/checker-qual/3.42.0/638ec33f363a94d41a4f03c3e7d3dcfba64e402d/checker-qual-3.42.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.errorprone/error_prone_annotations/2.26.1/c1fde57694bdc14e8618899aaa6e857d9465d7de/error_prone_annotations-2.26.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.j2objc/j2objc-annotations/3.0.0/7399e65dd7e9ff3404f4535b2f017093bdb134c7/j2objc-annotations-3.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cryptacular/cryptacular/1.2.4/4994c015d87886212683245d13e87f6fb903a760/cryptacular-1.2.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.bouncycastle/bcpkix-jdk15on/1.64/3dac163e20110817d850d17e0444852a6d7d0bd7/bcpkix-jdk15on-1.64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.bouncycastle/bcprov-jdk15on/1.64/1467dac1b787b5ad2a18201c0c281df69882259e/bcprov-jdk15on-1.64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.woodstox/woodstox-core/6.6.2/bfe905f19ce0e60bff5b7adcbded2681a092ac3/woodstox-core-6.6.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-lockmanager-api/2.33.0/7d3c17131b976abf5936be628cf92855b9ce491b/artemis-lockmanager-api-2.33.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.reporter2/zipkin-sender-okhttp3/3.4.0/bfd67147f2541cfef427cea03ed3338c497c24d4/zipkin-sender-okhttp3-3.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.reporter2/zipkin-reporter/3.4.0/63c8954dfd095e6f99066234213e5c2cf95caafe/zipkin-reporter-3.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.zipkin2/zipkin/2.27.1/74b5227ae2fe515217107fd228707e4d960ec3ec/zipkin-2.27.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.aws/brave-propagation-aws/1.2.5/828490df0b6be58b6de4d3dd3b3a395fb8243f45/brave-propagation-aws-1.2.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.brave/brave-context-slf4j/6.0.3/a863730f5af570514b4fa4b920c8455c9556d9cd/brave-context-slf4j-6.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.brave/brave-instrumentation-http/6.0.3/bc58655bd14d2f8e8975c5951fecab202e1a1e5/brave-instrumentation-http-6.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.brave/brave/6.0.3/2d626aaf5162463edefcc88291799d5ea9204630/brave-6.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.datastax.oss/native-protocol/1.5.1/97e812373a5fe7667384e7ad67819d2c71878bf8/native-protocol-1.5.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.datastax.oss/java-driver-shaded-guava/25.1-jre-graal-sub-1/522771d14d6b7dba67056a39db33f205ffbed6a4/java-driver-shaded-guava-25.1-jre-graal-sub-1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jaxb/txw2/4.0.5/f36a4ef12120a9bb06d766d6a0e54b144fd7ed98/txw2-4.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.sun.istack/istack-commons-runtime/4.1.2/18ec117c85f3ba0ac65409136afa8e42bc74e739/istack-commons-runtime-4.1.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.okhttp3/logging-interceptor/4.12.0/e922c1f14d365c0f2bed140cc0825e18462c2778/logging-interceptor-4.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-sender-okhttp/1.37.0/821912a6b2641ce1b07220067d874c8bcfe4c45b/opentelemetry-exporter-sender-okhttp-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.retrofit2/converter-moshi/2.9.0/db0979801926e6d39bc2478736145f9761c3e034/converter-moshi-2.9.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.retrofit2/retrofit/2.9.0/d8fdfbd5da952141a665a403348b74538efc05ff/retrofit-2.9.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.okhttp3/okhttp/4.12.0/2f4525d4a200e97e1b87449c2cd9bd2e25b7e8cd/okhttp-4.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.okio/okio-jvm/3.6.0/5600569133b7bdefe1daf9ec7f4abeb6d13e1786/okio-jvm-3.6.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jetbrains.kotlin/kotlin-stdlib-jdk8/1.9.24/a2f6d82081a54b52ceb120c5a18f87402ccab0c/kotlin-stdlib-jdk8-1.9.24.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jetbrains.kotlin/kotlin-stdlib-jdk7/1.9.24/46b6e1099acabc71feca1c0013deee78e6793d07/kotlin-stdlib-jdk7-1.9.24.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jetbrains.kotlin/kotlin-stdlib/1.9.24/9928532f12c66ad816a625b3f9984f8368ca6d2b/kotlin-stdlib-1.9.24.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-commons/1.13.1/5629ecbcc84a9f29e1cf976718de2497e50932bf/micrometer-commons-1.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec-http2/4.1.111.Final/f0cca5df75bfb4f858d0435f601d8b1cae1de054/netty-codec-http2-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-handler-proxy/4.1.111.Final/1e459c8630bb7c942b79a97e62dd728798de6a8c/netty-handler-proxy-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec-http/4.1.111.Final/c6ecbc452321e632bf3cea0f9758839b650455c7/netty-codec-http-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-resolver-dns-native-macos/4.1.111.Final/aeef447d930ddfcdc80a8b2c67eb9b5d781d6354/netty-resolver-dns-native-macos-4.1.111.Final-osx-x86_64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-resolver-dns-classes-macos/4.1.111.Final/c21cc719234e5553c3b65f29defb4b383edc8fd2/netty-resolver-dns-classes-macos-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-resolver-dns/4.1.111.Final/5ac6a3d96935129ba45ea768ad30e31cad0d8c4d/netty-resolver-dns-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-handler/4.1.111.Final/2bc6a58ad2e9e279634b6e55022e8dcd3c175cc4/netty-handler-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-native-epoll/4.1.111.Final/e102a0568f4f2cd7d4049c4154f94528cadf646b/netty-transport-native-epoll-4.1.111.Final-linux-x86_64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-classes-epoll/4.1.111.Final/8b97d32eb1489043e478deea99bd93ce487b82f6/netty-transport-classes-epoll-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-native-kqueue/4.1.111.Final/7d5baf959ccdbfb1586a2d42c9cbfe78e54e6841/netty-transport-native-kqueue-4.1.111.Final-osx-x86_64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-classes-kqueue/4.1.111.Final/baa6572d718f6e0bf3a6947278ca604f5d947dd8/netty-transport-classes-kqueue-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-native-unix-common/4.1.111.Final/acafc128cddafa021bc0b48b0788eb0e118add5e/netty-transport-native-unix-common-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec-socks/4.1.111.Final/ea52ef6617a9b69b0baaebb7f0b80373527f9607/netty-codec-socks-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec-dns/4.1.111.Final/f988dbb527efb0e7cf7d444cc50b0fc3f5f380ec/netty-codec-dns-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec/4.1.111.Final/a6762ec00a6d268f9980741f5b755838bcd658bf/netty-codec-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport/4.1.111.Final/24e97cf14ea9d80afe4c5ab69066b587fccc154a/netty-transport-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-buffer/4.1.111.Final/b54863f578939e135d3b3aea610284ae57c188cf/netty-buffer-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-resolver/4.1.111.Final/3493179999f211dc49714319f81da2be86523a3b/netty-resolver-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-common/4.1.111.Final/58210befcb31adbcadd5724966a061444db91863/netty-common-4.1.111.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-tcnative-classes/2.0.65.Final/3a7aecd4bcaf75c7b0b02c26ea6ceacf3e8f5f4d/netty-tcnative-classes-2.0.65.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-otlp-common/1.37.0/444d869b5773695c6fb0192d77b1304361e6a765/opentelemetry-exporter-otlp-common-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-common/1.37.0/6359022f97208fbec5f458749611e37fa3fc9404/opentelemetry-exporter-common-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-extension-autoconfigure-spi/1.37.0/bb9097589c4e4569e77e634477baabc76a755bc4/opentelemetry-sdk-extension-autoconfigure-spi-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk/1.37.0/e71abf2eaa1b7f91b9689d86d919b7d1c00faa3c/opentelemetry-sdk-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-trace/1.37.0/9875634a47d8e1e150df963ceba8a707547ab00a/opentelemetry-sdk-trace-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-metrics/1.37.0/49eb5a745be2bce3663a1a4f2ebc963e8a78620/opentelemetry-sdk-metrics-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-logs/1.37.0/d1b3fe627a0343c35a1b803f68ad596a1b231a25/opentelemetry-sdk-logs-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-common/1.37.0/7e1421111afbffca43f6aa65d2a60a606bc1da5b/opentelemetry-sdk-common-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-extension-trace-propagators/1.37.0/72e9f95ec089cbf711ac9d5cf37a131e34d709a/opentelemetry-extension-trace-propagators-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry.instrumentation/opentelemetry-instrumentation-api-semconv/1.33.3-alpha/9b26012e6c08d39441e2f44af181311bbd9bbb09/opentelemetry-instrumentation-api-semconv-1.33.3-alpha.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry.instrumentation/opentelemetry-instrumentation-api/1.33.3/133644185f680998c454ed738afcb459b211f6db/opentelemetry-instrumentation-api-1.33.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-api-incubator/1.38.0-alpha/27a5bf8657cf41181c3fd6768f1e86468a73ed9c/opentelemetry-api-incubator-1.38.0-alpha.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-api/1.37.0/9b4bdeb434885fdf417967ddea37afe4d21fab4e/opentelemetry-api-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-context/1.37.0/f180a3855a9dd8c1cf4fddabcfbd4d0a55c4996b/opentelemetry-context-1.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-core/1.2.1/362330b5934a128e91e331f1497cd275fec1a81c/prometheus-metrics-core-1.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-config/1.2.1/bcccb14176161671c4cb858b0ca50d680237fdbe/prometheus-metrics-config-1.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-model/1.2.1/99caac1a3f974de6bc9882fbf6a09ea055733c7b/prometheus-metrics-model-1.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-tracer-common/1.2.1/74cc4ac3226a3937d6e5c74c06454258e7901cec/prometheus-metrics-tracer-common-1.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-shaded-protobuf/1.2.1/2b8ace486645dbaba1f3a694bd3a081f4d7a3aa5/prometheus-metrics-shaded-protobuf-1.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/simpleclient_common/0.16.0/a09a8c790a20309b942a9fdbfe77da22407096e6/simpleclient_common-0.16.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/simpleclient/0.16.0/28b0eaf7c500c506976da8d0fc9cad6c278e8d87/simpleclient-0.16.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/simpleclient_tracer_otel/0.16.0/cc3d2b7b7cb6f077e3b1ee1d3e99eb54fddfa151/simpleclient_tracer_otel-0.16.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/simpleclient_tracer_otel_agent/0.16.0/9d724771e339ff7ec6cd7c0cc170d3470904c5/simpleclient_tracer_otel_agent-0.16.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/simpleclient_tracer_common/0.16.0/dec00ef7c6155c4ca1109ec8248f7ff58d8f6cd3/simpleclient_tracer_common-0.16.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.querydsl/querydsl-apt/5.1.0/3b1cbe05851840b5dc926833908747a193c097cc/querydsl-apt-5.1.0-jakarta.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.querydsl/querydsl-codegen/5.1.0/a8504ea51fbc2258543cedab6a37fe6039b2d20a/querydsl-codegen-5.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.querydsl/querydsl-core/5.1.0/be322c3fe98de8e7c204afb8860bfabd81a3bafd/querydsl-core-5.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.querydsl/codegen-utils/5.1.0/ba401554d613760617992eafb6cdba175c811e6f/codegen-utils-5.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-jcl/6.1.10/c22c18cf6ed7d768676816347f020a6868663224/spring-jcl-6.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-crypto/6.3.1/3e66321782db499cca3884830188a091058121f3/spring-security-crypto-6.3.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.fusesource.hawtbuf/hawtbuf/1.11/8f0e50ad8bea37b84b698ec40cce09e47714a63e/hawtbuf-1.11.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.typesafe/config/1.4.1/19058a07624a87f90d129af7cd9c68bee94535a9/config-1.4.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-posix/3.1.15/f7d6737adcbd5925d625b8f99166de2cbf13caac/jnr-posix-3.1.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hdrhistogram/HdrHistogram/2.2.2/7959933ebcc0f05b2eaa5af0a0c8689fa257b15c/HdrHistogram-2.2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hibernate.common/hibernate-commons-annotations/6.0.6.Final/77a5f94b56d49508e0ee334751db5b78e5ccd50c/hibernate-commons-annotations-6.0.6.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.smallrye/jandex/3.1.2/a6c1c89925c7df06242b03dddb353116ceb9584c/jandex-3.1.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.antlr/antlr4-runtime/4.13.0/5a02e48521624faaf5ff4d99afc88b01686af655/antlr4-runtime-4.13.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.msgpack/msgpack-core/0.9.6/d829f746a66769787e5d7ecab47ba0e4477050e2/msgpack-core-0.9.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.json/json/20231013/e22e0c040fe16f04ffdb85d851d77b07fc05ea52/json-20231013.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.luben/zstd-jni/1.5.5-6/f29e8571c4948a5e6409e9780d2f90b9170e615a/zstd-jni-1.5.5-6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.lz4/lz4-java/1.8.0/4b986a99445e49ea5fbf5d149c4b63f6ed6c6780/lz4-java-1.8.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.xerial.snappy/snappy-java/1.1.10.5/ac605269f3598506196e469f1fb0d7ed5c55059e/snappy-java-1.1.10.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.rocksdb/rocksdbjni/7.9.2/6409b667493149191b09fe1fce94bada6096a3e9/rocksdbjni-7.9.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-collections4/4.4/62ebe7544cb7164d87e0637a2a6a2bdc981395e8/commons-collections4-4.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.mchange/mchange-commons-java/0.2.19/7a4bee38ea02bd7dee776869b19fb3f6861d6acf/mchange-commons-java-0.2.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat/tomcat-juli/10.1.25/b51f8e4d1159a824c0961161af1b5801d3ee5c47/tomcat-juli-10.1.25.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.codehaus.plexus/plexus-interpolation/1.26/25b919c664b79795ccde0ede5cee0fd68b544197/plexus-interpolation-1.26.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-builder-support/3.9.4/671110e56110d5c89eda904f198719a2b5fa4a21/maven-builder-support-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.sisu/org.eclipse.sisu.inject/0.3.5/d4265dd4f0f1d7a06d80df5a5f475d5ff9c17140/org.eclipse.sisu.inject-0.3.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.codehaus.woodstox/stax2-api/4.2.2/b0d746cadea928e5264f2ea294ea9a1bf815bbde/stax2-api-4.2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/spring-bridge/3.0.6/e7047f31108550310f1ed9c2814caea58d875ccc/spring-bridge-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.dynatrace.metric.util/dynatrace-metric-utils-java/2.2.1/a25d8db688874b00aef7539d3bcefda603024c60/dynatrace-metric-utils-java-2.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/info.ganglia.gmetric4j/gmetric4j/1.0.10/3d62003123b586adb86cb028cc0f8a8c3a701d81/gmetric4j-1.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry.proto/opentelemetry-proto/1.2.0-alpha/aab7c61780ea1313bd0382b62080d076671dfe37/opentelemetry-proto-1.2.0-alpha.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.signalfx.public/signalfx-java/1.0.42/2d776effd17ad1394f2242e1cabc8824488b0106/signalfx-java-1.0.42.jar:/home/runner/.gradle/caches/modules-2/files-2.1/aopalliance/aopalliance/1.0/235ba8b489512805ac13a8f9ea77a1ca5ebe3e8/aopalliance-1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.contrib.brave-propagation-w3c/brave-propagation-tracecontext/0.2.0/bdc26787eb3bf99e7172b53df4e170e9a067b44/brave-propagation-tracecontext-0.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry.semconv/opentelemetry-semconv/1.23.1-alpha/218e361772670212a46be5940010222d68e66f2a/opentelemetry-semconv-1.23.1-alpha.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.objenesis/objenesis/3.3/1049c09f1de4331e8193e579448d0916d75b7631/objenesis-3.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.thoughtworks.qdox/qdox/2.1.0/64dd4d16364d1eaecba9f6c4c0d6dbcef8e8160/qdox-2.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.nimbusds/nimbus-jose-jwt/9.37.3/700f71ffefd60c16bd8ce711a956967ea9071cec/nimbus-jose-jwt-9.37.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.latencyutils/LatencyUtils/2.0.3/769c0b82cb2421c8256300e907298a9410a2a3d3/LatencyUtils-2.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-ffi/2.2.11/bcf004ce358c87fc4cd2853b658d336348d0370f/jnr-ffi-2.2.11.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-constants/0.10.3/af19ec7359dd72cbc7869c00bf7cdfa4c308e985/jnr-constants-0.10.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.moshi/moshi/1.8.0/752e7b187599d3ccb174d00ba7235e29add736be/moshi-1.8.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opencensus/opencensus-api/0.31.1/66a60c7201c2b8b20ce495f0295b32bb0ccbbc57/opencensus-api-0.31.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-context/1.62.2/69e86c35140b3b1718d65635bb54ccecc4c12f14/grpc-context-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-api/1.62.2/a93b6ee3761d48edd9a9279f20a58be1a245ad01/grpc-api-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-stub/1.62.2/fc1e85697502d96d6c912e8dd2a56f46f1aba050/grpc-stub-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-protobuf/1.62.2/15aaf31c8d16c3c1c695223d3bd22b75c6405a83/grpc-protobuf-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-protobuf-lite/1.62.2/9d807d2a0e34bd7284a5336186f57cf241090920/grpc-protobuf-lite-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api/api-common/2.30.0/c0621415b79825a4745d57b9f0610be202ef4255/api-common-2.30.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.auto.value/auto-value-annotations/1.10.4/9679de8286eb0a151db6538ba297a8951c4a1224/auto-value-annotations-1.10.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.protobuf/protobuf-java/3.25.3/d3200261955f3298e0d85c9892201e70492ce8eb/protobuf-java-3.25.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api.grpc/proto-google-common-protos/2.38.0/53f7972acb7a89ae6a9bd6f4f7d2743107940e87/proto-google-common-protos-2.38.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api/gax/2.47.0/7aae7101d5b7b6cc3858ba5d23deff61749f9d9a/gax-2.47.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.auth/google-auth-library-credentials/1.23.0/a50ee3611922a0eea9d421c6ddb1db031972a7dc/google-auth-library-credentials-1.23.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api/gax-grpc/2.47.0/7b34f26bd4f79f81eaebd364d2fd19c3537175d3/gax-grpc-2.47.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-inprocess/1.62.2/eff7a21027f8205334c22629cd8c2d38619b95cf/grpc-inprocess-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-core/1.62.2/5808049a5e33eba6f248a68d58e75399a68f2784/grpc-core-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.android/annotations/4.1.1.4/a1678ba907bf92691d879fef34e1a187038f9259/annotations-4.1.1.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.codehaus.mojo/animal-sniffer-annotations/1.23/3c0daebd5f0e1ce72cc50c818321ac957aeb5d70/animal-sniffer-annotations-1.23.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-alts/1.62.2/539c66c5fc83ed2fd356c4a94b41d8b1a2373ad6/grpc-alts-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-grpclb/1.62.2/6007272964ba7afd0ee926f8de8d3badc7ab9f4e/grpc-grpclb-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.protobuf/protobuf-java-util/3.25.3/c2284abc8c484d64ee5cb79bf61d5b7a819f6d50/protobuf-java-util-3.25.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.conscrypt/conscrypt-openjdk-uber/2.5.2/d858f142ea189c62771c505a6548d8606ac098fe/conscrypt-openjdk-uber-2.5.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-auth/1.62.2/5bc444f4e23ed7a8bafdf5eca700d0fd28a44c8f/grpc-auth-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-netty-shaded/1.62.2/a714ecbed7be23639d861015125b6b921481bc97/grpc-netty-shaded-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-util/1.62.2/98c4138f09fb57c3ad6cbeffb31ed73e302038f7/grpc-util-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.perfmark/perfmark-api/0.27.0/f86f575a41b091786a4b027cd9c0c1d2e3fc1c01/perfmark-api-0.27.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-googleapis/1.62.2/b70a7127144ca2a38dacc18b96c9ad2cdc047676/grpc-googleapis-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-xds/1.62.2/40d7036c6ae1aa694d754fde3560a5b29eda9574/grpc-xds-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opencensus/opencensus-proto/0.2.0/c05b6b32b69d5d9144087ea0ebc6fab183fb9151/opencensus-proto-0.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-services/1.62.2/9c323306c41d52641114987aff2ef2adcb889080/grpc-services-1.62.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.re2j/re2j/1.7/2949632c1b4acce0d7784f28e3152e9cf3c2ec7a/re2j-1.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.threeten/threetenbp/1.6.9/39c822e33f202e7c25b54172d8235d484b4966fc/threetenbp-1.6.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.wildfly.common/wildfly-common/1.5.4.Final/735ceee5616d5143bac1bc740e444697073c002f/wildfly-common-1.5.4.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.minidev/accessors-smart/2.5.1/19b820261eb2e7de7d5bde11d1c06e4501dd7e5f/accessors-smart-2.5.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jgroups/jgroups/5.3.2.Final/4155114e89e8c33523df336c91aff70e5d361446/jgroups-5.3.2.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/de.dentrassi.crypto/pem-keystore/2.3.0/945587a5930d1fa7b655c46ce4055a5fb8348121/pem-keystore-2.3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.bouncycastle/bcpkix-jdk18on/1.77/ed953791ba0229747dd0fd9911e3d76a462acfd3/bcpkix-jdk18on-1.77.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.bouncycastle/bcutil-jdk18on/1.77/de3eaef351545fe8562cf29ddff4a403a45b49b7/bcutil-jdk18on-1.77.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.bouncycastle/bcprov-jdk18on/1.77/2cc971b6c20949c1ff98d1a4bc741ee848a09523/bcprov-jdk18on-1.77.jar:/home/runner/.gradle/caches/modules-2/files-2.1/commons-beanutils/commons-beanutils/1.9.4/d52b9abcd97f38c81342bb7e7ae1eee9b73cba51/commons-beanutils-1.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jctools/jctools-core/4.0.2/e8c05d02ac3af90186ba74463be581dac0c110e6/jctools-core-4.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/commons-collections/commons-collections/3.2.2/8ad72fe39fa8c91eaaf12aadb21e0c3661fe26d5/commons-collections-3.2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/activemq-artemis-native/2.0.0/a1bdd3cea7822f3b90063456b0c9928702076bd1/activemq-artemis-native-2.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/osgi-resource-locator/1.0.3/de3b21279df7e755e38275137539be5e2c80dd58/osgi-resource-locator-1.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/class-model/3.0.6/cdb59ed7b763f2fbee0a5595b2d1bad91d22f27f/class-model-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.javassist/javassist/3.30.2-GA/284580b5e42dfa1b8267058566435d9e93fae7f7/javassist-3.30.2-GA.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opentest4j/opentest4j/1.3.0/152ea56b3a72f655d4fd677fc0ef2596c3dd5e6e/opentest4j-1.3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.acplt.remotetea/remotetea-oncrpc/1.1.2/705c490ad22ff4627389853439f9decf5ee69be/remotetea-oncrpc-1.1.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.tdunning/t-digest/3.2/2ab94758b0276a8a26102adf8d528cf6d0567b9a/t-digest-3.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.atteo/evo-inflector/1.3/4cf8b5f363c60e63f8b7688ac053590460f2768e/evo-inflector-1.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.stephenc.jcip/jcip-annotations/1.0-1/ef31541dd28ae2cefdd17c7ebf352d93e9058c63/jcip-annotations-1.0-1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jffi/1.3.9/b776ea131fa693af2c943368b52acf94131cbd7/jffi-1.3.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jffi/1.3.9/163d683f80c06911f3e770c723d6e399e4c59448/jffi-1.3.9-native.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm-util/9.2/fbc178fc5ba3dab50fd7e8a5317b8b647c8e8946/asm-util-9.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm-commons/9.6/f1a9e5508eff490744144565c47326c8648be309/asm-commons-9.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm-analysis/9.2/7487dd756daf96cab9986e44b9d7bcb796a61c10/asm-analysis-9.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm-tree/9.6/c0cdda9d211e965d2a4448aa3fd86110f2f8c2de/asm-tree-9.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm/9.6/aa205cf0a06dbd8e04ece91c0b37c3f5d567546a/asm-9.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-a64asm/1.0.0/a1cb8dbe71b5a6a0288043c3ba3ca64545be165/jnr-a64asm-1.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-x86asm/1.0.2/6936bbd6c5b235665d87bd450f5e13b52d4b48/jnr-x86asm-1.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2.external/aopalliance-repackaged/3.0.6/e3c3f17b649c97155640616026bd32b1043b3c1d/aopalliance-repackaged-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jetbrains/annotations/13.0/919f0dfe192fb4e063e7dacadee7f8bb9a2672a9/annotations-13.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.github.classgraph/classgraph/4.8.146/360448a09bfa5689d89cfa97fea53b3fdefa9c23/classgraph-4.8.146.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.mysema.commons/mysema-commons-lang/0.2.4/d09c8489d54251a6c22fbce804bdd4a070557317/mysema-commons-lang-0.2.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jdt/ecj/3.26.0/4837be609a3368a0f7e7cf0dc1bdbc7fe94993de/ecj-3.26.0.jar"
      "java.vm.vendor" : {
        "value" : "BellSoft"
    "name" : "systemEnvironment",
    "properties" : {
      "JAVA_HOME" : {
        "value" : "/opt/hostedtoolcache/Java_Liberica_jdk/17.0.11-12/x64",
        "origin" : "System Environment Property \"JAVA_HOME\""
    "name" : "Config resource 'class path resource [application.properties]' via location 'classpath:/'",
    "properties" : {
      "com.example.cache.max-size" : {
        "value" : "1000",
        "origin" : "class path resource [application.properties] - 1:29"
    "name" : "logCorrelation",
    "properties" : { }
在此示例中,已关闭敏感值的清理。
响应结构
响应包含应用程序的 . 下表描述了响应的结构:Environment
路径 类型 描述
activeProfiles
Array
活动配置文件的名称(如果有)。
defaultProfiles
Array
默认配置文件的名称(如果有)。
propertySources
Array
按优先级排序的属性源。
propertySources.[].name
String
属性源的名称。
propertySources.[].properties
Object
属性源中的属性按属性名称键控。
propertySources.[].properties.*.value
String
属性的价值。
propertySources.[].properties.*.origin
String
财产的来源(如果有)。
在此示例中,已关闭敏感值的清理。
路径 类型 描述
activeProfiles
Array
活动配置文件的名称(如果有)。
defaultProfiles
Array
默认配置文件的名称(如果有)。
propertySources
Array
按优先级排序的属性源。
String
属性源的名称。
Object
属性源中的属性按属性名称键控。
String
属性的价值。
String
财产的来源(如果有)。
检索单个属性
若要检索单个属性,请向 发出请求,如以下基于 curl 的示例所示:GET/actuator/env/{property.name}
$ curl 'http://localhost:8080/actuator/env/com.example.cache.max-size' -i -X GET
前面的示例检索有关名为 的属性的信息。 生成的响应类似于以下内容:com.example.cache.max-size
HTTP/1.1 200 OK
Content-Disposition: inline;filename=f.txt
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 511
{"property":{"source":"Config resource 'class path resource [application.properties]' via location 'classpath:/'","value":"1000"},"activeProfiles":[],"defaultProfiles":["default"],"propertySources":[{"name":"servletContextInitParams"},{"name":"systemProperties"},{"name":"systemEnvironment"},{"name":"Config resource 'class path resource [application.properties]' via location 'classpath:/'","property":{"value":"1000","origin":"class path resource [application.properties] - 1:29"}},{"name":"logCorrelation"}]}
在此示例中,已关闭敏感值的清理。
响应结构
响应包含所请求属性的详细信息。 下表描述了响应的结构:
路径 类型 描述
property
Object
环境中的财产(如果找到)。
property.source
String
属性源的名称。
property.value
String
属性的价值。
activeProfiles
Array
活动配置文件的名称(如果有)。
defaultProfiles
Array
默认配置文件的名称(如果有)。
propertySources
Array
按优先级排序的属性源。
String
属性源的名称。
propertySources.[].property
Object
属性源中的属性(如果有)。
propertySources.[].property.value
Varies
属性的价值。
propertySources.[].property.origin
String
财产的来源(如果有)。
在此示例中,已关闭敏感值的清理。
路径 类型 描述
property
Object
环境中的财产(如果找到)。
property.source
String
属性源的名称。
property.value
String
属性的价值。
activeProfiles
Array
活动配置文件的名称(如果有)。
defaultProfiles
Array
默认配置文件的名称(如果有)。
propertySources
Array
按优先级排序的属性源。
String
属性源的名称。
Object
属性源中的属性(如果有)。
Varies
属性的价值。
String
财产的来源(如果有)。
