For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
@SessionAttributes
@SessionAttributes is used to store model attributes in the HTTP Servlet session between requests. It is a type-level annotation that declares the session attributes used by a specific controller. This typically lists the names of model attributes or types of model attributes that should be transparently stored in the session for subsequent requests to access.spring-doc.cn
The following example uses the @SessionAttributes annotation:spring-doc.cn
@Controller
@SessionAttributes("pet") (1)
public class EditPetForm {
1 Using the @SessionAttributes annotation.
@Controller
class EditPetForm {
On the first request, when a model attribute with the name, pet, is added to the model, it is automatically promoted to and saved in the HTTP Servlet session. It remains there until another controller method uses a SessionStatus method argument to clear the storage, as the following example shows:spring-doc.cn
@Controller
	@PostMapping("/pets/{id}")
	public String handle(Pet pet, BindingResult errors, SessionStatus status) {
		if (errors.hasErrors) {
		status.setComplete(); (2)
1 Storing the Pet value in the Servlet session.
2 Clearing the Pet value from the Servlet session.
@Controller
class EditPetForm {
	fun handle(pet: Pet, errors: BindingResult, status: SessionStatus): String {
		if (errors.hasErrors()) {
		status.setComplete() (2)
