For the latest stable version, please use Spring Framework 6.2.6!spring-doc.cn
@RequestBody
You can use the @RequestBody annotation to have the request body read and deserialized into an Object through an HttpMessageConverter. The following example uses a @RequestBody argument:spring-doc.cn
@PostMapping("/accounts")
public void handle(@RequestBody Account account) {
fun handle(@RequestBody account: Account) {
You can use the Message Converters option of the MVC Config to configure or customize message conversion.spring-doc.cn
You can use @RequestBody in combination with jakarta.validation.Valid or Spring’s @Validated annotation, both of which cause Standard Bean Validation to be applied. By default, validation errors cause a MethodArgumentNotValidException, which is turned into a 400 (BAD_REQUEST) response. Alternatively, you can handle validation errors locally within the controller through an Errors or BindingResult argument, as the following example shows:spring-doc.cn
public void handle(@Valid @RequestBody Account account, BindingResult result) {
fun handle(@Valid @RequestBody account: Account, result: BindingResult) {
