Jackson JSON
Spring 提供对 Jackson JSON 库的支持。spring-doc.cadn.net.cn
JSON 视图
Spring MVC 为 Jackson 的序列化视图提供了内置支持, ,它们只允许在Object.若要将其与@ResponseBodyResponseEntitycontroller 方法,你可以使用 Jackson 的@JsonView注解激活序列化视图类,如下例所示:spring-doc.cadn.net.cn
@RestController
public class UserController {
	@GetMapping("/user")
	@JsonView(User.WithoutPasswordView.class)
	public User getUser() {
		return new User("eric", "7!jd#h23");
public class User {
	public interface WithoutPasswordView {};
	public interface WithPasswordView extends WithoutPasswordView {};
	private String username;
	private String password;
	public User() {
	public User(String username, String password) {
		this.username = username;
		this.password = password;
	@JsonView(WithoutPasswordView.class)
	public String getUsername() {
		return this.username;
	@JsonView(WithPasswordView.class)
	public String getPassword() {
		return this.password;
@RestController
	@JsonView(User.WithoutPasswordView::class)
	fun getUser() = User("eric", "7!jd#h23")
class User(
		@JsonView(WithoutPasswordView::class) val username: String,
		@JsonView(WithPasswordView::class) val password: String) {
	interface WithPasswordView : WithoutPasswordView
@JsonView允许视图类数组,但您只能为每个 controller 方法。如果需要激活多个视图,可以使用复合界面。
如果您想以编程方式执行上述作,而不是声明@JsonView注解 将返回值用MappingJacksonValue并使用它来提供序列化视图:spring-doc.cadn.net.cn
@RestController
	public MappingJacksonValue getUser() {
		User user = new User("eric", "7!jd#h23");
		MappingJacksonValue value = new MappingJacksonValue(user);
		value.setSerializationView(User.WithoutPasswordView.class);
		return value;
@RestController
	fun getUser(): MappingJacksonValue {
		val value = MappingJacksonValue(User("eric", "7!jd#h23"))
		value.serializationView = User.WithoutPasswordView::class.java
		return value
对于依赖视图分辨率的控制器,您可以添加序列化视图类 添加到模型中,如下例所示:spring-doc.cadn.net.cn
@Controller
public class UserController extends AbstractController {
	public String getUser(Model model) {
		model.addAttribute("user", new User("eric", "7!jd#h23"));
		model.addAttribute(JsonView.class.getName(), User.WithoutPasswordView.class);
		return "userView";
@Controller
class UserController : AbstractController() {
	fun getUser(model: Model): String {
		model["user"] = User("eric", "7!jd#h23")
		model[JsonView::class.qualifiedName] = User.WithoutPasswordView::class.java
		return "userView"
